View Full Version : B-body spindle "kit" for 68-72 GM A body - a sad tale!!
71OLDS
11-30-2016, 04:22 PM
So it’s not exactly on the level of the 2008 financial crisis but it’s a sad tale none the less! I’m referring to the B-body spindle “kit” for a 68-72 GM A-body that was all the rage and had quite the sales pitch going back to around the turn of the millennium. My 1971 Olds 442 stock suspension geometry puts the front wheels like this (if you look at the car from the front): \ / The problem with that (as the sales pitch went) is the car is already “set up to lean” before you even go into a corner. Want to see a video that shows that lean? Here you go. Watch the slow motion part going in and out of the cones. Note the top of the tires are leaning “into” the turn before the turn even starts. Love this video BTW – basically my car but with black stripes, top, and green interior. OK and it’s a W-30 (mine is “just” a 442) but it’s a great video to show what the stock suspension does on hard corners. This is how I drive my car ALL THE TIME in case you were wondering!! 
https://www.youtube.com/watch?v=qzBOsbcvOxk
Over a decade ago the big “fix” for this was to go with the B-body spindle “upgrade” which of course also required you to get aftermarket upper control arms and oh while you’re at it you might as well upgrade to bigger brakes. But of course you need bigger rims/wheels to fit those bigger rotors since my stock 14 or even 15” repro wheels can’t hold a 13” rotor. There just isn’t enough room. So if you’re like me maybe 15 years ago you bought B-body spindles, upper control arms from say Hotchkis or Global West, plus why not get the lower tubular control arms too, then a nice set of 4 wheel disc brakes from Baer or Wilwood for example (let’s say 13” front and 12” rear – most weren’t doing 14” rotors back then). Then to fit these big breaks you probably upgraded to let’s say a nice set of 18” wheels maybe 18x8 front and 18x10 rear with some wide tires to help with both cornering and traction in the rear. Maybe 255s front and 305s rear. And let’s throw in some nice sway bars front and rear, better springs or coilovers, and some high end adjustable shocks…oh yeah and a quick ratio steering box for good measure.
After all that you would think you are ready to take your 4,000 lb car and compete in the corners with the new Mustangs, Corvettes, Camaros….might as well throw in Nissan 350Zs and even Porches too….but is that really the case?
The problem is what no one told us back then is all the negatives that came with that first piece of the puzzle – the B-body spindles!! It felt like the car was cornering much better but was that just the wider rims/tires with smaller side walls, stiffer springs, better shocks, and meaty sway bars not to mention my quick ratio steering box? It feels like I can corner better but something doesn’t feel quite right when I REALLY get into a corner hard. Plus doing U-turns or even parking the car felt like something was slightly off. Hmmm maybe it’s just the alignment isn’t quite right. There are lots of aftermarket parts on there. Getting the alignment perfect will take some trial and error right? Or maybe it’s the bigger tires? After all the car just went from 14 or 15 all the way up to 18” right? What I tell myself is at least I know my suspension geometry is good now because the B-body spindles make the car look like this: / \ from the front now so going into a turn the car isn’t already set up for leaning like it was stock (in the video) but…..what we were NOT told over a decade ago about the B-body spindles was all the negatives:
1. They are really heavy – about 14 or 15 lbs. each!
Here's a pic of the stock spindle set up (top) vs B-body bottom - you can see it's taller but also much heavier than stock:
https://static1.pt-content.com/images/pt/2016/12/YtPHMGc-1.jpg
2. Even with the custom upper tubular control arms, the steering arms put the tie rod ends in the wrong location – meaning an A-body car like my 71 442 starts out with massive bump steer (about 1.5” of total toe change over 6” of suspension travel) caused by the vertical misalignment of the outer tie rod ends.
3. The steering arms are also 1” longer than stock. This slows down the final steering ratio making the turning radius much larger. So trying to make U-turns in my 442 isn’t as easy as it should be and that 12.7:1 quick ratio AGR box I spent $500 on doesn’t feel very quick!!
4. Then there is the Ackerman error – which is a fancy name for something that causes a lazy turn in when cornering and more tire squeal when you’re just slowly trying to park your car. Apparently the B-body spindles make that worse too.
The bottom line is the B-body spindle conversion actually DOES improve the suspension geometry of our old muscle cars but it adds weight, trashes the steering geometry, steering ratio, and Ackerman.
