View Full Version : The LSX Forum
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13
  1. Need help with my LS376/480 project! (6 replies)
  2. E-Rod LS3 Emissions Question (0 replies)
  3. Coil fitment with Holley LS tall valve covers (4 replies)
  4. Good place to buy drop out engine? (1 replies)
  5. opinions on a LS flash programmer (0 replies)
  6. mast motor questions!! (1 replies)
  7. Ls3/6L80e into a 1979 or 1968 camaro. (5 replies)
  8. LH6 & LM7 Interchangability (0 replies)
  9. Wiring... for the entire car in one shot (?) (10 replies)
  10. Anyone running Holley Terminator TBI on an LS yet? (0 replies)
  11. Comp cam ? (4 replies)
  12. Crate LS3 options (11 replies)
  13. Advice please (2 replies)
  14. Trans temp sender Moved to trans setion (0 replies)
  15. Power steering cooler and engine oil cooler sizing (9 replies)
  16. Need swivel or down facing Thermostat housing for LSA. (7 replies)
  17. LT4 Supercharged Crate Engines Now Available (66 replies)
  18. MAST Motorsports ECU situation (9 replies)
  19. IROC Box with LQ4 Swap in 69 Camaro (2 replies)
  20. LS 71 chevelle swap, input needed (2 replies)
  21. Roto-Fab LS1 LS2 LS3 goodies (0 replies)
  22. HP Tuners file needed (1 replies)
  23. LSX 454 throttle body touching the water pump (4 replies)
  24. gpmm ls3 controller help (63 replies)
  25. LS engine does not fit in 1969 Nova (3 replies)
  26. fuel system help for boosted L92? (4 replies)
  27. New custom welded CAI ... Titanium (2 replies)
  28. LS3, GMPP harness fly by wire pedal swap (7 replies)
  29. LSX 454, 2inch or 1&7/8 headers (2 replies)
  30. LSA supercharger on l92 (19 replies)
  31. A body, center the engine/ trans in the frame rails, or trans tunnel? (14 replies)
  32. C7 LT1 Engine 69 Camaro (22 replies)
  33. Fuel Pressure (3 replies)
  34. 1981 Trans Am LS1 swap / donor car (3 replies)
  35. best LSX 454 wet sump oil pan??? (9 replies)
  36. siphon fuel pump (0 replies)
  37. Best oil pan for lex 454 in 67 camaro (2 replies)
  38. ls3 swap in 69 camaro (1 replies)
  39. drive by wire or cable throttle on LSX454 with Jenvey cross ram (15 replies)
  40. Ls1 in 65 GTO clutch pedal rod (4 replies)
  41. stack style intake manifold, which one works the best? (1 replies)
  42. Low Fuel pressure external electric fuel pump help! (1 replies)
  43. adjusting LS3 idle speed (7 replies)
  44. Built LS3 - use Warren PCM & cable throttle or DBW setup?? (1 replies)
  45. Priming dry sumped ls3 (14 replies)
  46. LSx Swap pitfalls (16 replies)
  47. Stalling When Hot (0 replies)
  48. LQ4 starting issues in donor vehicle (1 replies)
  49. ls9 dry sump (12 replies)
  50. Which brake pedal to use with 1967 camaro LS t56 swap? (3 replies)
  51. MAF cause engine to not start? (7 replies)
  52. LS swap 68-72 GM A body. radiator hose help (2 replies)
  53. LS3 vs LSX vs Pontiac motor swap ? (8 replies)
  54. Need some help.. (5 replies)
  55. Need HP Tuners help (5 replies)
  56. 15' "LT-1" vs "LSx" swap... (17 replies)
  57. throttle cable for 69 camaro with ls1 (2 replies)
  58. 5.3 LS1 swap 2nd gen Camaro (0 replies)
  59. CHE Bushed Rocker Arms (0 replies)
  60. People with running LS3/525HP swaps...come on in... (7 replies)
