View Full Version : Carburetion
Pages : [1] 2 3
  1. Carb theory: What made the spread-bore designs so effective? (0 replies)
  2. Sniper back to a Carb (14 replies)
  3. Boost reference needed or not??? (0 replies)
  4. Need a recommendation (3 replies)
  5. fuel tank for carb'd 69 camaro (11 replies)
  6. Holley HP125 Fuel Pump Problems (0 replies)
  7. Having a rough time resurrecting 350/4 barrel combo (7 replies)
  8. Cowl induction airbox questions. (3 replies)
  9. 58 psi adjusted to 6 psi (4 replies)
  10. Throttle arm problems (3 replies)
  11. Help Needed - extremely rich (12 replies)
  12. Holley 4053 3923289 carb question (0 replies)
  13. Carb is running too rich! (33 replies)
  14. lean spot just of idle + 1 mixture screw not responding 4150 DP (1 replies)
  15. Vapor lock, air/fuel creep - need to fix or just live with it (5 replies)
  16. Fuel filter not full - potential vapor lock? (3 replies)
  17. Edelbock 650 AVS sneezing (0 replies)
  18. Electrical fuel pump carburetor (13 replies)
  19. Carb issue....maybe..... (5 replies)
  20. B-day present to myself, 4 x 44 Weber IDF's! (1 replies)
  21. Think my fuel pump is dying... (4 replies)
  22. air bleed question (2 replies)
  23. Carb identification? (3 replies)
  24. VaporWorx Intelligent Power Controllers Redefines Carburettor Fuel Pump Control (0 replies)
  25. return line set up (4 replies)
  26. E85 Carbs (4 replies)
  27. Holley Ultra XP 850 vs 950? (11 replies)
  28. 4150 base plate R80145 (0 replies)
  29. This car is driving me crazy. (4 replies)
  30. Help Identifying This Carb (3 replies)
  31. 1967 Gas Tank Question with DSE Mini Tubs Questions (5 replies)
  32. Fuel Sending Unit for Early SBC (4 replies)
  33. Edelbrock carb, banjo fitting? (4 replies)
  34. Q-Jet fuel leak help. (6 replies)
  35. 69 El Camino 454, surging out of gas.. (4 replies)
  36. Sf Bay Area tuner (2 replies)
  37. Need help with carb set up... (2 replies)
  38. Supercharged engine gerotor fuel pump suggestion needed (1 replies)
  39. Vapor lock or bad fuel pump? (0 replies)
  40. Looking for recommendations on fuel system (0 replies)
  41. fuel system upgrade (2 replies)
  42. Having a little problem, need help please (18 replies)
  43. Carburetor section on forum inactive (15 replies)
  44. Regulator question (7 replies)
  45. Intank fuel pump suggestions ??? (1 replies)
  46. Carb rebuilt how to's for beginner (4 replies)
  47. Air Cleaner (6 replies)
  48. Holley vs Edelbrock carbs... 455 Olds Engine. Opinions? (19 replies)
  49. Need advice on carb selection.... (11 replies)
  50. Holley 670 Air Bleeds clogged in 2 weeks sitting? (4 replies)
  51. Solenoids on Carbs (7 replies)
  52. Spectre Cold Air Intake (1 replies)
  53. tuning a Holley DP on a 396BB, used Vacuum method still running rich (3 replies)
  54. So removed the throttle rods and went throttle cable today in my 66 Chevelle (0 replies)
  55. Fuel line placement, Regulator mounting, plumbing the fuel log etc (0 replies)
  56. Oldsmobile Carburetor Problems (2 replies)
  57. Carb Tuning w/ Wideband (3 replies)
  58. Help choosing electric fuel pump (6 replies)
  59. smoke coming out of carbs on start (1 replies)
  60. I need some Holley help please! (5 replies)
  61. lost fuel pressure (1 replies)
  62. LS3 Carburetor selection? (0 replies)
  63. dual quad issue (3 replies)
  64. fuel help not surat is going on (2 replies)
  65. Wide band A/F meter reading (3 replies)
  66. Modify Filler Neck On Stock Gas Tank (3 replies)
  67. -10 Fuel Logs (2 replies)
  68. Quadrajet help (14 replies)
  69. 67 camaro Carburetion questions. (4 replies)
  70. Carb relocation - any one ever tried it? (9 replies)
  71. Primary bowl vent looks like a smoke stack (1 replies)
  72. edelbrock carb help needed (3 replies)
  73. Aggravating Holley Leak! (9 replies)
  74. Holley help (6 replies)
  75. FPR suggestions and installation (3 replies)
  76. Fuel system plumbing, advice needed.... (3 replies)
  77. Help: Mechanical Pump with return port, but no return line (3 replies)
  78. Fuel cell vapor problem (4 replies)
  79. Oil from SBC Mechanical Fuel Pump Question (3 replies)
  80. Help with narrowed fuel tank ... (3 replies)
  81. Recommend a wideband (19 replies)
  82. Richer then rich (9 replies)
  83. Fuel Leak Back (3 replies)