So what are we (those of us with 68-72 GM A-body cars that have the B-body conversion) supposed to do now or what options do we have if any? I have spent lots of time researching this and spent several hours talking to Mark Savitske at SC&C. As a matter of fact I “stole” most of the details here either from our conversation or from info I found online or on his website. To be clear this is NOT an advertisement for him and I don’t work for his company!! Haha… Just putting it out there. I’m sure some of this written here is not 100% correct but I think most of it is pretty close. Here are the options available today as I understand it:
Option 1: Do nothing and live with the known issues of the B-Body spindles. I think there are lots of us out there that have been doing this for years anyway. Obviously the cars can be driven like this. It’s just sad the lack of performance for what we paid.
Option 2: The cheaper “fix” is to go back to your stock spindles and go with a taller ball joint (instead of taller spindle) for the suspension geometry improvement but if you already have moved to the b-body spindles you will then have the wrong upper control arms and your rotors won’t fit. Did you keep all that stuff from over a decade ago? I certainly didn’t. Plus I would feel like I was going backwards to start putting all the stock 1971 parts back on but apparently if you do it in combo with the taller ball joint it will be better than the B-body spindle option. How sad is that? Make sure you get more details for this option if you go there because there’s more to it than just the taller ball joints but since I’m not going to do this option I didn’t investigate much further.
Option 3: The best option as far as I can tell and of course the much more expensive option is to go with the AFX spindles (replacing the B-body spindle), compatible adjustable tubular upper arms (replacing your Hotchkis or GW B-body compatible arms), and then swap out your B-body rotors for a set of AFX compatible rotors. All for the low, low cost of about 3 grand (around $2k for the spindle kit and control arms and another grand for the Baer 13” GT rotors that go with the AFX spindles)!!
So for $3k what benefits would you get?:
1. The AFX spindles are aluminum and only 3 lbs. each!! How about dropping 7 lbs. off of each side (aluminum spindle is much lighter but hub is heavier. Net drop is 7 lbs from B-body to AFX spindle including the hub)?
2. The AFX spindles give you the same improved suspension geometry as the B- body spindles {so using the old sales pitch / \ explanation above – the car is NOT set up to lean into the corners like it is with the factory suspension (\ /)}
3. The steering arm mounting holes have been relocated for near zero bumpsteer
4. The kit for my 71 442 would include the factory 68-72 GM A body steering arms not the 1” longer ones that caused some of the issues with the b-body spindles.
5. All kinds of other nice features can be found explained on the SC&C site with their “street comp” kit.
Bottom line is “have your cake and eat it too” for lots of $$$. You get the suspension geometry and steering geometry solved with one set up. Very little car lean in corners, near zero bumpsteer, and greatly improved steering . That 12.7:1 steering box should REALLY feel like a quick ratio now. No more lazy turn-ins when doing hard cornering or squealing tires when you’re parking your car and let’s not forgot the 22 lb. drop in weight for the front end!!
For all of us with the B-body setups still on our beloved muscle cars, is it worth the $3k price tag? Hmmmm?? I guess that depends on each one of us and how much we care about cornering/steering. I’ve read about several guys with the B-body setup that say they don’t notice any issues. I like to corner REALLY hard in my car and it always felt like something was not right but I thought the alignment might be slightly off or maybe my 12 year old AGR steering box just needed to be rebuilt or replaced. After learning about all this stuff I now understand all the negative steering geometry issues I’ve been experiencing. I’m leaning toward dropping the $3k and seeing if I can really have my 442 corner like a Porsche!! Actually I’ve never driven a Porsche but my wife’s car is a 2004 Nissan 350Z. If my 71 442 could corner, turn, make U turns and feel as good as it does, I would be a happy man!!
Sorry for the long post but I thought this might be helpful for others. I couldn’t find one place that really broke all this down so I figured I would write it all out myself. It actually helps with trying to make my decision for dropping all that $$$.
Oh cough cough….anyone want to buy a complete B-body kit for a 68 -72 GM Abody? Will be selling my B-body spindles, Hotchkis tubular upper control arms, & Baer 13” rotors as a set once I make the change!! 
