View Full Version : Suspension
- fays watts installation (28 replies)
- truck arm rear suspension - 57 chevy (11 replies)
- Bump Stops? (2 replies)
- C5/C6 corvette hub bearing bolt pattern (5 replies)
- Airbar Cradle INSTALL PROBLEM.. (8 replies)
- sway bar bracket snapped! need help (21 replies)
- Any PSC Motorsports Dealers? (0 replies)
- Adjustable rear shocks (3 replies)
- Improved performance (0 replies)
- Reverse roll center... (7 replies)
- PTS: Ridetech December Special of the Year! Free Shipping, Select Rebate, and 10% off (0 replies)
- Poly rear diff housing bushings bad for handling? (5 replies)
- SC&C or Ridetech (29 replies)
- Suspension package for a -69 Bird! (0 replies)
- 1967 - 1969 Mustang IRS or Solid???? (9 replies)
- Triple watts link? (12 replies)
- AFX Tall Spindles compatible with KONI Classic ? (6 replies)
- Building scratch frame (12 replies)
- Bolt-on Subframe Connectors and Fuel Line Interference (3 replies)
- Control Arm Bushing question (13 replies)
- Is there something wrong with my AFX-spindels ? (11 replies)
- v1 G-bar 19" vs 18" wheel (3 replies)
- good books on suspension design? (7 replies)
- Which GM Type 2 PS Pump for use with Hydraboost? (0 replies)
- A-body SPC adjustable UCA Delrin Bushings PICS! (14 replies)
- Improving GM's suspension, 64 Riviera (30 replies)
- Tall upper ball joints VS tall spindles? (9 replies)
- Noob with a Griggs GR350 questions (15 replies)
- Rainy Day suspension basics...Nice rear end! (4 replies)
- 72 nova and truck arms, spring rate needed (12 replies)
- 67 Camaro Tie Rod ends contacting inside wheel (3 replies)
- Thanksgiving Weekend & Cyber Monday sale at UMI, 15% off all items (10 replies)
- 4link questions for 2nd gen TA (14 replies)
- Thanksgiving weekend sale @ bmr suspension (1 replies)
- Stock 69 Camaro with rear air shocks. Looking for suggestions on ride height... (0 replies)
- satchel link in 65 mustang (14 replies)
- Front End Lowering Concerns (5 replies)
- what rate front springs (2 replies)
- Help identify my rear syspension (11 replies)
- steering help! need help finding a banjo fitting (15 replies)
- Help With Designing New Front Suspension for 71 Javelin Road Racer (18 replies)
- M9 back brace? (6 replies)
- Adding fluid to rear end (2 replies)
- need help with hotchkis leaf springs (10 replies)
- Suspension package for GM A-Body 70 Chevelle (15 replies)
- Rear Suspensions for 78-81 Camaro (40 replies)
- Rear coilover mounting? (3 replies)
- How do you extend the QA1 Shocks? (6 replies)
- Proforged '69 Camaro SEMA subframe (5 replies)
- Best steering box for a pro -touring 1966 skylark??? what are you guys running??? (8 replies)
- "B" body spindle on "A" body 1966 gm (8 replies)
- Suspension vendors? (21 replies)
- UMI G-Body Upper A-Arms w/ 1/2" Taller Ball Joints & Camber Curve Data (12 replies)
- 1969 camaro/firebird steering questions (9 replies)
- Lowering 68 torino (2 replies)
- 67 Mustang Torsional Rigidity Test (1 replies)
- Three questions in one... Rear end. (6 replies)
- A or G body ? (9 replies)
- Affordable1966 mustang coupe ifs (8 replies)
- Rear Diff Mounting Issue - Flex Form Leaf Springs (14 replies)
- SPC Upper A-Arm Installation Issue? (22 replies)
- 74 NOVA Spindle question (2 replies)
- SPC upper A-Arm question (13 replies)
- bmr TORQUE ARM SUSPENSION KIT (9 replies)
- Need pics of 1" drop springs vs 2" drop spindles. A-body (20 replies)
- Ridetech strongarm control arm question (6 replies)
- 350z rearend/ 67 camaro (165 replies)
- Plan was AM chassis but if it seems I can get similar results w/ bolt ons? (15 replies)
- 68 Firebird street suspension. (7 replies)
- need some help front suspension (6 replies)
- Hollow sway bar?.... (19 replies)
- boxing frame on chevelle (5 replies)
- rack&pinion upgrade for second gen camaro (31 replies)
- 2nd gen manual steering box (2 replies)
- what do you guys think of this suspension setup? (5 replies)
- '69 camaro coil overs (3 replies)
- 69 impala chassis stiffening (4 replies)
- Getting a 69 camaro to handle...on a budget (7 replies)
- Kevin Miller's 69 camaro W/Ride Tech (2 replies)
- New ProForged Upper Control Arms (23 replies)
- Bolt on parts compatibilty issues...do we need a STICKY? (2 replies)
- Suspension geometry information. (3 replies)
- Ford Hub on s10/g-body Spindle...Possible? (5 replies)