  61. 67 Camaro Best fit Intercooler LS SWAP Turbo (3 replies)
  62. Is this going to melt? (4 replies)
  63. chevelle LS swap questions (5 replies)
  64. Thoughts on 8000 RPM LS build article in HOT ROD online? (2 replies)
  65. Knock sensor (6 replies)
  66. sstb ls2 intake clearance (9 replies)
  67. LS swap into '94 Trans-AM (6 replies)
  68. LS headers for 2nd gen Firebird (1 replies)
  69. Steering box options with an LS swap. (10 replies)
  70. Idiot Lights (6 replies)
  71. LS Vintage Air Power Steering Pump (2 replies)
  72. 67-69 Camaro header question with 6 bolt heads? (6 replies)
  73. vacuum line routing LS2 (4 replies)
  74. LS3 and Vintage air (4 replies)
  75. LS in 66 mustang coupe (1 replies)
  76. 76mm turbo lq4 69 Camaro (8 replies)
  77. Lsx 454r (13 replies)
  78. Ls motor mounts that dont vibrate (18 replies)
  79. Fuel line question (1 replies)
  80. Need HELP IAT wiring (4 replies)
  81. Help me build my 5.3 Vortec (12 replies)
  82. Ls2 question (3 replies)
  83. Will stock exhaust manifolds work, ls3/camaro (10 replies)
  84. Mast LS7 SS 675hp Aggressive Street Usage? (11 replies)
  85. LSA supercharger: Put it on a stroker LS3 or a stroker LS2 (5 replies)
  86. LS bracket question (18 replies)
  87. Anyone use 98-02 LS1 radiator in 1st gen swap (8 replies)
  88. ls3 water pump (3 replies)
  89. 5.3 Vortec price question (5 replies)
  90. Auto trans wont shift after ls1 install (5 replies)
  91. Coil covers (2 replies)
  92. 68 Firebird/LS2/TKO 600/ engine mounts on stock subframe (26 replies)
  93. Dakota Digital Water Temp Sender (4 replies)
  94. Spanky's Rod Shop LS3 Cruise Control (8 replies)
  95. Project Dirty Bird (1 replies)
  96. LS7 in a 66 chevelle. Modifying the crossmember... (10 replies)
  97. holley ls trans cross member (1 replies)
  98. ls3 vs ls7 (17 replies)
  99. LS Pedal Assembly (3 replies)
  100. Thickness of Speedtech/ATS adapter plates? (1 replies)
  101. 69 Camaro Ls3/ subframe swap question (3 replies)
  102. Looking for tuner in southern Wisconsin or northern Illinois (11 replies)
  103. l92 injectors fit ls3 intake. (1 replies)
  104. LS Oil pans for 4" + sized crank shafts (5 replies)
  105. LS3 Engine doesnt start after sitting (8 replies)
  106. 2014 Camaro SS swap into 1968 camaro (3 replies)
  107. ls7 fuel filter/regulator location ? (5 replies)
  108. GM Performance LS3 ERod P2135 code won't run (1 replies)
  109. Autokraft Oil Pan Dealers (4 replies)
  110. Entropy Radiators now available from MCB! (1 replies)
  111. cam swap (0 replies)
  112. First gen f body, what motor plates w/ stock oil pan (11 replies)
  113. 5.3L turbo/zor 6.2L all engine (6 replies)
  114. LS swaps in Bay Area/Nor Cal? (1 replies)
  115. LS1 fuel injection vs carb? (8 replies)
  116. LS7 Card style MAF placement (10 replies)
  117. LS2 / L3 heads comp cam. DOD question (7 replies)
  118. Solid Engine mounts for Lq4 engine (2 replies)
  119. clutch? (2 replies)
  120. holley harness and painless universal harness wiring question (9 replies)
  121. Accessory drive for LS motors (cost effective) (15 replies)
  122. Valley pan question (1 replies)
  123. LS7 Hard Start (3 replies)
  124. Ricks (Resto Mod) new EFI fuel tank (6 replies)
