View Full Version : Aggravating Holley Leak!
Tom 72RS/SS
08-03-2014, 07:17 AM
A recent rebuild of the Holley 750 db for the wife's 68 Camaro SS has me frustrated to the point that I'm likely to order a new one from Jeg's today and be done. Motor is a sbc with a thumpin' cam, Brodix aluminum angle plug heads and incredible torque. The problem is after the rebuild, the mixture screws in the primary metering block are leaking! I have never seen anything like this in all the years I've worked on cars. Bought a set of the cork seals from Holley, installed (correctly), fire it up and although the engine is running great with excellent throttle response, begins to dribble out of the bleeder screw area (WTH). I have done this 4 times with same results!
As a last ditch effort I decided to ask for help as the local speed shop provided no solutions. So here I am guys, what can I do to resolve this issue or am I just going to call Jeg's for another 750 dp or possibly a 770 Street Avenger!
sam 74
08-03-2014, 03:28 PM
sounds like a metering block tolerance issue, did you happen to try the rubber gaskets yet, they may seal better than the cork.
Tom 72RS/SS
08-03-2014, 07:22 PM
Only been able to find the cork one's. Even Holley's website lists them as only option. Seems like a poor choice for sealing fuel!
Shaker455
08-04-2014, 01:13 PM
Tom,
Did they sand blast the carb?
Jeff
Red67Mustang
08-04-2014, 04:39 PM
Sounds like your throttle plates are open too far, removing vacuum from the idle circuit. You'll know this is the case if you can close both idle screws and the car still runs.
Nothing should drip from the idle mixture screws; they are supposed to be exposed to engine vacuum - something to check.
http://i1207.photobucket.com/albums/bb476/waynep712/waynep712%20carb%20album/holley_atIDLE_zpsbdbaea76.jpg
Red67Mustang
08-04-2014, 04:41 PM
Not my pics by the way... Credit to the guy why posted them. I just found them via google to try and offer assistance.
sam 74
08-07-2014, 02:21 PM
Tom the rubber gaskets may have been from a Barry Grant kit. checking your throttle plates might give you an idea whats going, i've never had a carb leak out of the adjuster screws before. if it were my carb i'd remove it from the engine and start tearing it down and check all the internal gaskets to make sure a wrong gasket didn't get installed by mistake. i'd also look for cracks in the main body and metering blocks just to be safe.
MonzaRacer
08-07-2014, 03:14 PM
Does it have 2 metering blocks? Get front and back swapped?
Somethings is odd. Most good Oreilly has metering block gaskets, I havent seen much cork on any holley for years, butthen most I have seen have been newer ones people have all messed up and I just have to get back in adjustment. Only way fuel would drip from idle mixture screw would be if it saw fuel pressure as all I have see the mixture screw seals for was to keep needle from moving not sealing in or out much more than dirt.
MonzaRacer
08-07-2014, 03:16 PM
Now if your taling sight adjustment hole that means floats are too high/stuck. maybe few quick pictures pointing too affected areas.
Tom 72RS/SS
08-07-2014, 04:33 PM
I'm going to tear it down this weekend and see if something is a miss.
