View Full Version : Having a rough time resurrecting 350/4 barrel combo
JustJohn
03-15-2021, 03:54 AM
Engine tuning is not my strong suit at all. I started with FI and prefer to stay there. That being said, I'm trying to get my 85 C10 motivated again after sitting for a few years. It's a little bit Frankenstein as it has a TH400 leftover from it's BBC swap and the old 350 from my Impala.
Carb is an old 4 barrel from the Impala, no choke of any kind. Trouble I'm having is I can't get the engine started from cold at all without priming the carb with gas. It will start right up once it's warm.
Also, I need to work up a throttle linkage with a kick down switch for the TH400 (was apparently never there).
The truck is worth bringing back - no rust anywhere and the bed has no dents at all. Should I just ditch the carb I have and start fresh with something that has an electric choke?
raustinss
03-15-2021, 08:05 AM
My 2 cents yes ... just get a new carb with electric choke
Rick Dorion
03-16-2021, 09:05 AM
Does the accelerator pump work?
JustJohn
03-16-2021, 11:51 AM
Possibly not. It's clearly an old carburetor and hasn't been rebuilt since before I got it > 10 years, plus it sat idle for another 3.
It also makes squeaky sounds when I rotate the throttle lever.
I opted to go ahead and order a new Holley 4 barrel (with a choke) and just be done with that part of it. Hopefully that'll get me on to the next phase - street legal.
Rick Dorion
03-18-2021, 04:47 AM
I too want to go FI. Having said that, I put a 650DP on my 5.3 and am feeding my OCD with an AFR gauge and lot's of tuning!
Timmah
03-18-2021, 07:22 AM
The 400 kick down switch would mount on the gas pedal under the dash. Your 1985 C 10 should have provision to mount it.
186036
JustJohn
03-22-2021, 04:43 AM
That's new to me and different from what I've been seeing. I was planning to use a switch up with the carb linkage.
Found it online with minimal searching. Amazing how knowing what something's called makes it easy to locate.
186036
MonzaRacer
12-26-2021, 03:41 AM
What carb? qjets accel pump die easy death but can be bought from NAPA separate BUT best path is 2-3 cans Berryman cleaner, pop tp and base.
jb weld jet well pligs and icle passage plugs, replace base to body gasket.
Inside find accel pump check, some are under a flathead screw. clean and make sure its free. spray through jets, idle mixture screw holes and main jets. make sure metering rods are installed properly.
Also some qjets have adjustable primary metering rods, makes dialing in carbs fun.
On a Holley pop squirter off, tip over and see if check falls out, if not its stuck,stick small pick or screw driver in and get it loose. if lucky its pointed brass check. Spray channel out. double check accel pump diaphragm. Newer Holley use rubber checks in float bowl but hopefully The old carb IS old, and has steel ball check. if holley adding pv blow out preventer check valve is good plan,especially if it has no choke. and usung 3-5 rated pv or lower helps cold starts and rarely causes any issues.