-Joe
SD455
11-30-2016, 11:44 PM
Seems like it's not $3k for the AFX kit if you buy it here?
https://m.summitracing.com/parts/clp-6474swbkstc5/none/images
71OLDS
12-01-2016, 12:27 AM
Thanks for the info. Unfortunately that does not include the adjustable control arms which is a big part of the kit. For the GM Abody the steering arm mounting holes have to be relocated in the correct spot to prevent the bump steer and you need the correct steering arm too. It's all ready to go with the SC&C Kit. If you only get the spindles and rotors you're still missing some really important custom designed pieces. Also the description shows them as "cast spindles". The SC&C spindles are aluminum which is why they only weigh 3 lbs.
csouth
12-01-2016, 07:09 AM
I think the verdict is still out on the CPP spindles. One reason is that no one has taken the time(don't know if they care to) check the geometry. These spindle could be on the same geometry specs as the Speedtech/ATS AFX spindle, but what the Speedtech \ATS has is its own steering arm. So while the CPP spindle is using a stock piece, the AFX is using one designed specifically for that application.
As you can have cast aluminum and cast iron, the CPP are cast iron and the ATS is forged which makes them stronger and lighter.
Twentyover
12-01-2016, 09:18 AM
Inferring that the spindle has stock ball joint separation, since the description includes"They are designed to work with factory, as well as Classic Performance Totally Tubular and other aftermarket control arms" Thta means, to me, no good negative camber gain in roll
djfxall
12-01-2016, 10:05 AM
almost cheaper to buy a C4 corvette then a set of spindles Hmmmm
csouth
12-01-2016, 12:30 PM
Agreed, I would think they are stock height and not tall spindles. If I didn't have ATS spindles, I would do a tall stock style spindle like Ridtetech over a cast C5 type in the same budget... just me. I think the OP is heading in the right direction.
pitts64
12-01-2016, 02:43 PM
delete, off topic..
Twentyover
12-11-2016, 08:51 AM
Been thinking about this some since first read. I wonder if there isn't an intermediate compromise that doesn't bust your wallet re-buying stuff.
The B spindle improves the negative camber gain in compression (and roll), the issue is that steering geometry sucks. So how to improve steering geometry of the B spindle? With brakes, kits like Kore 3 hack the caliper mounts off and replace it with a bolt on caliper bracket. Can the same deal be done with with the steering arm? Hack it off and screw a shorter arm designed for the application to the upright?
Just thinkin'. Ill go back to beer drinkin' now
pitts64
12-11-2016, 10:43 AM
Sc&c...
Jeff70
12-11-2016, 12:46 PM
Have you done any research on the DSE spindle and control arm kit? FYI Tom Lee's company is up and running again selling and rebuilding steering boxes.
djfxall
12-12-2016, 05:53 AM
Is the DSE Spindle available separate seems like a similar expensive cost at $1800 with tubular A-arms which is better then the $1600 that the other spindles cost alone. Spindles should not cost more then a forged light weight crank. LOL I feel the problem here is everyone wants a bolt on solution. Sure minimizing bump steer is great but I feel the whole idea of a holy grail spindle is not the answer are they nice yes but guys who run on a race track every week are not putting money like that into spindles. It is almost cheaper to relocate the rest of my steering to fix bump steer then buy into the whole expensive spindle deal. I mean I see the benefits of them and there sales points and even where the cost is to produce them. But I feel people need to back up and take a more realistic approach then throwing money at it.
Jeff70
12-12-2016, 05:57 PM
I'm a newbie and also own a 71 Cutlass conv which is in need of a suspension overhaul. I figured since Kyle and Stacy are suspension engineers they would have made some updates to the package the offer for the A-body platform but haven't looked into it as of yet.
It's no C6 spindle but........
http://www.detroitspeed.com/1964-1972-A-Body-products/030104-control-arm-spindle-kit.html
Shawn01754
12-12-2016, 07:36 PM
CCP spindals have been around for 10 years and sold by the bigger race supplies warehouses. Where's the broken parts threads? And dissatisfied customers regarding quality from owners? I would save the cash and buy the CCP, because I set a budget that gets me cruising each and every summer. There's always going to be cheaper knock offs, and ways around a forged part. All the reviews on Summit racing are positive. 7 reviews at a top score of 5 stars and 1 review at 4 stars. I think the ATS guys either paid a bit to much or aren't happy the CCP is within an 1/8" of there part and a cheaper knock off.
ah64pilot
12-12-2016, 10:06 PM
Interested in this discussion. I have global west control arms with del alum bushings, stock spindles, and BMR Sway bar. I will be looking at getting new spindles early 2017 and a brake kit. I'm not racing my car so I don't want to spend a fortune making it a tiny bit more fun to drive. It's pretty fun as it is.
