View Full Version : Carburated LS3 VS EFI LS3
NightRider12
10-23-2014, 01:43 AM
What do you think about ?
davidomilligan
10-24-2014, 09:33 AM
https://www.pro-touring.com/threads/110901-ls-carb-vs-efi
davidomilligan
no real answer just whatever you want to do but thats the link to recent forum
130fe
10-24-2014, 11:10 AM
Post 3 on that link says it all. Nothing wrong with what ever way you go, just depends on what your needs are. I have had EFI in my car since 2000 and don't miss the carb at all.
davidomilligan
10-24-2014, 12:57 PM
if you dont mind tweaking your carb for temp and altitude go with the carb. efi just tweaks if for you. pretty much all there is too it
badazz81z28
10-24-2014, 07:19 PM
If you had the option to go FI, why not? There is nothing nicer than having your car start-up and run like a modern car.
I don't recall the last time I flooded my car, died under hard breaking, or complained about the crisp throttle response. ;)
Don't go carb unless you have a legitimate reason.
alocker
10-25-2014, 04:27 AM
A well tuned carb can be very drive-able and reliable. I have found since going back to a carb, I don't like the pedal feel of getting into the secondaries. The power is difficult to modulate once you get into them, kinda like an on-off switch.
dirty rick
10-25-2014, 07:52 AM
No matter how well tuned a carb is, you won't be able to reach through the window and start it! (even cold!!!!)
69L48Z27
11-01-2014, 04:24 PM
I just got my LS3 project done, EFI. The only way I'm ever going to use a carb again is if the car is original and came with it. No way I would use a carb on one of these.
Just my 2 cents.
NightRider12
11-04-2014, 12:33 PM
Thank You for the help guys !
Another question:
For swapping my LT1 to a LS3 what I have to change ?
I think motor mounts and headers, about the clutch I can reuse the same ?
I have a Tremec T56 six speed installed on my car
71maroesteban
11-04-2014, 03:05 PM
Another question:
I have a Tremec T56 six speed installed on my car if it's a lt1 t56 your going to have to change the faceplate and input shaft to a ls style and I don't believe the clutch will work
