View Full Version : Swapping from DBW to Cable
firebirdzig
12-03-2014, 04:51 PM
I'm buying and LS3 that's coming with the ECU and all accessories ect... I was wondering if the computer can be flashed to be run w/o the DBW and use a cable throttle body.
csouth
12-03-2014, 06:49 PM
LS3 is 58x reluctor crankshaft motor. You would need to convert it to 24x to run DBC and run LS1 style PCM. Lingenfelter makes a converter box for such a conversion.
http://www.lingenfelter.com/mm5/merchant.mvc?Screen=PROD&Store_Code=LPE&Product_Code=L460065397&Category_Code=E1#.VH_LmjHF-So
andrewb70
12-03-2014, 07:44 PM
As was said, it isn't easy, and more importantly, why would you want to? The DBW set-up works awesome.
firebirdzig
12-03-2014, 09:12 PM
Thanks for the info. Will a stand alone harness and ECU from an LS2 be plug and play with an LS3?
garys 68
12-04-2014, 06:26 AM
Around 05-06 I think there were 24 and 58x reluctor LS2s in Vettes/GTOs. So maybe.
If your goal is to find a 58x ecu with IAC driver to use cable TB, that will be a very rare animal.
andrewb70
12-04-2014, 07:30 AM
It's as rare as a unicorn.
csouth
12-04-2014, 07:35 AM
^^^^ This.... Are you just assuming better throttle response with DBC? If you have the harness and PCM, you're 80% there. Just get the pedal, have your harness rewired and PCM programmed.
garys 68
12-04-2014, 12:24 PM
I was thinking Jackalope....
David LaBuda
12-05-2014, 06:25 PM
I'm happy with the drive by wire in my Sierra. I actually have a DBW setup to swap into the Chevelle. DBW gives a cleaner engine bay, less holes in the firewall, and allows you to run cruise control very easily. It's a win win win!
130fe
12-06-2014, 05:37 AM
David, are you running cruise on your current setup?
David LaBuda
12-08-2014, 09:42 AM
Not with the cable setup. I'll add a cruise control switch when I install the DBW computer/throttle body.
firebirdzig
12-08-2014, 01:48 PM
Thanks for the help guys!