  125. x pipe for ls7 in second gen camaro (1 replies)
  126. LS3 fuel rail removal (4 replies)
  127. ZL1/LSA Info needed (3 replies)
  128. Speed master starter (1 replies)
  129. need cam help LS 444cid build (0 replies)
  130. LS3 with no throttle response (8 replies)
  131. '71 Chevelle LS3 Header advice!!! Please (7 replies)
  132. Smaller p/s pulley Holley accessory drive, headers ls 71 nova (11 replies)
  133. IN STOCK! Rick's Stamped Steel 67-69 Camaro / 68-74 Nova EFI Gas Tanks (4 replies)
  134. E-Force LS7 Dyno run & Final Numbers (1 replies)
  135. 2nd Gen Camaro LS Build (3 replies)
  136. fuel line ? size and material suggestions? ls7 (24 replies)
  137. 1986 Elcamino 480HP LS looking for the best solution for front accessory (6 replies)
  138. which headers fit (5 replies)
  139. Any GMPP reps on here (13 replies)
  140. victor junior on 69 camaro (0 replies)
  141. 5.3 ls with 76mm turbo? (11 replies)
  142. Another 5.3 LS build, most cost effective route doable (4 replies)
  143. LQ4 build help, the stupid little stuff (1 replies)
  144. LS Block AN adaptor? (9 replies)
  145. corvette accessories (3 replies)
  146. NEW! 69 Camaro Stamped Steel Gas Tank with Notched corners + Powder Coated! Mini-Tub (1 replies)
  147. Ls3 upgrades (4 replies)
  148. Why doesn't anyone make complete LS swap packages? (28 replies)
  149. LS2 swap question (14 replies)
  150. engine question (9 replies)
  151. LS3 with a 4L65e (10 replies)
  152. headers for 69 camaro (9 replies)
  153. a little advice? (0 replies)
  154. Alternator low mount… Pass side A-body (3 replies)
  155. motor mount problems (1 replies)
  156. Carburated LS1 PCV System/ Catch Can set up need help (12 replies)
  157. lsx fuel lines in 1971 camaro (2 replies)
  158. ls6 intake on a ls2 (15 replies)
  159. First Gen Camaro; What stock oil pans will fit and with what engine mounts?? (14 replies)
  160. Choosing the right LS3 crate (14 replies)
  161. Cunifer for LS steam venting (2 replies)
  162. 04 CTSV pull out into 68 Chevelle (0 replies)
  163. LS2 Help (21 replies)
  164. Wegner or Vintage Air (2 replies)
  165. first gen fbody pedals (2 replies)
  166. Holley oil pan and accessory drive kit review (4 replies)
  167. 67 Camaro SS LS6 4L60E shifting issue (0 replies)
  168. best place to pick up a complete ls motor and trans for a 72' c10 (2 replies)
  169. Gm connect and cruise ls3 combo (4 replies)
  170. LS3 Wiring Harness, PCM, TCM (5 replies)
  171. L92 question (5 replies)
  172. modifications to change 241 heads to 243? (7 replies)
  173. LS7 cable throttle body (9 replies)
  174. cam ? (6 replies)
  175. LSA Cold Air Intake (21 replies)
  176. Coil relocation. Post a pic of where your hiding yours and the end result. (11 replies)
  177. Holley mounts (9 replies)
  178. 2006 LS2 24x vs 58x reluctor (3 replies)
  179. Ls2 gas pedal (7 replies)
  180. ls2 headers (1 replies)
  181. Ls2 harness Howell EFI? (3 replies)
  182. BRP LS Mounts (12 replies)
  183. Gauges for a LS (14 replies)
  184. Thinking about an LS3.... (23 replies)
  185. Chassis works motor mounts (2 replies)
  186. 1969 firebird LS1 swap Header experience/advice with hooker mounts & stock steering (14 replies)
  187. Boost capabilities. (5 replies)
