Bklatt67
11-06-2016, 12:06 PM
Hi All,
I have a 67 Camaro with the full Hotchkis kit. 2" drop springs in the front, 1.5 drop in the rear. After i set the car down initially a couple of years ago when I installed everything, the rear was too high. I ended up throwing some 1" drop blocks in there to correct it and make the stance right. At this point, i need to pull the rear end apart for some other upgrades/changes, and i want to replace the leaf springs with 3" drop so that i don't have to run spacers to get the ride height correct. So, here's my question. Is there any advantage to the Detroit Speed leafs over the Hotchkis? My first inclination is to go with Hotchkis since everything else is from them, however, i can't seem to find a set that doesn't include hangers, u-bolts, and other stuff i don't need. They are also $490 vs DSE's $385, probably due to the extra parts i don't need.
So, $100 obviously isn't a huge deal on a project of this scope. Should i just stick to Hotchkis for the springs to match everything else, or are the DSE springs better? Anybody have any experience with both?
Thanks in advance,
BK
Thanks in advance,
BK
