View Full Version : Disc Brakes
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18]
19
- Brake donor (2 replies)
- C5 brackets (5 replies)
- lt1 or ls1 rear disc (2 replies)
- 4th gen rear adjustment? (0 replies)
- offset on 12-bolt (0 replies)
- C4 or C5 Conversion (20 replies)
- 4th gen LS1 rear disc to early f-body swap........anyone pull it off yet? (7 replies)
- c4 conversion master cylinder on a 69 camaro (5 replies)
- Another ls1 question. (1 replies)
- wilwood master (0 replies)
- who has completed the 1st gen to LS1 front brake swap? need help and parts (6 replies)
- brake booster (3 replies)
- C5 vs. LS1 rear components (9 replies)
- Bear Brakes (16 replies)
- New CPP Master Clylinder (7 replies)
- Does anyone understand Master Clyinders??? (11 replies)
- 4 wheel disc setup (5 replies)
- 2nd gen cbb (0 replies)
- power or manual set up with wilwoods?? (9 replies)
- Stock 68 4 piston caliper (7 replies)
- best brake pad material (5 replies)
- disc brake spindle and 4th gen brakes (1 replies)
- corvette spindle (1 replies)
- Caliper adaptor bracket for LS1 and C4 13" the same? (9 replies)
- Need some newb advice on an unusual combo (2 replies)
- 70s vette 12'' rotor offset (5 replies)
- Disk brake conversion (1 replies)
- Brake conversion question (2 replies)
- Painted Rotors - the wheel to rotor mating surface - bad idea? (4 replies)
- c-5 fronts what ars they worth? (9 replies)
- C5 rear information (6 replies)
- Baer brake kit for Mopar (6 replies)
- Power to manual conversion - Does adpater plate affect pushrod length? (1 replies)
- LS1 Brakes 12" rotor? (6 replies)
- rotor question (1 replies)
- g-body/s-10 front pad upgrade (1 replies)
- Soft brake pedal problem - new 4-wheel manual discs (27 replies)
- dynalite brake pads (2 replies)
- Baer Brakes Price??????????? (9 replies)
- Baer has a new site (0 replies)
- caliper bore size ? (1 replies)
- Wilwoods on the way from Precision Brakes (3 replies)
- best prices on c5 calipers (4 replies)
- Which master cylinder (3 replies)
- LS1 to drum spindle bracket (6 replies)
- C4 caliper to abutement bracket (1 replies)
- C3 master cylinder hookup (3 replies)
- New "Big Brake" kits from OPG - any info? (0 replies)
- Disc brakes on 9" in 69 Camaro? (8 replies)
- SSBC or Baer for my 55 ? (15 replies)
- LT1 or LS1 brakes... (7 replies)
- 93 camaro front brakes on a 67 (0 replies)
- Need help with Corvette IRS (1 replies)
- Porsche Brake Conversion (1 replies)
- adjusting rear brake bias (1 replies)
- Whats the best way to go about big brakes ??? (5 replies)
- What to use? (6 replies)
- Wilwood brake help (2 replies)
- Braided lines LS1 calipers and first gen (5 replies)
- baers on 12 bolt rear (8 replies)
- Brake Booster action (2 replies)
- big brake and rear disc upgrade (2 replies)
- Yet another 2nd Gen Camaro, "TorkersCamaro" C4 rear brake ? (6 replies)
- 4th gen rears done but ? (4 replies)
- brake pedal stays down? (3 replies)
- 69 Camaro Rear Disc's (4 replies)
- What setup to use with 15" rims (8 replies)
- brake comparo - what brands are good? (3 replies)
- Concerned about my new Wilwood's (7 replies)
- Rear stainless steel braided brake line - Flex hose (8 replies)
- SSBC rear discs for 2nd Gen Camaro (6 replies)
- 2nd thoughts on Baer brake system (4 replies)
- Power to Man. 79' Firebird (Help)? (2 replies)
- Parking Brake for Wilwood (11 replies)
- 2nd gen front discs on 68 GTO (4 replies)
- Braking questions (3 replies)
- which brake fluid? (2 replies)
- baer vs Wilwood (15 replies)
- LS1 Rear Discs on an A-Body (2 replies)
- Baer's new 6 piston caliper ? (40 replies)
- symptoms for too small master???? (0 replies)
- symptoms for too small master???? (1 replies)
