View Full Version : DBW throttle body
mattdirocz
10-31-2014, 12:57 AM
OK this something I have been searching for a while and can't find an answer too. I have an 03 truck harness and I have a cheap pro comp intake I want to use on my 5.3. The intake is 4 bolt are there any throttle bodies out there I can use. I can only find one that is an 8 pin setup, it is off a earlier gxp. I just want to know if my harness and pedal will support it or if I will end up having issues with it only opening 90% like I have read in other forums. It appears from my research that that issue only occurs when trying to convert from the 8 pin to the 6 pin plug. Thanks for your help. Matt
garys 68
11-01-2014, 05:02 AM
Simplest solution, 3 to 4 bolt adapter:
http://www.ebay.com/itm/New-76-102mm-3-4-Bolt-suits-HSV-LS2-LS1-VE-VZ-V8-LS1-LS2-Throttle-Body-Adaptor-/111457374107?pt=Motors_Car_Truck_Parts_Accessories&hash=item19f3608f9b&vxp=mtr
mattdirocz
11-01-2014, 05:57 PM
I need an adapter to go from 4 bolt to 3 bolt then
csouth
11-01-2014, 08:35 PM
If you need 4 bolt intake to 3 bolt TB, here you go.
http://www.ebay.com/itm/USA-Made-LS1-throttle-body-to-LS2-Intake-Manifold-Billet-Aluminum-Adapter-LSX-/271609298094?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f3d2cfcae&vxp=mtr
mattdirocz
11-01-2014, 08:58 PM
Well thank you that is what I need guess I was using the wrong wording on ebay to find.
