View Full Version : Twin Turbo Olds
CliffS
09-16-2008, 04:22 AM
Doing some research on Turbocharged Olds engines. Planning to turbo an Olds 442, 455 engine. There is some info on Olds diesel engines on the net but looking for some more specific (finished) Olds projects. Any links/info?
oestek
09-16-2008, 05:26 AM
We're in the same boat with our project S71 Olds... it's a diesel-block based 428 stroker with a single turbo and a FAST EFI system. Not much info out there, check www.realoldspower.com for some insight. Got pics?
CliffS
09-17-2008, 06:28 AM
We're probably are, not much info out there:)
Got some pics have to search though, nothing special only a 442 without engine and rear end.
jackfrost
09-18-2008, 10:20 AM
check out ROP. like kevin mentioned. most guys turbo the diesel small-block.
what are you goals? do you just want a twin turbo? there might be a better way w/ your BBO.
CliffS
09-20-2008, 01:37 AM
We're looking in something totaly different. The old has seen several set ups; rebuild, stroked, steel heads, alu heads, lot of comp (13:1 on pump gas).
With the twin set up we want to achieve triple digits horses.
TD2593
10-12-2008, 04:15 PM
If your looking to do a Turbocharged Olds motor, go with a small block for a base. This is what Im running, excellent durability.
http://72.22.90.30/phpBB2/viewtopic.php?t=759
CliffS
10-13-2008, 11:57 PM
Thanks Russel. I've seen your post on the Olds board. Do you have more details on the block maybe some pics?
