neongreen
03-01-2016, 08:28 PM
I searched a bit and didn't find anything addressing this topic specifically, so here goes.
I have a TCI Mustang II suspension in my Falcon. I haven't had a chance to really rail on it, I'm still sorting things out. However, my initial impressions are that the steering is touchy and overboosted. This hasn't been aligned properly and that may be part of my issue, but bear with me. Initially I had the caster settings all wrong. I don't think it was negative, but definitely closer to neutral, and it was very twitchy. I realized I had it set up wrong, so I adjusted the caster as positive as is possible with this suspension system. It helped a ton, but I still feel that the steering is overboosted.
I know that this can be an issue when GM pumps are mated with Mustang II racks, and it's common to use this valve to remedy the problem. http://www.speedwaymotors.com/Mustang-II-Power-Steering-Flow-Valve-for-GM-Pump-2-GPM,5852.html That would be all fine and good if I were using a GM pump, but I am using a Ford PS pump with the Ford rack but I don't really like the steering feel. Could this just be too much toe out? Not enough caster? Do I need a UCA with more caster built in? Is there a way to reduce the output of a late 80s Ford PS pump?