- What manual master for LT1 rear disks in 2nd gen Camaro? (1 replies)
- Needing a Power Booster (5 replies)
- Permanently Mounted Brake Pressure Gauge (0 replies)
- Baer disc brake squeeking, how do you get rid of it? (7 replies)
- Wilwood master (0 replies)
- Wilwood vs. Baer (28 replies)
- need rotors for 7? trans am rear (2 replies)
- Cooling ducts for front discs (4 replies)
- Who are the best providers for Dana 60 Disc conversions (1 replies)
- Difference between LS1 calipers and C5 calipers? (10 replies)
- Brake Fluid question (0 replies)
- '64 Impala Disc/Drum MC Advice (2 replies)
- wheel stud lengths when changing to rear disks (9 replies)
- C5 Brake Adapters for 2nd Gen needed (16 replies)
- how do i switch from manual to power (6 replies)
- Another C5 Brake Question -Master Cylinder (0 replies)
- 12'' c4 brackets (0 replies)
- Which master cylinder? Pushrod length? (7 replies)
- 1st gen drum hub on 2nd gen spindle (3 replies)
- drum to disc conversion cheap!!! (1 replies)
- Rod between booster & master cyl (3 replies)
- C4 and/or C5 bearing pack dimensions (5 replies)
- rear axle hub diameter/C5 rotors (1 replies)
- m/c question (1 replies)
- disc brakes for 12 bolt (7 replies)
- C4 13" brackets (6 replies)
- Best front brake lines? (5 replies)
- Brake companant question, brass metering block? (19 replies)
- factory swap (6 replies)
- Long pedal with Cadillac callipers (2 replies)
- Need Help With G-Body (6 replies)
- brake question (0 replies)
- PBR cobra calipers = Baer pbr calipers????? (7 replies)
- Dust Caps (0 replies)
- swapable rear ends (3 replies)
- C5 Swap Master Cylinder Options - Manual vs Power (0 replies)
- Booster Big to Small (0 replies)
- C5 rear caliper questions (10 replies)
- S10 M/C Bleeding Tips? (45 replies)
- Looks like I may have a rear disc problem. (10 replies)
- Using Compression Fittings on Brake Lines (5 replies)
- Slotted rotor mounting ?? (5 replies)
- C5 to 1st Gen Swap Hub problem --- What's all the hubbub, bub? (4 replies)
- Question for Paul@Hydroboost (1 replies)
- Low Budget (5 replies)
- Holy Sh!^$*&^!!! (5 replies)
- Road race brakes, my plans (11 replies)
- Custom Wilwood Brakes (9 replies)
- Dirveshaft parking brake (7 replies)
- Wilwood rotors: cracked (7 replies)
- Road race brakes & future upgrades (11 replies)
- Baer Brakes prices (4 replies)
- rear disc caliper location (2 replies)
- baer trac question (3 replies)
- Looking for CBB for corvair (5 replies)
- C5 Brakes, Manual M/C, Pads? (19 replies)
- Best Baer Brake prices? (1 replies)
- Lincoln LSC 8.8 with discs, how wide?? (0 replies)
- LS1 Rear Brake Part Numbers (5 replies)
- 2nd Gen. Factory rear disc brakes (6 replies)
- 4th gen MC bore sizes? (1 replies)
- 69-82 Corvette (1 replies)
- Willwood Master cylinder (0 replies)
- ws6 ta brakes & mc choices (4 replies)
- rear disk brake offset on 69 (2 replies)
- will this Idea work??? (1 replies)
- Rear Disk brake brackets/baskets (8 replies)
- Baer 79 Firebird (0 replies)
- Caliper Finishes? (2 replies)
- Brake Booster? (0 replies)
- hydro boost questions (5 replies)
- Need Dimension Caliper/Caliper Bracket (3 replies)
- Wilwood Kit (0 replies)
- WS6 Brakes vs. LT1 brakes (10 replies)
- 4th gen Camaro master hook up (2 replies)
- parking brake clearance problem (2 replies)
- MC for C4 swap (7 replies)
- Master Cylinder questions, disc/drum, disc/disc. Pushrod? (2 replies)
- Affordable front and rear disk brakes for 69 Camaro? (12 replies)
- Backing Plate with Aftermarket Discs (3 replies)
- C4 calipers at Touring Classics (6 replies)
- what other drum hubs? (1 replies)
- Largest 12 bolt disc? (16 replies)
- Need Help with Front Disc Brake Kit for 17x8.5 Wheel (8 replies)
