View Full Version : Suspension
- BMR Suspension Christmas / New Years Sale (1 replies)
- UMI Releases New Product: Subframe Repair Kit for the 1970-1981 Camaro & Firebird (1 replies)
- Looking to upgrade my steering box on my 71 chevelle , any suggestions? (3 replies)
- UMI Releases New Product: Upper & Lower Front A-arms for the 70-81 Camaro & Firebird (0 replies)
- C6 UCA mounting angle (4 replies)
- Napa quick ratio steering box for GM a body (5 replies)
- Steering Column and Box (5 replies)
- Coilover Options (11 replies)
- Track width change (1 replies)
- Safe clearance for rim/suspension (9 replies)
- 9inch axle length difference (3 replies)
- '69 Camaro Steering Column/Quick Ratio Box Info (8 replies)
- FAB 9 rear leaf spring perch angle (0 replies)
- Hotchkis Arms jacked up on 67 Firebird (9 replies)
- 4th gen camaro ridetech coilovers owners please come in (1 replies)
- Steering shaft u joints (5 replies)
- Roadster Shop (3 replies)
- Suspension design idea (8 replies)
- Over Assisted Power Steering Answer.. (5 replies)
- 70 nova rear wheels (0 replies)
- B-body spindle "kit" for 68-72 GM A body - a sad tale!! (34 replies)
- 72 nova suspension (4 replies)
- Power steering pump for 68 Camaro (6 replies)
- lowering blocks (1 replies)
- G body Monte Front coil springs (2 replies)
- Any good Black Friday/Cyber Monday deals on Borgeson?? (0 replies)
- Several great Speedtech supensions on sale!! (0 replies)
- UMI Black Friday-Cyber Monday 5-Day Sale! 10% Off & Free Shipping- 11-24 to 11-28 (0 replies)
- UMI Releases New Product: Performance Monotube Shocks for the 70-81 Camaro & Firebird (0 replies)
- UMI Releases New Product: Panhard Bar Lowering/Leveling Kit for the 1982-2002 F-Body (0 replies)
- Control Freak 4-link experiences? (3 replies)
- Help with First gen Camaro frame alignment (1 replies)
- BMR Suspension Thanksgiving / Black Friday Sale (2 replies)
- Firewall reinforcement (1 replies)
- Art Morrison steering arm loose (3 replies)
- Building a torque arm set up for 72 nova (8 replies)
- UMI Releases New Product: Panhard Bar Lowering Bracket for the 1982-2002 GM F-Body (0 replies)
- First gen Camaro with GW arms and RideTech spindles. (3 replies)
- tall spindles with 2" drope (0 replies)
- Global West kit for 1967 Camaro?? (2 replies)
- 67 Camaro Mini Tub Kit Questions (1 replies)
- Ridetech coilover too low (12 replies)
- Pro touring F body comp kit vs ridetech level 2 (16 replies)
- Camber / Tall spindle dilema (12 replies)
- Leaf Spring Advice- First Gen Camaro (13 replies)
- Too stiff up front or too soft in back? (3 replies)
- Effects of tall ball joints on GM A bodys.. (1 replies)
- 1969 camaro upper ball joint angle looks wrong? (11 replies)
- 69 camaro (0 replies)
- Which rear suspension set up offers the most room for exhaust? (6 replies)
- has any one used this kit (7 replies)
- what spring for Ridetech Tall Spindle (3 replies)
- Lowering height/Camber adjustment (0 replies)
- chassis tech, sway bar, article by Bob Bolles December 2016 circle track magazine (0 replies)
- simple, cheep, and pretty accurate way to set toe (6 replies)
- IRS "jacking" - blame it on the RC height, or the LCA angle? (0 replies)
- Jeep Grand Cherokee Steering box A body swap (9 replies)
- 69 charger front suspension build (9 replies)
- Straight line performance sucks...DSE (17 replies)
- PS flow control on vintage air frontrunner Pump (0 replies)
- originals 1969 brackets (2 replies)
- gen 4 column in first gen camaro (5 replies)
