Schwartz Performance
12-06-2014, 10:32 AM
The new LT1's are now available!
https://static1.pt-content.com/images/pt/2014/12/15773448700_0b76c83dbe-1.jpg
Your price from Schwartz Performance:
Wet sump: $8700 & FREE SHIPPING to the 48 states! (PN 19328728)
Dry sump: $8900 & FREE SHIPPING to the 48 states! (PN 19329997)
Specs for LT1 crate engine:
Power: 460 HP @ 6000 RPM, 465 ft. lbs. of torque @ 4600 RPM
Displacement: 376 CID, 6.2L
Bore x Stroke: 4.065” x 3.622”
Compression Ratio: 11.5:1
Recommended Fuel: 92 Octane
Block: Cast Aluminum with 6 bolt cross bolted main caps
Crankshaft: 8-bolt Forged Steel
Connecting Rods: Forged Powdered Metal Steel
Pistons: Hypereutectic Aluminum
Camshaft: Billet Steel Hydraulic Roller Tappet
Cam Lift: .561” Intake / .531” exhaust
Cam Duration @ .050”: 242 deg. Intake / 244 deg. Exhaust
Lobe Separation: N/A
Cylinder Heads: Aluminum Rectangular Port, Direct Injected
Combustion Chamber: 59cc
Valves: 2.165” Intake/ 1.590” Exhaust
Rocker Arms: Cast Roller Trunnion, 1.81:1 Ratio
Balance: Internal
Reluctor: 58X
Maximum GM Recommended RPM: 6600
Engine Includes:
• Fully GM assembled long block
• Ignition Coils, Plug Wires and Spark Plugs
• Oil pump, pick-up and oil pan (dry sump or wet sump)
• Exhaust Manifolds
• Intake, Injectors and Throttle Body
• High Pressure Fuel Pump (installed under intake)
• 14” Auto Trans Flexplate (11.063 tc pattern, 8-bolt crank)
• Harmonic Balancer
• Front timing cover
• Aluminum Water Pump
• Oil Filter
• Passenger Side RH Oil Dipstick and Tube
• Warranty:General Motors limited 2 year / 50,000 mile parts & labor warranty
These engines are a bit different than the LS.
-Engine mount pattern is different
-Header flange pattern & tube spacing is different.
These are what come on the LT1 crate:
https://static1.pt-content.com/images/pt/2014/12/21687627113_6b32212ebf_n-1.jpg
And these are a potentially more swap-friendly truck manifold:
https://static1.pt-content.com/images/pt/2014/12/22319255581_a25716a6e3_n-1.jpg
-The new C7 has electric steering so no hydraulic power steering pump is available yet. Street & Performance has a serpentine drive with an aftermarket Sanden AC compressor, about $1900 for the kit.
The GM serpentine kit with AC and alternator only is part number 19329990.
-LT1/4's have an 8-bolt crankshaft pattern, which is the same pattern as the LSA. The clutch/flywheel kits for the LSA fit the LT1/4.
-The bell housing pattern is just about identical.. But the top bolt is in a different location. The new 4L65/70 E's that come in the connect & cruise kits for these engines have an extra hole to bolt to them. See picture below. At this time we're unsure how different the 4L80E will fit.
https://static1.pt-content.com/images/pt/2014/12/22120679940_2d8744fec6_n-1.jpg
-The GM steel bell housing for T56's has the hole in the right spot, and is large to accept their clutch kit.
-There are TWO different oil pans - dry sump & wet sump. The dry sump has a shorter (front to back) sump. Wet sump oil pans may require notching. Don't worry, there's plenty of room in the front of the sump to make that happen.
Wet sump:
https://static1.pt-content.com/images/pt/2014/12/21685946764_d79c12740c_n-1.jpg
https://static1.pt-content.com/images/pt/2014/12/22319264121_d25f9c1279_n-1.jpg
https://static1.pt-content.com/images/pt/2014/12/22282639766_6ca00f207f_n-1.jpg
Note these oil pans have no gasket.. Just RTV! And they're pretty heavy....
-The T56 Super Magnum that GM released is the same as the Magnum dimensionally, but the shifter is different, and there is a 40-tooth reluctor for the speed sensor, which is only required for the E-Rod systems. It's also a close-ratio setup.
We'll update this thread with more details as they come available! If anyone has any more knowledge on these, feel free to post a reply- we all have room to learn about these Gen 5's :)
-Dale
Balance: Internal
Reluctor: 58X
Engine Includes:
• Exhaust Manifolds
• Harmonic Balancer
• Oil Filter
Wet sump:
-Dale