- frame weight (2 replies)
- 65 gto can not align (16 replies)
- Suspension plans for my G-body (20 replies)
- 3rd gen steering box for 69 Firebird (2 replies)
- Bad Ast steeering u-joint/intermediate shaft construction WELDING? (4 replies)
- G Link Spring install HELP (16 replies)
- Can I bend the steering arms inward? (23 replies)
- 66 mustang 1.5 inches to stops is that ok? (7 replies)
- IRS - center section (5 replies)
- Fastener Tech for Suspension Bits (16 replies)
- 4 link setup,link bar sizes (3 replies)
- PT '73 Grand Am Suspension Changes...Would like advice! (0 replies)
- Removing upper control arms without removing headers? (7 replies)
- ride tech e3 problem (1 replies)
- Rainy…uh, make that SNOWY day Suspension Basics. Lets Hit the Bars! (10 replies)
- alignment issue (14 replies)
- BMR rear suspension setup for '78 TA (6 replies)
- Koni Coilover Shock (0 replies)
- 2 inch versus 3 inch drop - 67 Camaro (16 replies)
- Should I align frame before welding SFCs in first gen? (24 replies)
- Anti-Roll Bar Drop Links (13 replies)
- Will Hotchkis Max handle bars work with Anvil Carbon inner fenders? (6 replies)
- Lowered suspension questions on a 83' Elco (4 replies)
- Suspension Hardware: Nuts and Bolts (6 replies)
- 1969 Camaro body on 2007 Corvette Chassis??? (3 replies)
- suspension help (24 replies)
- Rrear seat belt hump 2-gen F-body (3 replies)
- Detroit Speed And Engineering Mustang Parts (56 replies)
- Leaf Springs for 2nd gen T/A (17 replies)
- Which allows the most back space with 17" wheels, AFX or Proforge (6 replies)
- ididit column in 1st gen camaro - install questions (13 replies)
- IRS in classic mustang (12 replies)
- satin or semi- gloss powder coat for frame? (0 replies)
- Late 2nd gen camber gain curve (help) (14 replies)
- AFX Spindles + GW UCA (CTA79-AP) does it work ? (13 replies)
- Suspension 101 (14 replies)
- 67 GTO Front Suspension Advice (16 replies)
- coilovers for 68 tempest (2 replies)
- UMI Performance Stage 3 handling kit (4 replies)
- Monotube Eddy IAS vs. Monotube single adjustable (1 replies)
- 4 link for a1968 camaro,what u guys suggest? (21 replies)
- Front airbag position (0 replies)
- 3rd link offset?? (32 replies)
- Watts link bar lengths? (11 replies)
- 67 Camaro diy 3 link. (47 replies)
- Power steering pump upgrade time (4 replies)
- Ridetech Upper Control Arm/Ball Joint Problem (13 replies)
- Corvette Power Steering Pump & O-Ring adapters (1 replies)
- PLEASE HELP. Steering Arm Cracked! (1 replies)
- Shocks for live axle? (4 replies)
- 84 g-body frame boxing (7 replies)
- rear sway bar attachment differences (0 replies)
- GM A-Body Budget Ebay Tubular Control Arms...Have you used them?? Feedback?? (16 replies)
- Speedtech High Clearance UCA's (1 replies)
- Hotchkis 3" drop leaf springs (8 replies)
- 1966 A-body tall ball joints & 15" steel wheels (5 replies)
- C5 and C6 Transmission mounts - Is the rubber isolator the same? (0 replies)
- Tall Ball Joints, is Proforged the only option? (24 replies)
- sway bar setting for drag racing (5 replies)
- Drop Spindles and Control Arm Compatiblity (11 replies)
- Rod Ends in the Steering System (4 replies)
- 3-Link Build (14 replies)
- Drop Spindles and Control Arm Compatibility (0 replies)
- 2nd gen DSE Subframe and headers (12 replies)
- varishock or ride tec air springs? (3 replies)
- Hotchkis Lowering Springs and Ridetech Spindle? (2 replies)
- Custom front suspension for lowly ranger (12 replies)
- Hellwig 1-5/16 tubular front sway bar vs oem 15/16 dia solid bar A-body (2 replies)
- Ridetech stuff on Craigslist... (2 replies)
- Rainy day suspension basics...let's get LOW. (56 replies)
- rear end "stepping out" (1 replies)
- Power Steering working only sometimes? (5 replies)
- Hotchkis GM Full-Size Car Show and Open House (Oct 22, 2011) (6 replies)
- RideTech CoilOvers and SpeedTech Control Arms (16 replies)
- Ride Tech True Turn and Coil Over Conversion Install At Prodigy Customs (16 replies)
- Custom 4 link design (2 replies)
- Need help with rear sway bar mount (8 replies)
- 2nd gen coilover conversion (1 replies)
- Speed-Tech vs. Ridetech (14 replies)
- Which Hotckhis 2" Drop Coil Spring for 67-68 Camaro W/ Big Block and Aluminum Heads? (2 replies)
- Why would a spindle bend..... (13 replies)
- Has anyone used global west tublar inner shock tower supports with ridetech bags (9 replies)
