View Full Version : Gbody frame notch.
87cutty
11-24-2015, 02:19 PM
I have an 87 cutlass supreme. I need to fit 11-11.5 tire under wheel wells. I have seen the notching done and a mini tub. Can notching get me there or should I just go mini tub. I am getting aftermarket wells too. Budget build so I would appreciate any insight
Schwartz Performance
11-24-2015, 02:30 PM
I think you'd need to notch AND minitub, no?
-Dale
87cutty
11-24-2015, 03:40 PM
Ok. So if u could help on a mini tub Wat all does it entail?
87cutty
11-24-2015, 03:46 PM
Just doing the wheel wells....
You need to look at the backspacing/offset of the rims you are planning to use. Get the wheel off, set the suspension at ride height and measure how much room you have under there.
If you are going to notch, have a look at this:
http://www.maxchevy.com/tech/2008/iii_8-frame-1.html
Streetbu
01-22-2016, 06:38 AM
You will need a notch and tubs to fit that wide of a tire. You will need to cut out the old tub, I would buy premade wheel tubs and cut the floor and new tubs to fit. You will also get into the supports for the trunk hinge that are spot welded to the tubs. Not hard, but very time consuming....