  84. What Elecric fuel pump should I buy? (12 replies)
  85. My car stinks! (16 replies)
  86. Running a Holley UltraHP 750 on a very mild 454 (6 replies)
  87. Any Way to tell the CFM on a carb? (3 replies)
  88. Stainless Steel Fuel Line (8 replies)
  89. Lokar bracket and throttle kit issues for Q-jet application (8 replies)
  90. Inline electric fuel pump for carb? (3 replies)
  91. Air Cleaner height over carb? (11 replies)
  92. holley 750 dp? (5 replies)
  93. Looking for a new carb. (4 replies)
  94. Carbed LS engine stumble problem at 5500RPM! (5 replies)
  95. Holley 750 not maintaining Idle after installing fuel pressure gauage (5 replies)
  96. Holley 4160 Rebuild Questions (5 replies)
  97. Important Cabrburetor Question (5 replies)
  98. Already using smallest secondary rods...how to further richen quadrajet secondaries? (6 replies)
  99. idle and off throttle surge - edelbrock 1405 (0 replies)
  100. carb fuel demon during hard turning... ideas and any help (0 replies)
  101. Is this right for Rick's Tank (4 replies)
  102. Demon Blow Thru Carbs now available. (0 replies)
  103. Holley carb problem Just started happening (9 replies)
  104. carb popping (4 replies)
  105. Carburetor question (4 replies)
  106. Holley VS on OEM Pontiac AFB intake? (3 replies)
  107. carb (1 replies)
  108. Help tuning carburetor for street use (9 replies)
  109. Holley carb cant get a consistant idle (9 replies)
  110. holley carb choices (7 replies)
  111. Spectre (4 replies)
  112. Carb tuner referral needed (3 replies)
  113. Edelbrock leaking fuel from top. (2 replies)
  114. Oil catch can or oil air separator or both? (2 replies)
  115. Rick's stainless tank number (2 replies)
  116. Edelbrock carb tuning for autocross (7 replies)
  117. Fuel Cell recommendations? (3 replies)
  118. Best air filter (2 replies)
  119. Carbon Fiber Air Cleaner Top (10 replies)
  120. Jet compatibility (1 replies)
  121. looking for sp2p (0 replies)
  122. auto parts (0 replies)
  123. carb tuning for dummies? (4 replies)
  124. Help with idle - holley 4150 (10 replies)
  125. AFR Composite Intake Manifold (3 replies)
  126. Holley leaking fuel???? (1 replies)
  127. Need New Carburetor For 1967 Pontiac Tempest (2 replies)
  128. What carb should I use? Shaker455?? (3 replies)
  129. building new bbc fuel system (4 replies)
  130. 1/2 INCH FEED 3/8 RETURN.. Three different places, three different opinions... HELP. (7 replies)
  131. Help with Carb selection for Pro-Touring 455 Olds big block (12 replies)
  132. Holley trick kit (2 replies)
  133. Carter carb question (7 replies)
  134. converting 4 corner idle to 2 corner? (8 replies)
  135. Holley DP idle mixture questions (2 replies)
  136. think you heard this before :-) (0 replies)
  137. holley fuel return question (18 replies)
  138. New Holley HP Double pumper - Electric choke (6 replies)
  139. Plumbing Ricks Tank return line with Ricks Tank intank fuel pump (0 replies)
  140. 396 carb size (2 replies)
  141. Carb sticking? (16 replies)
  142. changed jet size now it wont start (1 replies)
  143. Holley help- 3 days to Power Tour!!! (9 replies)
  144. edelbrock 600 turing issues (1 replies)
  145. My demon needs servicing! (8 replies)
  146. Breaking up in third gear (3 replies)
  147. Fuel Pressure Regulator Setup.. (2 replies)
  148. Demon Carbs (4 replies)
  149. Carb Guru's, I need some help. (1 replies)
  150. Very Rich ... Blow Through Setup ... Ideas (2 replies)
  151. Air Bleeds on SD Concept Engineering Prepped Carb for Blow Through, Are these Right?? (2 replies)
  152. Fuel Pump Suggestions.. (35 replies)
  153. how close can a carbs come to fuel injection (12 replies)
  154. 950HP idles to fast (15 replies)
  155. Tuning 600cfm holley for 305 engine input needed. (6 replies)
  156. Wall thinkness for SS 1/2 fuel lines.... (6 replies)
  157. Stock 69 Camaro has 2 lines going from the tank to the fuel pump. Why? (8 replies)
  158. Help Me Build a Fuel System (6 replies)
  159. demon carbs, are they back? (3 replies)
  160. Engine Bogs/Discharge Nozzles/ Manual Camaro (20 replies)
  161. Fuel return line for a carb? ie Carb to tank? (9 replies)
  162. What size jets for my 625 Demon? (8 replies)
  163. stop the gas from leaking from the fill tube (8 replies)
  164. Fuel Volume Problem (5 replies)
