View Full Version : Suspension
- relocate rear shock on 1988 monte carlo, more tire clearance less bind (0 replies)
- are coil overs better in front than stock springs (1988 monte) i have 700 lbs springs (4 replies)
- 1969 BB convert. need suspension (3 replies)
- Opinions reviews and feedback on DSE Camaro subframe? (5 replies)
- and now to the rear, drop leafs or 4 link? (5 replies)
- Help with Bilstein "Deflective Disc Valving" monotube (2 replies)
- 1972 Monte Carlo suspension upgrade? (13 replies)
- rack and pinion vs. standard steering, opinions? (10 replies)
- if you use intermediate steering shaft out of jeep cherokee, i had an issue (2 replies)
- global west control arms (0 replies)
- 12-bolt housing alignment (11 replies)
- jeep cherokee center steering link that eliminates rag joint can fail (0 replies)
- rear shock mounting (2 replies)
- changing pitman and idler arm angles to get rid of toe out when the gbody turns (8 replies)
- Alston Canted 4 bar rear clip (0 replies)
- Ridetech upper control arm issue (6 replies)
- At crossroad, upper arms for '72 El Camino (37 replies)
- Lighter weight suspension parts for 2.gen fbody? (1 replies)
- Coilovers - Ridetech vs. Viking (16 replies)
- Need Some Input Coilovers on A Budget (20 replies)
- It's spring time, good reason for a new Subframe... (0 replies)
- Securing upper and lower links (1 replies)
- Antoher Caster Thread:68 Mustang Version (5 replies)
- Another issue with Ridetech Tru Turn 69 Camaro (26 replies)
- Steering Setup in a '66 Mustang (1 replies)
- Opinion on Afco Camaro leaf springs (2 replies)
- UMI Releases New Product: Front Frame Reinforcement Brace for the 1978-1988 GM G-Body (2 replies)
- CPP C5 Upright & Hub Weight? (9 replies)
- Help me determine what my tire temp reading are telling me. (1 replies)
- Leaf shackle difference (4 replies)
- Steering Shaft (2 replies)
- 1970-81 quadra link bolt torque? (1 replies)
- Cal Trac Leaf Springs (7 replies)
- Art Morrison rear clip in 1969 Camaro ( South Texas ) (8 replies)
- U-Joint Doesn't Go In All The Way (2 replies)
- CPP Stage IV Pro tour kit (3 replies)
- Spherical Leaf Spring Joints for '67-'81 F-Body (19 replies)
- UMI Releases New Product: Auto-x/Road Race Rear Sway Bar for the 1978-1988 GM G-Body (0 replies)
- suspension painting (3 replies)
- Shocks for lowered El Camino (0 replies)
- unisteer steering arms with 275 front tire/17 x 9.5" wheels (6 replies)
- Calling all c10, and suspension guru's! (2 replies)
- IFS for 67 fastback coyote swap (0 replies)
- Has anyone installed a RideTech level 2 c/o kit for GM A-Body? (5 replies)
- anyone try to install G8 front wheel bearings on 4th gen Trans Am? (8 replies)
- Teach me what to measure (2 replies)
- 75-79 nova (5 replies)
- KONI Shocks on Sale @ BMR Suspension 20% Off (0 replies)
- Reman IROC steering box....too much play?? (6 replies)
- Collapsible steering column (2 replies)
- How to fit Fox Mustang to Maverick? (3 replies)
- Geometry issue - links and panhard crooked (3 replies)
- second gen fbody subframe mods (7 replies)
- Lee Mfg coming back? (1 replies)
- Mustang II steering feel (10 replies)
- speed tech performance (5 replies)
- Ridetech Coilover preload??? (11 replies)
- 66 fastback ame options (0 replies)
- New stance after level 2 Ridetech 1967 Gto (5 replies)
- A-body Jeep steering box (1 replies)
- Wheel clearance issues after Ridetech install (16 replies)
- Aftermarket subframe DSE vs others (5 replies)
- This is bad right? (chevelle rear c/o related question) (5 replies)
