Restomod Z28
10-14-2010, 05:25 AM
I've had an off-idle stutter in my 10:1 383 SBC that has been present since I built the engine. I've tried tuning it out with timing, I've tried covering the "lean" spot with richer primaries (and pump shot and PV), and I've tried many combinations of both timing and fuel curve. While I have minimized it, still, my stutter remains. My wideband O2 will go from lean, to rich as this occurs.
I notice it occurring under slight load (going up a hill) when cruising between 2k and 2.4k RPM's. Once engine speed picks up, it is fine. I have a 230° @ 0.05" cam. Edelbrock RPM heads (70cc), RPM intake with the plenum divider notched in the middle, 1" open phenolic spacer, Holley 650HP carb, MSD pro billet distributor (18° initial, 18° mechanical in by 3k, 10° vacuum advance on manifold vacuum), Tremec TKO, and 3.73's. I've tried several carbs & an HEI setup and it still has the same problem.
I'll add that the vacuum is good - 13.5" at idle, 21" at cruise. I do notice that under light acceleration, the vacuum reading steadily & rapidly fluctuates +/- 1" of vacuum - which I'm thinking is the reversion. I just ordered a 1", 4-hole, spacer to replace my open spacer with the hope of boosting the signal over the boosters at low RPM's...
Short of putting in a cam with less overlap, is there a better solution? Any other ideas, or is a different spacer my only other hope?
EDIT: I should note that I'm running 1 5/8" primary headers, 2.5" exhaust w/ h-pipe, chambered mufflers out the rear...