DreKoushRanada
12-13-2016, 07:36 AM
I went with the Ridetech spindles with the level 2 coilover system. Can't speak on the ride quality yet because I have not installed it. I will be running brembo brakes from a Camaro SS 5TH Gen I got for a great price.
jake72ss
12-13-2016, 03:20 PM
I recently sold my 72 Chevelle that I had put the tall spindle swap on years ago and yes it had its problems. At the time I completed the swap I used 15" wheels and tires same ones I had with the old stuff. And by the seat of the pants I thought I was driving a Porsche, at the time( before I had actually driven a Porsche). Anyways I remember reading in a Chevy Hi Performance at one point that stated Hotchkis was developing a spindle that had the B Body height and spindle pin with the provision for a bolt on steering arm so you could have the best of both worlds i guess. I think that idea never materialized due to the other options that came around about that time. One thing I always wanted to see was an unbiased test of all of the bolt on "solutions" just to quantify the change/improvements offered. Personally I would like to see a fabricated B Body replacement spindle that uses Howe/Vogel spindle snout and hub like the style No Limit uses for the sniper F body chassis, and that corrects the bump steer and ackerman problems.
my $0.02
Jake
analyte
12-13-2016, 04:39 PM
I swapped out my stock spindle with tall ball joint setup to the Ridetech Spindle, control arm, and TQ Coilovers this summer. All my Kore3 brackets bolted back on for the Z06 calipers so that was a non-event. The only conflict was my sway bar end links that had to be changed for more clearance.
All said, I'm very pleased with the swap. The handling feels more direct and precise, plus Ridetech was available for all my questions during assembly. I definitely recommend Ridetech for your needs as their complete system just flat out works well together. Give them a call and ask for Rodney which is who I worked with on my parts and he was great.
Kerry
csouth
12-13-2016, 07:13 PM
I think the company is CPP... The CPP C5\6 spindle has not been around for 10yrs, try 4. The ATS guys didn't pay too much, they paid what it costs to R&D\Engineer a new part that was not already available. All CPP did was copy a forward thinking design. No one knows the specs on the CPP part because they don't even know, but I bet Speedtech can tell you everything about the ATS spindle. Heck, I asked CPP for a spring rate when trying to help a friend and they couldn't even tell me that.
For what its worth when buying a performance suspension parts I'm not putting my faith in reviews from Summit racing that say "great fit, easy to install.." "Fast shipping Summit.." I want feed back from people that are actually using the part...
71OLDS
01-24-2017, 11:04 AM
Update - Just purchased:
**Street comp AFX spindle kit from SC&C that includes the forged aluminum AFX tall spindle with C7 Corvette hub and bearing pack, stock A body steering arms, and adjustable upper controls arms - will be going with the "aggressive street" settings/alignment.
**Baer GT 13" GT rotors that are compatible with the AFX Spindles
**Lee 800 steering box 12.7:1 at 1275 psi to match my hydroboost and current pump
**SC&C heavy duty tubular chassis brace to help "triangulate" the front frame horns to improve steering response and chassis stiffness - this was a must with my convertible and the entire front end being fiberglass (fenders, bumper, and hood) - needed something for additional support. The frame and glass panels deflect and move too much right now plus the steering box is just hanging out there imparting all it's steering load on just one frame rail. This chassis brace will eliminate all these issues.
My B-body spindles, Baer 13" track rotors, Hotchkis B-body compatible upper control arms, and my 12 year old leaking AGR steering box will all be coming off.
AK-69
02-19-2017, 04:59 PM
Global West just started making a modular spindle that that fixes the bump steer problem
downl50
02-20-2017, 01:27 PM
Great thread -- been thinking about updating my GW control arm/B body spindle/brakes and just starting to look at what's out there. I'd love to hear how the AFX stacks up against against Ridetech or GW's setup with their spindles.
This SC article measures the bumpsteer in GW's new spindle vs. B-body -- seems compelling!
http://www.superchevy.com/how-to/chassis-suspension/1609-the-truth-about-bumpsteer-and-what-you-need-to-know/
71OLDS
03-13-2017, 02:47 PM
Nothing but frustrating delays on everything. Front end parts and 6 speed trans were both ordered 7 weeks ago. Tremec stopped making the Magnum 2.66 6 speed for 5 weeks so mine finally shipped today. Then I got an update from SC&C that the company that makes the aluminum AFX spindles won't have another run of them completed until end of April at the earliest which means they won't be assembled and to me until May/June time frame. Unfortunately the B-body spindles and my old rotors will have to go back on for now until these spindles are finally ready. Will have the chassis brace, SC&C adjustable upper control arms, and Lee 800 box installed this go round but will have to wait on AFX spindles and GT rotors until I finally have the spindles.
