View Full Version : 12 bolt axle tubes slight curve?
Travis104
09-01-2016, 04:47 AM
Hello,
I picked up a 12 bolt posi trac for my 68 Camaro. The axle tunes look like they have a slight curve to them. I wasn't sure if this was intended, so the weight of the car would make them straight, or if they have been warped by people welding on different brackets?
F-Body International
09-01-2016, 08:13 AM
Could be from welding on brackets if that's actually what happened. In order to fix this, you will have to cut the tubes and reweld in a jig so all the bearings line up. Careful though, many axle tubes aren't straight from the factory as well. There is an amount that is considered OK...
raustinss
09-01-2016, 08:23 AM
They can be saved if you have the right inserts ,bar and know a little bit about welding and heat ...
mitch_04
09-01-2016, 08:57 AM
In a book I once read (Chassis Engineering?) they talked about having adding a slight amount of toe-in to rear axles by heating up the front center of each tube cherry red, then letting it cool. Once it cooled, it would shrink just a bit (1/2 degree toe if I remember). You could apply the same method to trying to straighten your axle tubing.
garvir
09-01-2016, 02:27 PM
NASCAR runs a little negitive camber on their rearends, in fact when they do a inspection, they check the angle, i think they are only allowed two degrees. after that they can start having problems with the bearings.
