View Full Version : Power Adders
- Twin Turbo Ls3 (20 replies)
- What plugs?? Vortech blown 338SBC with AFR heads (2 replies)
- turbo question (1 replies)
- Support turbos or not? Pic's Opinions,,, (14 replies)
- boosting at altitude (2 replies)
- Question about turbo cam (4 replies)
- turbo oil return pump (10 replies)
- Wideband o2 (23 replies)
- 4000hp BBC comming soon.......? (11 replies)
- 30 Degree Temp Gain (11 replies)
- Fuel pressure for blown sbc? (13 replies)
- Variable Geometry Turbo's (1 replies)
- Question about my GT35R (12 replies)
- Sbc with procharger. Which r4 compressor to buy? (0 replies)
- Edelbrock E- Force Super Charger Install On 2010 Camaro (10 replies)
- Dyno day (10 replies)
- Twin turbo engine upgrades? (6 replies)
- procharger ? (9 replies)
- Turbo vacuum (10 replies)
- too much oil? (7 replies)
- turbo seized? (6 replies)
- 421ci SBC High Boost/E85/Blower/N2O Project (9 replies)
- Fuel Tank for Twin turbo (20 replies)
- rear gear recommendations (10 replies)
- oil feed line for a 5.3 turbo (5 replies)
- Mod motors (9 replies)
- What Kind of system would you Suggest (2 replies)
- delete (0 replies)
- External wastegate vs. Internal (12 replies)
- Juice on a zz430 (1 replies)
- bbc 454 upgrades (5 replies)
- Pictures of my water injection in manifold (5 replies)
- I'm going Twin Procharged (48 replies)
- Tuning on twin turbos (4 replies)
- Programmable 6al2 (13 replies)
- Big block Mopar with engine plate (3 replies)
- 5.0 KB twin screw (0 replies)
- Nelson supercharger (2 replies)
- is it safe to run nitrous with a dual plane intake (3 replies)
- Procharger on LS engine kit? (0 replies)
- twin turbos with or withour intercooler (23 replies)
- LS turbo setup in 1st gen f-body, anyone? (2 replies)
- Stock 350 block w/ twin turbos? (18 replies)
- Anyone Know About COMP TURBO'S? (1 replies)
- Please help me Identify my Banks Turbo (0 replies)
- L92 Turbo or Supercharger? (12 replies)
- HELP with intercooler 1st gen camaro (2 replies)
- rear mount turbo (25 replies)
- Custom Water/Methanol Injection System (26 replies)
- Procharger with power steering issues - help! (16 replies)
- 7.2:1 comp ratio, just how much BOOST? Pontiac 400... (22 replies)
- procharger C3 corvette (good news) (18 replies)
- D1SC Bracket that holds cover on blower (1 replies)
- Intercooler for 1st gen Camaro (16 replies)
- KB Twin Screw (27 replies)
- weiand 144 (1 replies)
- Vacuum operated exhaust cutout? (1 replies)
- Procharger question? (1 replies)
- Twin Turbo SB Mopar (5 replies)
- Holy Huge Supercharger The New Procharger F4 (5 replies)
- RSX Piston Meltdown (38 replies)
- w/g & bov question (4 replies)
- The motor is alive! (6 replies)
- Single turbo SBC (9 replies)
- Quick Procharger Race Bypass Valve Question ... (13 replies)
- I might have to take my engine to a Pro. (15 replies)
- who knows of a master power dealer? (1 replies)
- Eldorado supercharger ? (4 replies)
- AFR 235 for the street! (35 replies)
- 69 gto (4 replies)
- LT1 in 2nd gen camaro ... will procharger fit? (4 replies)
- is my motor sufficeint for a supercharger? (1 replies)
- SBC Turbo Cast Manifolds! (15 replies)
- 20 year old Turbo (5 replies)
- Intercool vs Methyl injection (10 replies)
- 5.3 with a turbo in a 85 monte??? (3 replies)
- zz385 350 forged crank fb heads h cam (1 replies)
- I have obstacles in my way when trying to use my timing light ... questions ... (2 replies)
- Boost Timing Master and Vac Advance? (8 replies)
- twin turbo (2 replies)
- Supercharger (0 replies)
- magnussen supercharger (0 replies)
- FINALLY got my car put together and running & now to button it all down ... questions (12 replies)
