View Full Version : 67 camaro Carburetion questions.
67_camaro
08-23-2014, 02:14 PM
I have a 67 camaro with 396 aggressive cam, should I go 750 vacuum secondary or 750 double pumper holly???
Shaker455
08-24-2014, 03:43 AM
What intake are you running?
whatever you get go for a 4-corner idle
67_camaro
08-24-2014, 03:08 PM
Edelbrock Air Gap
juggernaut
08-24-2014, 06:08 PM
I'm running a Quick Fuel 850 vacuum secondary on a 496. Dyno'd @ 625 hp. I swapped from a mechanical secondary 850 for more drivability. I find a slight highway cruising advantage because the vac secondary offers an adjustable "delay" before power comes in. I find I can more easily feather the gas in high gear and in theory gain a little fuel mileage. On the flip side, when I punch it, The power comes in like a Two-stroke. The difference isn't worth going buy a new carb if you already have a mechanical.
hipockets
04-16-2015, 04:17 PM
What gears and rear tire size? What trans, and if an auto, what stall speed?
The rule of thumb is if a light car/higher than stock stall or std/low gear ratio, then double pumper
If heavy car/factory stall auto/tall gear ratio, then vacuum secondary.
In any case a 750 for sure, and I would lean towards the street HP Holley, or an AED 750 HO.