- Not Pro-Touring ,but a Nice Article on how well BMR Parts hold up! (0 replies)
- 69 Camaro DSE Stage II kit Issues (1 replies)
- Sway Bar Mounting Problem! (7 replies)
- BMR Suspension New Product Release - G-Body Control Arm Reinforcement Braces - RB003 (0 replies)
- Cris Alston G-link ridehight problems 2nd fbody ('73 firebird) (1 replies)
- 72 Nova Pro Touring Look Street driven? (18 replies)
- Wilwood ProSpindle kpi/sai (14 replies)
- Detroit Speed Kit #1 for GM A body... (6 replies)
- What's the average ride height drop for stage 2 Ridetech coil overs (3 replies)
- Chevelle rack and pinion questions (9 replies)
- c5/c6 spindle conversion for the c2? (12 replies)
- Is there still any interest in B-Body spindles or brakes? (2 replies)
- 1969 Camaro needs a total suspension make over. Suggestions, on a budget. (14 replies)
- coilovers or performance springs? (2 replies)
- Suspension physics models (8 replies)
- UMI Releases New Product: Bolt In Rear Lift Bars for the 1978-1988 GM G-Body (0 replies)
- A great deal on control arms for G bodies! (0 replies)
- Heim Spacers for Bilstein Shocks? (2 replies)
- abc performance mini tub kit(65 gto) (12 replies)
- Rear-end Noise After 4-link (7 replies)
- Need Sponsor for New Build (5 replies)
- Monoleaf to multi with 1.5"drop - mounting plate /Camaro 67/ (0 replies)
- CPP 500 Series™ Power Steering Kit for 68 Camaro (0 replies)
- Power steering pump inlet fitting (1 replies)
- Installing custom rear frame rails in 77 Firebird Trans Am (2nd gen fbody) (5 replies)
- Camber + Caster VS its affects when steering (7 replies)
- do full frames stop body stress cracks? (1 replies)
- Olds power steering pump bracket (6 replies)
- 64 Chevy II springs (0 replies)
- AMC Rebel suspension project (3 replies)
- RideTech front Muscle bar fitment? (9 replies)
- What grease for DSE control arms and ball joints (5 replies)
- ride Tech rear suspension .....something changed! (11 replies)
- sub frame connector fit (6 replies)
- 1st Gen Firebird w/ Speedtech Torque Arm (on a Blazer 8.5" 10 Bolt?) (1 replies)
- UMI New Release: Handling Kit with Factory Height Springs for the 64-72 A-Body (0 replies)
- Help identify Detroit locker (2 replies)
- G body front suspension (5 replies)
- 2nd gen camaro any high clearance front sway bars? (42 replies)
- CPP Upper Control Arms? (6 replies)
- DSE control arms vs Summit control arms (54 replies)
- control arm length (9 replies)
- 55-57 Thunderbird? (1 replies)
- Ridetech Chicane mounts on a 70 Chevelle (7 replies)
- 69 Camaro ls3 (6 replies)
- Ridetech coilovers rising through mounts under load on a '66 Chevelle (20 replies)
- Wheel Hop with G-Link rear suspension (14 replies)
- Modeling Suspension Geometry Camaro FE4 (1 replies)
- RRS suspension (2 replies)
- front suspension thoughts on a B-Body Mopar - RMS vs. XV (9 replies)
- RideTech StreetGrip suspension for competition? (8 replies)
- Steering box options (3 replies)
- GM Ford Axle bearings (0 replies)
- Detroit Speed Steering Shaft Issue (28 replies)
- Running no subframe bushings (8 replies)
- ridetech street gripfor 68 cutlass (6 replies)
- 1968 cutlass (3 replies)
- G Body - Front adjustable upper control arms (3 replies)
- Ford Fuel tank between custom frame (2 replies)
- Rear axle weight on a leaf spring, light tail vehicle (2 replies)
- Drop spindles for classic mustang (4 replies)
- Torque arm rear - Speedtech vs CA Chassisworks (23 replies)
- Rear end offset and front end alignment. (2 replies)
