    Results 1 to 3 of 3
      Chico, California Nor-Cal
      4th gen Camaro master hook up
      I'm installing this on my 71 camaro, it's from a 96 trans am 4 disc. I understand the front fitting gooes to the rear, while the rear fitting goes to the front brakes? Is this correct????
      I believe you are correct. The easiest way to tell is the that larger of the two resevoirs goes to the front.
      they are the same size!