  188. What car/truck to look for at the junk yard? (5 replies)
  189. 2010 LS3/T56 pullout in 2nd gen. (5 replies)
  190. Ls3/525 (3 replies)
  191. 1968 Firebird/2005 GTO LS2 accessory drive question (4 replies)
  192. ls acessory drive (1 replies)
  193. Chevelle LS1 Motor Mount/ Oil Pan/ Spacer Problem. (19 replies)
  194. L99 vs LS3 (7 replies)
  195. LS2 / LS3 / LS6 oil level sensor issues (1 replies)
  196. clear ls3 valve cover help?!!!! (7 replies)
  197. New 2" LS headers! (1 replies)
  198. Need help on PTV clearnce issue- 402 LS2 (4 replies)
  199. Out with the OLD and in with the NEW .. (7 replies)
  200. Where to start ?? (1 replies)
  201. LT1 Crate Engines Now Available (22 replies)
  202. oem wiring and pcm or holley set up? (5 replies)
  203. Swapping from DBW to Cable (11 replies)
  204. need help/information from others thwt used brphotrods ls swap kit (7 replies)
  205. helping finding some ls3 valve covers? (4 replies)
  206. ls7 reliabliltiy (10 replies)
  207. LSX source in SoCal? (5 replies)
  208. Best bang for your buck LQ4/9 408 crate engine (4 replies)
  209. 68 camaro lq9 help (2 replies)
  210. VSS and Reverse lockout silenoid wiring t56 (29 replies)
  211. Need a good reference source for LS Swaps (12 replies)
  212. info please (10 replies)
  213. DBW throttle body (4 replies)
  214. Powdercoating Block (5 replies)
  215. Video of my LS3 swapped RX-7 (3 replies)
  216. Carburated LS3 VS EFI LS3 (10 replies)
  217. Feed fitting for corvette power steering pump. (8 replies)
  218. 2002 Corvette Z06 (3 replies)
  219. Newbie: 5.3 supercharger retro swap questions (9 replies)
  220. Carburated LS3 376ci/515HP Engine (3 replies)
  221. LS3/LS7 engines weights (2 replies)
  222. LS7 throttle body/harness/cam and more (27 replies)
  223. any use these engine mounts? (11 replies)
  224. Big bore build 440CI (17 replies)
  225. Change simple settings without expensive software or tuner? (5 replies)
  226. ls carb vs efi? (14 replies)
  227. LS3 compatibility (2 replies)
  228. LS/4L80e in a 71 Firebird (2 replies)
  229. Holley 550-603 ls2 ecu and harness kit? or standalone harness with e67 ecu? (6 replies)
  230. Ls2 with ls3 heads and intake... What throttle body (8 replies)
  231. anyone use pacific fabrication ls2 engine (1 replies)
  232. LS3 Swap / Upgrade (4 replies)
  233. LS7 install help please (7 replies)
  234. Cam sensor HELP please (5 replies)
  235. 68 camaro with LS. Oil pan change out. (5 replies)
  236. LS 427 inline fuel pump (6 replies)
  237. Turn Key Engine Supply? (1 replies)
  238. Its in!!! Its in!!! (7 replies)
  239. Which wet sump Ls conversion pan is best for road racing? (15 replies)
  240. LS 1/2/6 intake (0 replies)
  241. Best way to increase LS1 horsepowers (12 replies)
  242. anyone have pics of new holley pan on gm A-body? (6 replies)
  243. Sroked LS1 or LS3 ? (0 replies)
  244. LS1 low oil pressure damage? (4 replies)
  245. LSA Performance upgrades (38 replies)
  246. Engine Alignment issues with BRP mounts on 2nd Gen firebird (6 replies)
  247. Wiring Harness Rework companies (10 replies)
  248. LS2 mileage (2 replies)
  249. IM taking the leap! (3 replies)
  250. Chassis Dyno Numbers (2 replies)
