View Full Version : Upper arms for Speedtech AFX
rpinnt
11-10-2015, 02:10 AM
I am planning on using the tall AFX spindle on my 1965 Cutlass. My rear suspension is Hotchkis would like to use them for the front as well. I see that they have upper arms for stock (1102C) and tall spindles (1103C.) I tried to ask their tech but only got a vague reply if either one would work. Anyone using Hotchkis uppers and if so, which one?
UMI Tech
11-10-2015, 05:56 AM
Welcome to the board.
If you decide to research different brands, we have a tall spindle worthy arm which works awesome with the AFX spindle.
http://umiperformance.com/catalog/index.php?main_page=product_info&cPath=1_250_267&products_id=956
The 4056 is shorter pivot to ball joint and (usually) doesn't require shims to achieve alignment.
ramey
BMR Sales
11-10-2015, 07:41 AM
You want an Arm that is designed for Tall Spindles as the Angles change.
http://www.bmrsuspension.com/?page=products&productid=47&superpro=0
Build-It-Break-It
11-10-2015, 11:54 AM
Why not just order the Speed Tech upper and lower arms that are built for their AFX spindle? I wouldn't have any brand loyalty, I'd use whats meant to work together from the start.