  165. Steel fuel lines, what fittings to use? (6 replies)
  166. starting problems (10 replies)
  167. Oil leak from mechanical holley fuel pump (1 replies)
  168. Aluminum hard line (4 replies)
  169. 4150 Lacks Throttle Response When Hot, Help Please (27 replies)
  170. Need help with Mighty Demon 650 (6 replies)
  171. Any experiences with smaller return fuel line? Pump selection? (8 replies)
  172. Barry Grant badman, can't find one (ford) (7 replies)
  173. sea foam with carb (3 replies)
  174. Custom Shaker Air Cleaner (2 replies)
  175. How much do PTFE fuel lines cost, any brand recommendations (3 replies)
  176. A/F Ratio tuning questions..... (16 replies)
  177. Barry Grant back in buisness (6 replies)
  178. Pro-Systems SV1 - any experience, comments, good/bad? (9 replies)
  179. Spectre Air Intake Kit (7 replies)
  180. Help setting up a carbed car to drift (2 replies)
  181. trying to decide on which brand carb (19 replies)
  182. anyone make a lid similar to this (10 replies)
  183. Carb for 383 stroker (8 replies)
  184. Idle feed restrictors VS Air Bleeds (2 replies)
  185. mini tubbed f-body .....what fuel tank (2 replies)
  186. mechanical fuel pump test (0 replies)
  187. Carb and linkage for 300hp GMPP, 700R4 autocross '68 Camaro? (5 replies)
  188. I got it running and driving... tuned??? Well lets say it's rough. (4 replies)
  189. 1969 quadrajet vacume advance hook up? (0 replies)
  190. Carter AVS (2 replies)
  191. throttle cable mounting (1 replies)
  192. Cfm? (4 replies)
  193. spectre or k&n (1 replies)
  194. Demon 750 issue (7 replies)
  195. Carb Tuning For Elevation (1 replies)
  196. which carb to get? (3 replies)
  197. Linkage Pics (3 replies)
  198. throttle linkage....... (3 replies)
  199. Help! Who knows someone at Barry Grant??! (11 replies)
  200. Carburetor Tuning in Southern California (14 replies)
  201. tweaking an edelbrock carb for autocross (1 replies)
  202. Help guys!! 750 Holley Double pump over flowing on secondary side, Gas everywhere!! (7 replies)
  203. Demon 750 problems (2 replies)
  204. Tank vs. Fuel cell (4 replies)
  205. Demon Carb needs heli coil insrts - need a kit (2 replies)
  206. pro series carb (5 replies)
  207. Gas Tank - stainless vs. zinc coated (2 replies)
  208. Help Me with my Pinging issue... Please (4 replies)
  209. Custom Carburetor Spacers? (1 replies)
  210. carb breaking up under moderate throttle (3 replies)
  211. carb tuning with wbo2 sensor...cant get it right (20 replies)
  212. Holley Tuning for E10 (22 replies)
  213. anyone have experience with Weber Carbs? (4 replies)
  214. Carb with better street manners for my BBC 540 (20 replies)
  215. full injection or carb (1 replies)
  216. demon 850 idle (9 replies)
  217. Off-Idle engine stumble (near stall)... how to troubleshoot/correct it? (4 replies)
  218. Carb suggestion for my 383 stroker. (8 replies)
  219. Rick's efi tank to carb plumbing? Will it work? (5 replies)
  220. Help Correcting Strange Idle Issue (5 replies)
  221. interchangeable gaskets (2 replies)
  222. What Carb throttle pedal/linkage. assem/Pics (0 replies)
  223. How to plumb 1/2" line to Tank? (2 replies)
  224. Which Mechanical fuel pump? (8 replies)
  225. Aeromotive A1000 (5 replies)
  226. vacuum leak test (3 replies)
  227. Holley Support is no Help! (12 replies)
  228. Intake Recommendation for 383 (4 replies)
  229. Ricks SS tank for 1st Gen Camaro (0 replies)
  230. Reversion? (9 replies)
  231. sbc fuel line (1 replies)
  232. How Much Fuel Flow for 550 HP? (2 replies)
  233. Carb or EFI, If you were to do it over, would you? (8 replies)
  234. Throttle Plate Replacement (3 replies)
  235. Carb Selection - zz383 (1 replies)
  236. Poor Running zz383 Help Needed (4 replies)
  237. Summit Carbs ??? (1 replies)
  238. 454 tune (15 replies)
  239. Idle mixture screws (1 replies)
  240. Carb Theory Help (3 replies)
  241. Which carb should I be using? (1 replies)
  242. Carb question (30 replies)
  243. Opinion on Edlebrock Carb (11 replies)
  244. Fuel Feed Line Size (9 replies)
  245. Doooo What...... (3 replies)
  246. how to cleaning up a grimey Edelbrock Performer Carb????Help (4 replies)
  247. Quality fuel sending unit? (6 replies)
  248. Holley 830 carb question (3 replies)
  249. Motorcycle Carbs (1 replies)
  250. Opinion Please (15 replies)
