View Full Version : Ride tech Level 1 work with chevy 10 bolt?
camarodude87
07-03-2016, 03:36 PM
Might be a dumb question, However I was curious if the Ride tech level one kit will work on a chevy 10 bolt?. I have read on the Speedtech forum that their Camaro GT suspension kit will work with "12 Bolt". Just curious if that would include a 10 bolt. Thanks for looking.
Ray
camarodude87
07-03-2016, 03:41 PM
I just saw on speed techs tq arm kit it gives the option for a 10 bolt.
csouth
07-03-2016, 03:49 PM
The 10 and 12 bolt housings are dimensional the same. The only reason why they need different versions is because of how the torque arm bolts to the rear and the bolt spacing. This is why they have to have a 12 bolt, 10 bolt, and Ford 9"version.
camarodude87
07-04-2016, 08:07 PM
The 48 Hr camaro vid on youtube mentions that if you had a 10 bolt you "should" sell and get a 12 or 9 bolt. This true? Can I not use my 10 bolt. I am referring to using Ride techs 4 link.
Mark Antrim
07-05-2016, 04:25 AM
I have the ride tech 4 link bolted to a 8.5 10 bolt. I think they are referring to the 8.2 10 bolt which is a weaker rear end. If you have any kind of hp you probably should upgrade at that time if you have the 8.2.
Josh@Ridetech
07-05-2016, 06:14 AM
There aren't any issues with the 10 bolt fitting in the car, the brackets are all the same as well.
camarodude87
07-05-2016, 07:41 AM
Thanks for the Reply Mark & Josh
Not all 8.5 10 bolts are the same, the early Nova is different from the 2nd generation Camaro rear.
hifi875
07-05-2016, 02:15 PM
i have beat the snot out of my 8.5 10bolt for 15yrs. nothing wrong with them at all