- 74 firebird to 75up centerlink/tie rod ends (1 replies)
- Wilwood pro spindle? (0 replies)
- Frustrated with steering rack (5 replies)
- Double A vs McPherson (6 replies)
- Ridetech Camaro A-arm, stock spindle with Gmod (12 replies)
- DSE Rear Sway Bar Options - 2nd gen Camaro (7 replies)
- Toe in measurment from "stringing" or Quick Trick? (6 replies)
- how is fast is turning radius? (lock to lock) and what did you do to achieve it? (0 replies)
- Am I on the right track? Tentative layout. (5 replies)
- UMI Releases New Product: Front Frame Brace for the 70-81 GM F-Body & 64-72 GM A-Body (0 replies)
- 67 Camaro Subrame measurements (0 replies)
- 65-66 mustang Hotchkis upper and lower arms? (1 replies)
- A-Body upper a-arm attachment. (5 replies)
- Need help with a RideTech Question (3 replies)
- 69 camaro frame (6 replies)
- UMI Releases New Product: Bumpsteer kit for the GM 64-72 A-Body and 78-88 G-Body (7 replies)
- 68 Camaro Aftermarket Subframe (12 replies)
- Rear end squat at high speed (13 replies)
- Retrofit IRS to a 67 Camaro (6 replies)
- Frame stiffening? (1 replies)
- 2013 camaro no power steering pump (2 replies)
- Proforged ball joint (3 replies)
- who makes the best coilover shocks? (17 replies)
- ridetech sell me some coil overs (11 replies)
- I need a quick/easy measurement from the 64'-67 gm a body guys (1 replies)
- best WAY TO REMOVE REAR URATHANE LEAF SPRING BUSHING FROM SUB FRAME (1 replies)
- Will a front sway bar still work if mounted behind the ft tires? (5 replies)
- upgraded leaf spring pocket mount with four link (2 replies)
- Maier Racing Drop Spindles for 65-70 Mustangs (9 replies)
- Ridetech rear suspension bottoms out on bumps (9 replies)
- Hitch on my 68 Firebird (7 replies)
- 1985 Dodge 300 2WD Crew Cab Short Bed (2 replies)
- Question for the Metal Geeks, Torsion Bars (5 replies)
- Best power steering pump replacement? (6 replies)
- 3rd gen F-Body rack and pinion conversion info needed (13 replies)
- '69 Camaro Suspension Advice - Comfort #1, Performance #2 (31 replies)
- UMI 5-Day Sale- 10% off & Free Shipping 09-02-16 to 09-06-16 (0 replies)
- 12 bolt axle tubes slight curve? (4 replies)
- 1988 monte carlo suspension upgrades front and rear (2 replies)
- Sway bar testing with Hotchkis springs (3 replies)
- 1st gen camaro DSE subframe and quadralink alignment specs (6 replies)
- 65-66 Impala "B" Body Ackermann steering Fix (4 replies)
- F- body 2gen. Fuel tank relocation (9 replies)
- the people that are into suspension should be reading BOB BOOLES, CIRCLE TRACK MAG (0 replies)
- Need help with Ridetech upper control arms. (0 replies)
- inboard shock mounting on g-body helped take some of the bind out of the shock (4 replies)
- Square tube panhard mount on the street? (0 replies)
- Viking Rear travel with Speedtech Torque Arm (4 replies)
- steering issues, need some help (5 replies)
- 68 camaro rear minitub.. what's all needed?? (11 replies)
- fatman fabrication has very good article in chevy high performance jan 2013 (0 replies)
- Slotting upper control arm shafts for more caster (2 replies)
- Looking to completely upgrade gbody suspension. Need suggestions please. (5 replies)
- Pinion Angle Finally Solved (6 replies)
- Nova Daily Driver Suspension Help (13 replies)
- s10 front clip tubular a arms (15 replies)
- steering column rebuild and modification on 77 trans am- 2nd gen (3 replies)
- Possible to run Shockwaves with stock control arms? (7 replies)
- 68 Camaro bolt in subframe (14 replies)