- G body - adjustable rear control arms (5 replies)
- Options steeringboxes, saginaw, delphi, DSE, AGR, borgeson vs rack FR, UNI (5 replies)
- Front shocks help.. (1 replies)
- UMI Christmas Sale- 10 Days of 10% off & Free Shipping! (0 replies)
- BMR Suspension Christmas / New Years Sale (2 replies)
- Initial adjustment of double adjustable a-arms for front suspension mock up (1 replies)
- Hotchkis Leafs or 4 Link (24 replies)
- Left over DSE Quadra Link Parts (3 replies)
- 89-04 Mustang front suspension question (1 replies)
- More ridetech hurtles (3 replies)
- Ball joint question. (1 replies)
- Upper Control Arm Cross Shafts (21 replies)
- 68 Cutlass 'vert suspension: potentially highly redundant (8 replies)
- Upper mount angle G-Body rear (0 replies)
- Can someone critique my set-up (15 replies)
- Wheel bearing grease and preload questions. (2 replies)
- Narrowed tubulars on a 67 Camaro (0 replies)
- Different alignment specs for rack and pinion (10 replies)
- 70-81 F Body Negative Caster Issue (10 replies)
- 68 chevelle shocks on a 67 chevelle (0 replies)
- Welding on Axle Housing Tubes (4 replies)
- Ridetech Coil over system Level 1 wheel size question.. (18 replies)
- Subframe connector install time frame? (3 replies)
- Ford 9" for 69 Camaro with g-Link Suspension rear Chris Alston (18 replies)
- Ridetech 4 Link Spring Rate (2 replies)
- Exhaust routing for g-LINK PIVOT-BALL 67-69 CAMARO REAR COIL-OVER suspension. (11 replies)
- Ridetech Thanksgiving Specials (1 replies)
- UMI Releases New Product: Bolt In Rear Coilover for the 1964-1972 GM A-Body (1 replies)
- UMI 6-Day Thanksgiving Sale! 10% Off & Free Shipping! (0 replies)
- Ridetech stage 2 air ride help! (3 replies)
- Coil Spring advertised rate vs installed rate (3 replies)
- 6 Day Black Friday Suspension dealio! (0 replies)
- Gbody frame notch. (5 replies)
- Torque arm location preference question (5 replies)
- BMR Suspension Thanksgiving/Black Friday/Cyber Monday Sale (4 replies)
- C5 brake conversion mounts (3 replies)
- How long to install level 2 non air Ridetech (3 replies)
- Ridetech HQ coilover set 68 camaro (1 replies)
- 69 Chevelle Muscle Bar hitting frame (4 replies)
- Great article on Ron Sutton in "The Shop" (2 replies)
- 1967 Chevy II Nova time to mini tub and 4 link what do you all recommend ? (4 replies)
- Black Friday Sale 4 Link Suspension (2 replies)
- 67 Camaro what suspension to go with ??? (18 replies)
- What happened to the RideTech Select series coilover? (5 replies)
- BMR Suspension Releases New Product - 1.5" Drop G-Body Lowering Springs - SP035 (1 replies)
- Ridetech 4 link question... (3 replies)
- QA1 Mopar K-Member??? Street and track use? (7 replies)
- Ride height question (4 replies)
- Upper arms for Speedtech AFX (3 replies)
- Tuning for the street (3 replies)
- Driveline question (3 replies)
- Is the Ride Tech Tiger Cage NHRA/IHRA or SCCA certified yet? (24 replies)
- Need help with driveline angle set up (0 replies)
- Rear lower control arms for 2003 Mustang (5 replies)
- Ridetech 4 Link or TCP g-Bar Suspension (4 replies)
- SPC Control arm issues (5 replies)
- Looks like Chris Alston has a 4 way adjustable Varishock coilover (8 replies)
- Safe to ream out ball joint holes in spindles on 65 Skylark? (14 replies)
- 4 Link and Torque Box Problems (0 replies)
- TCP Leaf Springs (0 replies)
- Air bags on UMI control arms? (3 replies)
- Mixing A arms? (5 replies)
- p/s pump that keeps up at autocross? (2 replies)