- erotorshop on ebay (1 replies)
- Aftermarket Direct Replacement Calipers 67 Camaro (3 replies)
- Rear Disk for 77 Trans-am (4 replies)
- #5460346 Master Cylinder (0 replies)
- Need advice on brake purchase (1 replies)
- Dropped A-Body Disk Brake Conversion (3 replies)
- 4th gen camaro mc throw? (0 replies)
- Booster Confusion! (0 replies)
- C5 brake brackets, where??? (16 replies)
- Beating a dead horse. (0 replies)
- 4th gen master on 2nd gen F-body (4 replies)
- Not disks but drums (2 replies)
- 2piece Drum Hub Vs Drum Brake Hub Sizes? (2 replies)
- no emergency brake (14 replies)
- Drum Brake hub source (5 replies)
- Pressing studs from drum hubs...Help. (4 replies)
- Question about C5 calipers (16 replies)
- Piston sizing... (20 replies)
- Is there such a thing as too much brakes? (8 replies)
- Brakes for Ford 9" (1 replies)
- Good place to buy PBR calipers (1 replies)
- Wilwood brakes on Chevelle (4 replies)
- Disc Brake conversion - which one?? (7 replies)
- cheap? early vette 4piston to 1st generation (5 replies)
- rear disks? (19 replies)
- Double-check my braking plan (6 replies)
- Baer Track 13 on 79 Trans Am (1 replies)
- Opinions on floating rotors? (4 replies)
- C5 rear brakes on Buick GN? (2 replies)
- 4th gen booster in a 1st gen f body (0 replies)
- 15/16 master on C5 front brakes? (6 replies)
- are compression fittings ok for brake lines? (8 replies)
- funny cross drilled post from ls1tech .com (10 replies)
- 13" Rotors on C4 Rear ??? (5 replies)
- Christmas Sale at Touring Classics (0 replies)
- Mule Master Cylinder? (2 replies)
- Master Cylinder question for PBR calipers (4 replies)
- Rotor diameter ? (9 replies)
- Bias Bar vs. Prop Valve (10 replies)
- cheap front disks for 62 (2 replies)
- Malitude master cylinder ? (1 replies)
- Master Cylinder (for JL8 brakes) (3 replies)
- Partial C5 brake swap (0 replies)
- C5 brakes on 2ndGen Camaro? (8 replies)
- Who makes mounting brackets for C5 brake swap? (6 replies)
- Any issues with Durastop rotors? (3 replies)
- Touring Classics C5 conversion & dropped spindles (0 replies)
- Painted calipers - yes or no? (9 replies)
- Need assistance. (0 replies)
- late model camaro rotor differences?? (4 replies)
- Partitioning valve bracket (1 replies)
- New cheap big brake idea (22 replies)
- Corvette or Camaro ABS Swap into my 69 (5 replies)
- Torque Specs (2 replies)
- Front Disc Question....... (8 replies)
- Crossdrilled rotors part 3!!! (43 replies)
- ford 9" disc brakes (1 replies)
- What wheels work with the C5 rotor? (4 replies)
- Adjusting problem ? (2 replies)
- Which Years LS1 Rear Brakes Fit a First Gen Camaro (8 replies)
- Upgrade options for front brakes on 2nd Gen. Camaro (1 replies)
- have 12 bolt need brakes 72 chevelle wagon (3 replies)
- New Touring-Classics front/rear discs (12 replies)
- Vibration when braking from high speeds (3 replies)
- Which rotor and MC to use with LS1 calipers (2 replies)
- C5 park brake parts? (7 replies)
- Emergency/Park Brake (9 replies)
- mustang...... (4 replies)
- C5 Conversion Hub Balance Question (4 replies)
- Opinions on Brake set-up (0 replies)
- Master Cylinder Question (2 replies)
- Baer Brakes for old Fords? (4 replies)
- Question about Baer Brakes (7 replies)
- Rear Brake swap (0 replies)
- LS1 Rear Brackets (12 replies)
- C5 master cylinder (10 replies)
- Is it worth it? Stock size slotted rotors. (1 replies)
- C5 2nd Generation Brackets (6 replies)
- Baer online info (3 replies)
- looking for a 69 Rear Disk setup (0 replies)
- disc brakes fro '77 to '68 ???????? (3 replies)
- Rear Brake Hardlines (5 replies)
- Baer Brakes Serious Street? (5 replies)
- HELP! anyone know the difference between REAR C5 and LS1 caliper brackets? (26 replies)