- Question for the Turbo Guys... (5 replies)
- dont know if this is the right section but, lets see hidden nitrous setups! (22 replies)
- AEM Water/Methanol injection kit (10 replies)
- supercharger (7 replies)
- Nitrous question (2 replies)
- theoretical: what's a blower got that high compression ain't got? (9 replies)
- Carbd Procharger Part throttle lean problems (10 replies)
- Kenne bell owners (6 replies)
- turbo/engine Q (10 replies)
- my new blower setup - procharger F1-R on FE 427 (5 replies)
- Surge valve (9 replies)
- Turbo, synthetic or mineral oil? (5 replies)
- the juice (3 replies)
- question on inlet pipe diameter - f1 procharger (20 replies)
- Supercharger (7 replies)
- 94mm Turbo Setup Pics (7 replies)
- Boost reference. (7 replies)
- Got a free 6-71 Dyer. Need info to put on my 454 (16 replies)
- dyno day (6 replies)
- Supercharged s10?? (1 replies)
- super charged ranks (3 replies)
- Running a centrifugal supercharger backwards (36 replies)
- cam selection for Procharged 350 (18 replies)
- Twin turbo math question (18 replies)
- Throttle pedal issues... (0 replies)
- Limiting high rpm boost (3 replies)
- Vortech V2 S-Trim on SBC.. need help! (4 replies)
- Can I use the EGR port for my brake booster? (7 replies)
- Ignition timing for Supercharged 408 (8 replies)
- How would you build my LT1? (11 replies)
- B&M 144 blower and power question (2 replies)
- Blown head gasket!!!!!! (6 replies)
- Hats (0 replies)
- Turbo...Up front or in the back? (6 replies)
- vac lines? (1 replies)
- Intake Charge Temperature (9 replies)
- Exhaust Cutout illegal? - San Diego, CA (11 replies)
- Procharged Chevy 350 (15 replies)
- Opinions on Banks Twin turbo set-ups... (9 replies)
- G body Turbo (3 replies)
- to cog or not to cog (9 replies)
- Twin Turbo in a 68 camaro (8 replies)
- Cogged crank pulley (4 replies)
- Any info-how to change teflon strips (5 replies)
- How to change teflon strip in blower? (0 replies)
- Horsepower per pound of boost? (2 replies)
- What is the world record? 8-71 (12 replies)
- Vortech S1 trim or B&M 143 roots? (2 replies)
- Mock up of the D1SC on my 408 sbc (18 replies)
- Turbo LT1 (3 replies)
- D1SC/355 combo (3 replies)
- MAP / Fuel Reg / By-Pass Valve (Line) (1 replies)
- Too Much!!!!!!!!!!!!!! (4 replies)
- Probably a dumb question, but... (7 replies)
- From Roots To Procharger? (2 replies)
- Evap pump for MotiV8r (2 replies)
- Pan evac for boosted motor (1 replies)
- Al. or mild stl. charge tubing? (3 replies)
- Blow through carb and hat sealing (1 replies)
- Magnacharged Gen III with Front Runner? (2 replies)
- Found a Twin Turbo Buick 455 Kit advice needed (1 replies)
- 455 Buick Twin Turbo upgrade kit (0 replies)
- best forced induction for LT1? (1 replies)
- Procharger (and others) Videos on You Tube (27 replies)
- Procharger Bypass/Surge Valve with Intercooler (2 replies)
- Blown issues!!!! (11 replies)
- 351c Centrifugal blower ? (1 replies)
- What's everyone think of this Supercharger? (8 replies)
- pro charger (2 replies)
- Twin Turbo Olds (6 replies)
- 351 cleveland mini roots blower? (5 replies)
- cannot make over 10 psi of boost (17 replies)
- what the shaft (0 replies)
- FAST A/F meter mountung (5 replies)
- Twin GT-K1000 project (6 replies)
- To boost, or not to boost? (6 replies)
- OK trying to get better idea of possibilities,,,, (1 replies)
- Procharger Alternator mounting on BBC (8 replies)
- X hat or super vic (19 replies)
- Turbo oil source. Where to find on SBC? (10 replies)
- E85 + Boost + "High" Compression? (11 replies)
- Blower for 351? (10 replies)
- Supercharger in 66 El Camino (2 replies)
- Inline 6 with turbo (28 replies)
- Turbo size help (8 replies)
