    Results 1 to 7 of 7
      Jul 2002
      Mesquite, TX
      Double-check my braking plan
      Brakes, like so many things on my car, have been up in the air for a long time and a lot of ideas have sounded like the 'proper' way to go. Unfortunately, I don't remember what went with what and why item A was a better idea than item B at the time.
      What I've got right now:
      Tall (B-body) spindles
      Joe's C5 front caliper brackets
      93-97 Camaro/C4 rear caliper brackets
      The plan:
      C5 front calipers (2 40mm pistons) on C5 13" rotor
      C4/93-97 Camaro rear calipers (1 40.8781mm piston) on Camaro 11.6" rotors.
      15/16" bore master cylinder
      Now, I remember reading that the rear piston should be ~60% of the size of the front (but I can't find where I read that so it may be my imagination) and in my searching this morning I found a post that said that the rear piston area should be no more than 50% of the front.
      If I break out my rusty math skills, I get 2512mm area for the fronts
      (40mm diameter = 20mm radius; 20mm^2 * pi -> 1256mm, *2 for 2 pistons -> 2512mm)
      and 1311.75mm for the rear
      (40.8781mm = 20.439mm radius; 20.439mm^2 *pi = 1311.75mm)
      which would appear to leave the rears at 52% of the fronts.
      If y'all would, please a) doublecheck my math, and b) doublecheck my thought process - it's not too late to change directions on this so long as I haven't bought anything expensive.
      CA
      a) Your math is close enuf (I got 2513.3mm^2 and 1312.4mm^2). I multiply the numbers by two for floating calipers, so effective piston area of 5026.6mm^2 and 2624.8mm^2, respectively.
      b) It really depends on the combination of parts you have, so there's no set rule, or set % ratio of rear piston area/front piston area (as far as I know, anyway). A car with super low CG, 65% rear weight bias and 25" front and 32" rear tires will require a lot more brake in the rear than a car with high CG, 58% on nose with same diameter tires all way around, for example.
      My rear calipers (1.375" 4-piston) have 62% of total area of my front calipers (1.75" 4-piston). 13"/12" rotors, and 27.2"/28.5" tires, w/ 57% front weight bias. It's basically an oversized A-body w/ big block (Riv is E-body, JFYI). It's been working just fine since I got the rear pressure dialed in.
      Not sure about your M/C bore size (depends on pedal ratio and power-or-manual), but otherwise it looks fine to me. Make sure you have some means of adjusting the front/rear brake bias (dual M/C or proportioning valve).
      The first step of becoming a better driver is to attend a track event, time yourself, and realize the fact you really suck.
      Signed,
      A driver who laps Big Willow at 1:42.6 in a 134hp BMW - and I am still considered mediocre.
      Jul 2002
      Mesquite, TX
      Thanks, Katz.
      I'd neglected to add the adjustable proportioning valve I'd planned, or to point out that this is for my '65 Malibu. M/C would be powered - either vacuum-powered or Hydroboosted.
      CA
      With power assist and pedal ratio of 4:1 or better, you can probably do 1" M/C. But don't quote me...
      CarlC has setup somewhat similar to yours on his Camaro (which happens to be one of my fav. Camaros on this site - very clean but he uses it on tracks regularly). Check out his webpage and see what he'd done.
      Signed,
      Dec 2002
      MusicCity
      Larger Bore
      Quote Originally Posted by derekf
      Thanks, Katz.
      IF you end up going the hydraulic assist route, note that master cylinder bore sizing is very pleasantly de-emphasized quite a bit, due to the unique characteristics of their functions. For instance, a 15/16ths bore mc would be a general candidate for manual usage vs your combo, a 1" bore would be a general candidate with the vac assist, and with hydraulic assist, you could actually run a range of 1" to 1 1/8" bore with spectacular results. If you were to install one of our systems, I'd steer you towards the 1 1/8" bore...
      There IS a difference - Thank you for choosing Hydratech!
      Paul M. Clark
      Founder / Master Engineer
      Hydratech Braking Systems ®
      www.hydratechbraking.com
      please school me on joes c5 brake brackets, havent been on line hear for a while ,i must have missed this, thanks dwayne
      dennis68 Guest
      Joe's brake bracket to fit the C5 caliper onto B spindles can be seen below....
