    Results 1 to 6 of 6
      hudsonville, MI
      c4 conversion master cylinder on a 69 camaro
      On my 69 camaro does anybody know what master cylinder to use with c4 12" rotors in the front and stock drums in the back ? This will remain a manual system and I here about the 88 s10 mc but I havent seen anybody use it with a manual system I would like to have the look of the newer aluminum mc with plastic if possible.
      CT
      Actually I have the same question, sort of...
      I have the C5 - 13" and keeping the rear drums till the fall.
      May 2000
      For the C4 calipers in manual mode. Many have tried this, and most didn't have the best results. What you want it a m/c bore size very small. Try to find one with a 7/8" bore, or smaller.
      Baer sends a m/c with a 15/16" bore, with their kit that uses the same calipers.
      Stock C4 had a 15/16" bore, but used a booster. So I'm not sure how this bore would work very well at all without using a booster.
      C5 calipers have a larger piston volume. So I would think a 15/16" bore would work. But I'm sure someone has this combo, and will supply better info.
      For the rear drums, an adjustible prop valve can be used.
      Sep 2001
      Accord, NY
      I tried a 78 Malibu MC, 15/16", in manual mode and gave up and went to hydroboost. Even with aggressive Hawk pads, the effort is too high to comfortably modulate. This is a 13" C4 front/rear drum. Mean69 did alot more experimenting with poor results. Try a search for lots of discussion. I think a 7/8" gave too much pedal travel.
      69 Camaro convertible, 410, M22, 8-pt cage therapy program. SOLD.
      68 camaro - SOLD
      67 Bel Air - New street project with perfect floors, frame and trunk!
      Sep 2004
      CT
      I purcahsed a manual M/C w/ portioning valve from MP brakes to use with My old 4 wheel disc setup. I recently put the c5 conversion on the front and it still works good..
      hudsonville, MI
      Do you happen to have the part# from MP brakes so I can look into this more through them? Thanks a bunch.
