View Full Version : Which Mechanical fuel pump?
obengston
11-10-2010, 01:31 PM
I have a SBC 383 pushing over 500hp to the flywheel. I'm currently in the process of rebuilding the engine (ported my heads/new cam (solid roller) ect.. Well I was wanting to uprgrade my mechanical fuel pump to a better one. I don't want to go electric (yet). But was thinking of the following 2. I think the 110 GPH would be good. I like the 170 GPH but don't want to have to change over to AN fittings right now (both don't need regulators, which again I don't want to add. What are your thoughts? or is there a different one that might fit the bill. Again looking to stay away from regulators right now and electric. I will add nos in the near future.
1. http://www.summitracing.com/parts/HLY-12-327-25
2. http://www.summitracing.com/parts/HLY-12-327-11
the 79 dollar one is just fine
FULMNTE
11-10-2010, 05:13 PM
I run an Edelbrock Performer RPM on a supercharged BBC for a few years now without any problems....
wmhjr
11-10-2010, 05:14 PM
I give big kudos to RobbMC. Absolutely top notch product, workmanship and service after the sale.
550hp SBC? http://www.robbmcperformance.com/products/chevy550.html
Only problem is that for some reason it says they don't fit 1st gen Camaros?
obengston
11-11-2010, 05:29 AM
Checked the one out, I quess it would hit the sub-frame on the 1st gen is my only guess. I'm still deciding. Maybe just go with a electric. How do I determine what size my hard fuel line is right now?? Would I measure the OD of the line??
obengston
11-11-2010, 05:39 AM
Just measured the OD it was 0.387, so whats that equal.??Is it 6-an or 8??
wmhjr
11-11-2010, 09:53 AM
3/8" line. -6.
Northeast Rod Run
11-11-2010, 03:17 PM
Checked the one out, I quess it would hit the sub-frame on the 1st gen is my only guess. I'm still deciding. Maybe just go with a electric. How do I determine what size my hard fuel line is right now?? Would I measure the OD of the line??I'm in work so I can't open the link (firewall at work). Is it just the positioning of the fuel inlet/outlet that might get in the way of the frame?
The reason I sak is because I've used pumps before that wouldn't fit, but I was able to rotate the base and everything worked out fine
wmhjr
11-12-2010, 05:43 AM
My guess is that rotation of the body wouldn't solve it, as in the same listing that says '67-69 camaros won't fit, it also says the body can be rotated to any position. Maybe it's too deep?