- UMI Releases New Product: Competition Coilover Kit for the 1993-2002 Camaro/Firebird (0 replies)
- Increasing steering effort (5 replies)
- G Body Suspension Geometry - UCA (0 replies)
- 1st gen camaro dse quadralink shock choice (19 replies)
- Mustang rear suspension, tci 3-link, chassisworks triangulated 4-link (0 replies)
- Hotchkis Sub Frame Connectors 68 camaro vert (3 replies)
- Need Steering Box Help (1968 GTO, Pro Touring Suspension) (21 replies)
- TCI 4 link and subframe opinions? (6 replies)
- Hiedts (10 replies)
- Chevrolet truck arms on Ford F100 (3 replies)
- 1gen ridetech 4 link upper brackets (4 replies)
- Double adjustable shock. Does increasing compression... (13 replies)
- UMI vs ridetech (14 replies)
- A favor from the Fox Body Mustang Guys (0 replies)
- Differential identification - need help (2 replies)
- Off set shafts - A Body... (1 replies)
- Las Vegas alignment shop? (2 replies)
- Late 70's Plymouth Volare and Dodge Aspen (1 replies)
- '62 Chevy "Chicayne" frame work link needed. (0 replies)
- 1955 Belair springs - recommendations? (0 replies)
- Street Grip review (54 replies)
- Question 68 Camaro rear suspension w/ coil overs vs 4 link set up (12 replies)
- Cutlass/A-Body lowering - shock, spring question (12 replies)
- Something wrong with DSE rack!! (56 replies)
- Anyone have experience with Spax shocks? (0 replies)
- C10 rear 5" or 6" lowering coil spring installed height (0 replies)
- steering set-up for 70 Firebird with DSE subframe and rack (3 replies)
- 2003 Viper a arm specs (1 replies)
- Suspension questions... (3 replies)
- quicksteer box centerlink clearance (2 replies)
- 3 link and a strange phenomenon.. I think. (8 replies)
- PS pump whine when autocrossing. '68 pump, '86 monte ss box (20 replies)
- SC&C Stage 2+ question 69 A body.. (15 replies)
- Tri. 4 link install help? (0 replies)
- Ride tech Level 1 work with chevy 10 bolt? (8 replies)
- Ridetech Shockwaves w/internal height sensors? (2 replies)
- Opinions on CCP 2nd gen spindles? (22 replies)
- UMI 5-Day Sale- 10% Off & Free Shipping 07-01 to 07-05 (0 replies)
- Which way do the rear shocks mount on a DS rear set up (1 replies)
- Frame Bracing (2 replies)
- driveshaft angles. (8 replies)
- GM type II pumps for DSE rack? (2 replies)
- Jacobs Ladder (1 replies)
- Flaming River Variable pressure Type 2 power steering pump? (0 replies)
- Trying to cut through the hyperbole (13 replies)
- Speedtech releases new stronger Frame Connectors! (0 replies)
- chassis works g street chassis (15 replies)
- 3rd Gen F body Mac struts (5 replies)
- Adjusting rack and pinion (2 replies)
- steering box suggestions? (11 replies)
- QA1 Level 2 Handling Suspension Kits HK02-GMF2 (0 replies)
- DSE Sub Frame Connector Installation - 1971 Firebird (3 replies)
- Tie Rod Flip and Reverse Taper (3 replies)
- 70-81 Camaro/Firebird sway bar comparisons (36 replies)
- 71 Chevelle - splined sway bar or not? (5 replies)
- ebay/Chinese garbage? Or good deal? (9 replies)
- Speedtech's new 3rd Gen Camaro suspension (0 replies)
- G-Body Front Suspension: RideTech vs UMI thoughts, opinions? (15 replies)
- Speedtech pro touring frame (19 replies)
- When to weld in DSE subframe connectors (5 replies)
- mazda mx5 or rx8 suspension and handling (14 replies)
- Bagged Flaming River Bumpsteer Problem (4 replies)
- Sneak Peak! New ExtReme Chevelle Chassis (20 replies)
- 68 Camaro Backspace suggestions to solve an issue (2 replies)
- Control arm bushing size ? (4 replies)
- Caltracs with offset shackles? (4 replies)
