View Full Version : aftermarket deck
protour_chevelle
01-02-2007, 11:48 AM
Where are you guys getting all of your wires from for an aftermarket deck? I'm putting a system into the Chevelle and am curious towards where the "best" spots are to snag power from.
mucho appreciated
-Matt
andrewb70
01-06-2007, 09:06 PM
mucho appreciated
-Matt
Power for the deck or for the amp? In my GTO the amp gets power directly from the battery through a 100AMP fuse. I don't have a deck, just an iPod hooked directly to the amp. You should have a few spare circuits on the stock fuse panel where you can draw power for a deck.
67cam
01-11-2007, 06:56 AM
For the power of a deck I would run off the ACC hot on your ignition. That way when you turn of the car the raido turns off and you dont kill your battery. The ACC wire is the pink (it should lead up to the accessorie side of the ignition) wire leading to the ignition switch.