- What's the best way to upgrade my 350 (2 replies)
- BDS blower for LSX (1 replies)
- Best methanol injection out there?? (3 replies)
- Martin Turbo setup... (4 replies)
- Heat wrap turbo? (5 replies)
- PCV on a boosted engine??? (11 replies)
- supercharging a VUE (12 replies)
- Intercoolers (15 replies)
- Where's your Eliminator/A1000? (3 replies)
- Is 9.0:1 compression ratio too high for 10lbs of boost? (30 replies)
- Who makes the best Desktop Dyno for turbo motors? (5 replies)
- LS2 1st Gen F body FI kit (3 replies)
- sufficient bottom end for procharger? (19 replies)
- Blower cam?? (7 replies)
- SC LS1 first gen??? (9 replies)
- Ring End Gap On Small Bock Chevy With Procharger (4 replies)
- nitrous for LT1??? (1 replies)
- new guy (3 replies)
- Procharger Giving Me FITS! (21 replies)
- Will 4 inch tubing improve F1C efficiency? (37 replies)
- Comments / advice request (5 replies)
- anyone heard anything about the aluminator? (2 replies)
- Paxton SN93 F-body (0 replies)
- Would this work?? (7 replies)
- Turbo size question. (1 replies)
- D1sc Accessory Drive Question (7 replies)
- help with twin turbo timing. (8 replies)
- who makes the smallest supercharger? (6 replies)
- Turboing a BBC (8 replies)
- good start for a twin turbo set up? (3 replies)
- Anyone a Turbonetics dealer? (5 replies)
- Intercooler tubing clamps. Help me locate. (29 replies)
- good high reving race engine? *nitrous injected* (9 replies)
- custom intercoolers? (12 replies)
- fuel pump block off plate drain. (3 replies)
- Need help deciding on what size turbos to get. (5 replies)
- Twin turbo headers....where to buy some (18 replies)
- Blow Off question? (3 replies)
- BBC Turbo Kits (1 replies)
- Any Procharger experts out there?? (19 replies)
- Alcohol Injection (12 replies)
- Turbo on 93 Corvette LT1 Block (7 replies)
- Nitrous questions (3 replies)
- Procharger and Power Brakes (5 replies)
- What You Need for A Turbo Setup (8 replies)
- Procharger Fuel Pump (13 replies)
- f1r charger intercooler on 69 maro (4 replies)
- cast iron heads for intercooled twin turbo setup (4 replies)
- By Pass Valve Vent or into the intake (6 replies)
- BBC Turbo placement... (1 replies)
- electric supercharger for $67 ??? (3 replies)
- This might damage my reputation for asking but are these any good? (20 replies)
- Need thoughts on new dizzy, vacuum advance or not? (22 replies)
- Which Procharger Pulley is this? (2 replies)
- Looking for info on a car... (0 replies)
- Procharger needs idler pulley (3 replies)
- Corvair twin Turbo (23 replies)
- 5.0 GT Vortec issue (0 replies)
- Intercoolers-does size matter? (7 replies)
- Procharger 8 rib drive belts (6 replies)
- Intercooler prices (3 replies)
- Single turbo? (2 replies)
- Serp Pulley setup for Procharger Motor (8 replies)
- Which power adder for this SBC Engine? (9 replies)
- need some help here ! (3 replies)
- Where to buy: Aluminum tubing and silicon hose (11 replies)
- air fuel blues! (24 replies)
- Procharger prices? (4 replies)
- Supercharger Help!!! (5 replies)
- Prologger wide band system. Opinions please. (0 replies)
- Twin Turbo BBC (29 replies)
- Ideas on how to change current 950 Wideband tune when adding Alky? (3 replies)
- Procharger-Power Steering- Small Block Chevy (18 replies)
- Weiand 142 and 68 Camaro (4 replies)
- Nelson Racings new LSX twin turbo headers (18 replies)
- ATI clutch drive (8 replies)
- Which type of TB is most streetable? (1 replies)
- Belt slip on Magnacharged LS1? (21 replies)
- 17.8-18.9 AFR @ idle, thoughts? (7 replies)
- Roots style vs centrifugal (6 replies)
- Vortec 8.1 (496 bored .030 over)....turbo'd? (8 replies)
- FAST dual A/F mounting options (2 replies)