- setting front toe 1987 monte carlo (0 replies)
- Suspension Ideas! CHEVY VEGA CORNER CARVER (33 replies)
- Pinion angle for a 67 camaro with an LS motor. (1 replies)
- Leaf springs (0 replies)
- Memorial day subframe special! Woohoo! (0 replies)
- question about steering shaft XJ astro van shaft?!??! (0 replies)
- polyurethane leaf spring bushing? ford ranger. (3 replies)
- Widened Camaro front inner fenders available! (13 replies)
- Air lift 1000? (13 replies)
- speed tech??? (4 replies)
- Rag Joint/Rag Joint Eliminator (3 replies)
- Should I order a new new axle without leaf spring perches? (1 replies)
- caster increase and steering effort in manual steering (6 replies)
- Sway bar size/brand recommendations (10 replies)
- SN95 mustang steering Rack - what fittings do I use. (6 replies)
- How important is ACKERMAN (14 replies)
- GM Power Steering Pump Flow Valve Shim Kit (5 replies)
- question about power steering gear box? (8 replies)
- Boiling power steering fluid after GC steering swap. (27 replies)
- so what spring rate are you guys running? (2 replies)
- 67-69 C/F Hellwig 55824 Rear Sway Bar Dimensions? (3 replies)
- Falcon torque boxes (4 replies)
- Speedtech is giving away FREE sway bars again... (0 replies)
- DSE rear sway bar for 2ND gen (0 replies)
- BIG PROBLEMS with MuscleBAR Sway Bar (4 replies)
- Anyone use the NEW 1st gen F-body reproduction sub-frame (10 replies)
- triangulated 4 link questions (2 replies)
- heim joint strut rods - shock loads, bending moment and the frame mount (0 replies)
- Chris Alstons Chassisworks. (15 replies)
- 2013 mustang suspension ? (1 replies)
- double nuts works very nice on sway bar links, shocks, instead of those locking nuts (2 replies)
- 9" Rear End Measurement (4 replies)
- Budget Weekend Warrior Suspension (7 replies)
- Bump Stops (1 replies)
- fix front sway bar bushing alignment problem on monte carlo UMI 1 1/4" front sway bar (0 replies)
- Fox/SN95 mustang front suspension/ Ball Joint question (0 replies)
- 69 El Camino front suspension update.. (2 replies)
- Suggestions: Lowering springs for -67 A-body (11 replies)
- Please help with choosing rear springs (1 replies)
- Alignment question (1 replies)
- Thoughts or Experiences on Strange Dana 60 ( S60 ) Axle? (6 replies)
- Seriously Considering grafting a C5/C6 Front Suspension (5 replies)
- UMI rear sway bar and shock relocate on 1988 monte carlo (0 replies)
- 1988 monte relocate shocks and UMI rear sway bar really hooks up (1 replies)
- ride tech 4link fit problem (9 replies)
- Looking for a Machineshop in Los Angeles. (4 replies)
- Has anyone gotten their Speedtech's Extreme subframe...opinions/feedback wanted... (19 replies)
- '69 Firebird suspension upgrade and wheel/brakes size (9 replies)
- Is there a LCA that moves the LBJ forward? First Gen F-Body (14 replies)
- What mods to do on a stock F-body subframe (15 replies)
- Front end bottoming out (5 replies)
- Pest or cholera - leafs or trailing arms what's better above 120mph? (8 replies)
- Centering rear-end on 2nd generation Trans Am (3 replies)
- UCA dimensions? (0 replies)
- 2nd Gen Fbody Body mount bolt sizes (4 replies)
- DSE Quadralink Alternative Crossmember (3 replies)
- Rear-end not centered on 2nd Gen Trans Am (0 replies)
- 1967 Camaro 17" wheels - what ride height? (1 replies)
- upper arm orientation (6 replies)
- Caster/Camber Gauge Recommendations (15 replies)
- Steering Upgrade Lares JGC Box or Cardone JGC box (1 replies)
- BMR subframe connectors (7 replies)