- 1979 Camaro Sub-Frame Questions (0 replies)
- Summit tubular control arms (8 replies)
- Panhard bar on Truck Long arm suspension (9 replies)
- C6 rack and pinion in a first gen camaro? (0 replies)
- What is your take on Coil Overs for 1st Gen Camaro? (2 replies)
- Can i do it????? (15 replies)
- questions about prodigy bar. (2 replies)
- Front spring advice for BBC (0 replies)
- ridetech upper control arms (2 replies)
- How to obtain factory suspension information?? (1 replies)
- TCP front coil conversion question (15 replies)
- Pro Touring Suspension (34 replies)
- Camaro steering arms - effect on turning radius (3 replies)
- Looking for some guidance. 68 Fairlane content inside. (5 replies)
- removing a Ridetech air line ??'s (9 replies)
- Best base car to borrow suspension from? (24 replies)
- suspension conversion 01 onto 69 (11 replies)
- Drop Spring or Coil Overs? (4 replies)
- Play in Front End AFTER New Parts (0 replies)
- True benefits of swapping to tubular control arms ??? (26 replies)
- DSE MINI TUB KIT w/LEAF SPRINGS (13 replies)
- Question on Rear End Width for Street/Track Car (11 replies)
- RideTech choices, need to make it happen. (18 replies)
- Positive caster on Tubular Upper Control Arms (7 replies)
- rear end chop (0 replies)
- keyway or press fit--how to tell? (6 replies)
- Suspension help, What do I have here? (5 replies)
- Front Upper control arm help Please! (7 replies)
- Have any ideas on flaming river electronic steering system (5 replies)
- How to swap 3rd Gen IROC Camaro Steering Box into 1st Gen Camaro (11 replies)
- 67 Camaro Control Arm Bolts/Hardware (1 replies)
- art morrison subframe u-joint (6 replies)
- Classic Industries Steering box?? (3 replies)
- help me ID this suspension kit for a 57 chev (2 replies)
- Ridetech Promo Ending Soon... (4 replies)
- Front Shock/Coil-overs: Ride Tech or DSE??? (7 replies)
- early ford handling (27 replies)
- Ride Tech Tru Turn for 67 - 69 Camaro (1 replies)
- TCI Torque Arm vs. Exhaust H-Pipe (1 replies)
- Ebay Upper and Lower arms vs Global West (65 replies)
- C2 suspension guru? (6 replies)
- C5/6 Suspension design help (2 replies)
- How to decrease camber? Hotchkis Arms (7 replies)
- Rear shackle movement (4 replies)
- Wayne due front clip (7 replies)
- Can't Lower Car w/ G-Bar System (4 replies)
- DSE or Speedtech steering (1 replies)
- How to get an A Body El Camino to corner? (13 replies)
- Coil-over conversion sleeves (8 replies)
- 70 Chevelle Speedtech A-Body Track Time Suspension Package (3 replies)
- Bad Ast Suspension Conundrum (14 replies)
- need help w/ new front susp. parts (7 replies)
- Sway Bar Help please (8 replies)
- Installing Tru Turn (44 replies)
- What is the Best place to buy ridetech products? (14 replies)
- BMR Launches New Product - Torque Arm Suspension for 74-81 Camaro/Firebird (0 replies)
- KRC pump (7 replies)
- 67 Camaro idler arm in 69? (0 replies)
- Pinion angle and drive train alignment (9 replies)
- Rookie mistake on steering gear install, striped the threads (0 replies)
- Couple issues I found while pulling the car apart, ideas? (12 replies)
- Hotchkis 3 Link for sec gen Camaro (117 replies)
- RideTech Triple Adjustable Shocks (11 replies)
- X-frame rigidity? (6 replies)
- 79 Malibu Best Donor steering box (4 replies)
- lowering springs (8 replies)
- Is anyone using PRO SHOCKS brand GM coilover conversions? (1 replies)
- Strut Suspension Questions (2 replies)
- Upgraded 1969 Mustang Suspension (5 replies)
- Measuring for Rear Coil Overs (2 replies)
- Power rack retrofit. Geometry question. (1 replies)
- 2nd gen f-body leaf spring perch width? (5 replies)
- Whats a normal steering angle? (16 replies)
- SPC adjustable uppers or RideTech Strongarms? (9 replies)
- 68 mini-tub install cost? (4 replies)
- can 2nd gen camaros handle well with big blocks? (17 replies)
- '68 camaro with tall ball joints (1 replies)
- pro-touring 57 ford ranchero front suspension ideas (18 replies)
- Help, gmod issues possibly (1 replies)
- Rear Suspension and NASCAR 9" for 71 Javelin Project (22 replies)
- Need some GBODY suspension advice (7 replies)
- Has anybody used ENERGY SUSPENSION brand body bushings? (16 replies)
- Wheel alignment problems! (22 replies)
- Rear Circle Track Springs Chevelle help! (6 replies)
- Stock Height (1 replies)