- Is Lee's manufacturing out of business? Anyone else reputable to build a box?? (2 replies)
- BMR 1st Gen Lowering Springs are ready! (0 replies)
- SEMA Speedtech and Ron Sutton booth appearance (3 replies)
- Coil Over spring rates VS coventional coil spring rates (7 replies)
- First Gen Camaro IROC steering box swap question (8 replies)
- Crazy spindle idea- will it work? (12 replies)
- Budget Upper/Lower control arms 1969 Camaro? (6 replies)
- RideTech StreetGrip debuts at SEMA! (25 replies)
- All Wheel Steering (27 replies)
- Pro touring suspension street manners (24 replies)
- Hotchkis wait times?? (10 replies)
- Mii suspension travel (3 replies)
- Suspension update for Daily Driver 70 Chevelle (13 replies)
- Art Morrison vs Roadster Shop (4 replies)
- Process in bagging a Task Force (3 replies)
- Steering Wheel Won't self- center (18 replies)
- 67 firebird ridetech 4 link install help (19 replies)
- RideTech Posi Link Alternative (1 replies)
- 69 Camaro - trouble with QA1 shocks mounting to Cal Trac shock mounts (3 replies)
- Got BMR lowering springs? We want pictures of your car! (7 replies)
- Anyone run a 315 front tire with Ridetech stage 3 ('69 Camaro) (5 replies)
- F-body driveline angles-1st gen (3 replies)
- Radius Arms Vs Trailing Arms (7 replies)
- sweet steering box (0 replies)
- MIi kits (0 replies)
- wheel size with detroit speed subframe, first gen camaro (18 replies)
- Just installed a CA Chassisworks front upper and lower control arms, but .... (1 replies)
- Pontiac Type II Power Steering Pump (43 replies)
- quick ratio manual box (0 replies)
- 1972 Pontiac Lemans Power Steering box upgrade project I need help/input! (0 replies)
- rear coil over set up and clearance (10 replies)
- Now that Lee Steering is out of business who to use? (10 replies)
- lee manufacturing adapter fittings (5 replies)
- Speedtech upper control arm angle seems too much under load? (19 replies)
- GM A/F/X spindle dimensions (0 replies)
- Thinking about a Fays2 watts link in my GTO next spring, looking for feedback (3 replies)
- Deciding on suspension for my 1967 project. DSE and quadralink system? (5 replies)
- Advantages of an aftermarket subframe? (13 replies)
- Driveshaft angle? A body (2 replies)
- IRS parts and the aftermarket - what's the current state of affairs? (13 replies)
- SC&C Mark Abody brace and Hellwig FSB (3 replies)
- Coil-over question - help appreciated (4 replies)
- 1967 Camaro Subframe/Suspension identification. (2 replies)
- 1966 Chevelle steering box question (1 replies)
- A couple for the chevy truck guys (7 replies)
- UMI Releases New Product- Bolt In Rear Relocation Brackets for the 78-88 GM G-Body (1 replies)
- Changing KPI from 4.75 to 8.75? (3 replies)
- Popping noise from under the car with event coming up in 2 weeks (8 replies)
- Custom AMC front A arms (27 replies)
- UMI Releases New Product- Bolt In Rear Shock Tower Brace for the 1964-1972 GM A-Body (8 replies)
- Measuring Camber Question.. (0 replies)
- 66 Chevelle ride tech drop spindle (5 replies)
- How much should I drop the front and/or rear? (36 replies)
- best shocks for a driver / weekend toy? (0 replies)
- Triumph GT6 project... Built frame, SBC, etc... Which coil Overs? (11 replies)
- 1966 Chevelle with coil overs front and rear??'s (2 replies)
- rear suspension help needed (2 replies)
- Setting Ride Height (1 replies)
- help? DIY front suspension set up? (8 replies)
- 1969 z28 Wayne due full frame c4 (4 replies)
- Uni Steer 1978-88 GM G-body rack & pinion kit (0 replies)
