View Full Version : Anyone run a 315 front tire with Ridetech stage 3 ('69 Camaro)
MattG
10-11-2015, 06:34 AM
At Holley LS Fest this year I saw two '69's with Anvil's carbon front fenders. They are 1.5 inches wider than stock and both cars had the DSE subframe. They had 18/11 rims with 315 wide tires. Stielow runs the same setup I think.
Question is has anyone run these fenders with the Ridetech suspension?
I'm sure it can work. My wheel is a 9.5/18 with 5.75 backspacing. I run a Falken 275 tire and if I change the fenders and the outer shell of the wheel by 1.5 inches, I should be able to fit the 11 inch wheel with the 315 wide tire.
Any thoughts...
Matt
MattG
10-12-2015, 02:19 PM
O.K., guess I'll be the first to try it...time to trail blaze!
Schwartz Performance
10-12-2015, 07:03 PM
Your backspacing will remain the same, so as long as there is actually 1.5" of additional fender clearance then there's no problem.
-Dale
MattG
10-13-2015, 06:11 AM
-Dale
That's what I'm hoping...ordering the fenders today (3-4 month wait).
dontlifttoshift
10-13-2015, 07:29 AM
I know the Red 69 you looked at is running the 315 on a 10.5, not an 11. That's a 6.125 backspace wheel with the DSE sub and 1.7* negative camber.
Stielow also ran a 10.5" wheel on Hellfire.
MattG
10-13-2015, 12:04 PM
Now that's good info...I would rather run a 10.5 anyway. I'm at 1.2 camber right now and would like to get closer to 2* anyway. That red '69 at LS Fest was making me drool. Nice gentleman driving it too, thinks he went by Gramp's or Pop's or something like that.