killer69
03-16-2017, 11:24 AM
You are correct and this is not an excuse just the facts. we had a po in with the forging company in early november the 5th to be exact. knowing they take 4 months to get the forgings done (don't ask me why it takes that long, i haven't been able to figure it out in the last 9 years) comes to mid February and the call comes in sorry material has been delayed you wont see your order till end of MAY, that is unacceptable. so i said i will supply the material. Nope that will double the cost............... then march 1st ish they call "Oh your material showed up "SHOULD" be able to have your parts by the end of April. that is all dependent on Boeing or some other huge company sending in a rush po. so Anyway we had a huge run on the spindles in nov and dec which really messed up the timing and available supply. and that is why you are now having to wait. we are sorry and are doing all we can to get them in boxes and out the door asa they show up. but people keep ordering and the list keeps getting longer and longer. a good problem to have in one respect hang in there.
Blake Foster
beater65
03-16-2017, 12:53 PM
Blake Foster
Cool to see business take time to comment on threads and give people the real deal situation.
Still sucks for consumers, but certain things are just out of our control as seen here.
71OLDS
03-16-2017, 01:41 PM
Good news for a change - Mark at SC&C had a customer change plans and return a set of AFX spindles and luckily I was first in line - They will be arriving at the shop next week. So I don't have to wait until May/June now on anything but the aluminum steering arms unless Mark can get them to make a few sets earlier (apparently there are 3 or 4 people with AFX spindles w/o the aluminum steering arms). If not will have to go with the stock steering arm until the aluminum ones are made with next run of the AFX spindles. Will still have the bumpsteer unfortunately until the steering arms are swapped out but at least I will have the AFX spindles installed, the new GT 13" rotors installed and several of the negative issues from the b-body spindle set up resolved.
killer69
03-17-2017, 09:55 AM
we have Steering arms in stock. But since we were holdng the arms to ship with the spindles until we hear different from SC&C ??? i will send him a note letting him know again.
lt1cutlass
03-17-2017, 12:56 PM
I ordered steering arms two weeks ago from summit. I called yesterday to get an idea on when they would be shipping and was told they were at the powder coasters. I didn't know they were in stock, can you confirm this? I already have your spindles. Thanks ,Mike.
71OLDS
03-18-2017, 10:22 AM
Wow thanks Blake - hoping that means Mark can send me a set of the aluminum steering arms when he sends my AFX spindles - that would be huge. I will follow up with Mark next week to confirm.
-Joe
71OLDS
03-21-2017, 09:51 AM
Great news as Blake already suggested - Mark from SC&C confirmed today the aluminum steering arms are available now and will be sent to the shop with my new aluminum spindles. Now everything can be installed this go round instead of installing stock steering arms temporarily so really happy about that.
71OLDS
03-27-2017, 02:29 PM
Lee 800 steering box and new chassis brace are on:
https://static1.pt-content.com/images/pt/2017/03/Y54OgRN-2.jpg
https://static1.pt-content.com/images/pt/2017/03/VpijkXr-2.jpg
downl50
03-28-2017, 08:58 PM
https://static1.pt-content.com/images/noimg.gif (http://s303.photobucket.com/user/jl71442/media/20170327_154855_zpsrjn4ccii.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s303.photobucket.com/user/jl71442/media/20170327_154819_zpsgcjdeneb.jpg.html)
That's the SC&C brace, right? It looks like it tucks up much better than I'd previously seen. Very curious if you have any clearance issues on the road -- I'm highly considering.
71OLDS
03-29-2017, 06:22 AM
Yes it's from SC&C - won't have it out on the road for several weeks since the 6 speed, spindles, and roll bar all still need to go in but I will provide an update on how everything drives here - good or bad. Not sure where you think there might be clearance issues. Do you mean ground clearance or maybe lock to lock steering?
71OLDS
04-10-2017, 08:44 AM
AFX spindles, steering arms, upper control arms, and GT rotors are installed:
https://static1.pt-content.com/images/pt/2017/04/7kVsCHa-2.jpg
https://static1.pt-content.com/images/pt/2017/04/BFjMJit-1.jpg?1
71OLDS
09-29-2017, 02:49 PM
Updated pics on this post that were blocked - gotta love photo bucket. Hoping to have car back on the road around mid-October - we'll see.
