View Full Version : C5 rear information
jjump59
04-19-2005, 04:21 PM
just finishing up my C5 rear caliper/rotor deal (GM 12 bolt). everything is going together real well. was wondering if someone could provide someplace to post pictures, part numbers and a short how-to. i don't know much about the computer end of it and could send everything to someone. i had a hard time getting good solid answers when i started and would like to provide the information for others. Total cost is around $500.00 using GM parts, mostly new but used calipers. sorry if this is posted in wrong place.
joeljet
05-07-2005, 03:33 AM
hey jump sorry i cant help you put the info onto the computer but im trying to find info on doing something like this to a second gen f-body. what car did you do it to? thanx joel
jjump59
05-07-2005, 10:45 AM
i did it to an a-body but it's all the same, 10 bolt/12 bolt GM. i didn't get any response to this so i put the car together without writing it all down. if you need i can get all the information to you in a few days. i'll just have to go over all of my reciepts for the part numbers. i had a friend CNC a set of spacers so the e-brake stuff lines up. he can make more and is selling them for $65.00 a pair. i used C5 calipers and rotors with LS1 backing plates and e-brake cables. havn't driven it yet but it looks good! trying to get the master on today and take it out tonight.
rocketpower
05-10-2005, 05:18 AM
jjump,
I can host the information on my site, if you wanted to do a HOW TO. I am actually in the process of starting to bolt the 13" C5 setup on my 65 Cutlass.
Shoot me an email at [email protected] if you need help.
joeljet
05-11-2005, 06:50 AM
yes id like to see part #'s,prices(approx),and photos if possible.what did you do for the front brakes? send to [email protected] thanx joel
jjump59
05-11-2005, 10:22 AM
i also used C5 stuff on the front. i bought my brackets from touring classics and bolted it all to the stock spindles. bought used calipers, otherwise everything is new GM. can't beat the 40.00 drilled/slotted Z06 rotors! i will try to get a list together before this weekend and email it to you.
69camaro69
05-11-2005, 05:30 PM
Hey guys, I'm doing the same setup on my 69 Camaro-- all LS1 rear setup. Would you be able to give me the name and number of the person that makes the spacers for the 12 bolt rear.
Thankyou!!
