Juzzy
08-24-2016, 03:53 AM
Hi
Something doesn't seem right with my measurements and I was hoping someone could help me. I'm in Australia so It's hard to call into a vendor to ask questions.
I have roughed in my Speedtech Torque arm without the 3rd member to check clearances on my 68 Camaro and noticed that I only have around 3.5 inches between the diff housing and frame rail - metal to metal, with the shock at full extension. I have the viking C205 with a total stroke of 3.82" and this was supplied with a 10" 225lb spring.. (even though viking recommends a 9 inch spring for this shock). Viking recommends that 60% of the shock be used for travel with around .5" to go as it hits the bump stop, so as not to bottom out the shock. that basically only gives me 1.97" of travel before the diff housing hits the frame rail... and I still have to get a bump stop in there!? The smallest bump stop I can find without cutting is 1.8". The car is minitubbed, so I can't use the standard bump stops. The shock is in the bottom mounting hole in the diff housing brackets. I could move it up one, but that would basically raise the whole car.
I know alot of people have set these up with Camaros, so wondering if I'm doing something wrong or hoping someone from speedtech can give me some feedback.
Cheers.
Cheers.
