    Results 1 to 5 of 5
      Sep 2004
      Baer Brakes for old Fords?
      (a continuation of a thread from the project update page)
      so where can I buy the 13-front/12-rear Baer brake package for my Fairlane
      (same spindle as a mustang)? I know Baer makes them; lots of cars are running
      them. I just don't know where they are buying them and for how much. baer.com
      is not much help, and googling only turns up late model packages.
      I'm still trying to decide Baer vs. SSBC vs. JMC.
      pointers & urls welcome. thanks.
      Oakland CA
      call the number on the baer site they would be glad to asisst...
      :3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
      1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
      Quote Originally Posted by phonedude_mln
      you need to follow the advice above in the projects post. you have to buy directly from baer. expect a small wait, i took me a little over a month to get mine. if you can, upgrade to the 70 drum spindles, they are heavier duty, but only if your car is a 68-69 or 70
      EDIT nevermind on the 70 spindles, stay with yours on a '66, i just read your profile.
      http://www.splendora-classmates.com/mystang.htm
      351W/AOD/4X DISC BAER BRAKES/17X8" TT II'S/TCP POWER R&P
      Sep 2004
      thanks --- I'll call them direct. I was confused since you could find late model stuff
      at reseller sites.
      btw -- Global West sells brakes w/ Wilwood calipers on the large 69-73 spindles:
      http://www.globalwest.net/mustang_19...%20catalog.htm
      maryland
      actually, i'm having an open GP on them right now.
      look in the group purchase section of this board for details.thank you,
      mike
