JamesJ
11-13-2008, 01:38 PM
Can I runn all three: MAP / Fuel Reg / By-Pass Valve off the same line or is it better to have adedicated line for one or the other?
camcojb
11-13-2008, 04:16 PM
map should have it's own line, shorter the better. The other two can share, assuming EFI (since it has a map sensor). With a blow through carb the fuel regulator line goes in the hat, the bypass would need a vacuum signal.
Jody
