View Full Version : Rear Diff Mounting Issue - Flex Form Leaf Springs
Bulletpruf
11-13-2011, 01:39 PM
Fellas -
Details on the car - 71 Javelin, 401, 4 sp, 500 flywheel hp, 9" full floater, 3,300# race weight, street legal but just barely.
I removed the AMC 20 rear end in order to replace it with a Speedway Engineering full floater 9" with 1* negative camber. Speedway welded leaf spring pads on the rear for me. I also swapped out the heavy multileaf springs for a pair of composite springs from Flex Form.
The problem I'm having is that the AMC 20's axle tubes were 2.5" in diameter and the 9" tubes are 3" in diameter - - this means that my U bolts are too narrow to fit over the axle tube (shouldn't have a problem sourcing new ones) and the shock/spring bracket that the leaf springs and shocks mount to has holes that are 1/2" too close together. There's not enough material left to drill the holes 1/4" wider on each side.
Options that I can think of -
1. Purchase new or used lower brackets and U bolts that will work for my setup. Any ideas here?
2. Somehow reinforce/build up the brackets and drill the holes 1/4" further out.
3. Figure out how to fab up some U bolts that will fit a 3" tube, but neck down to 2.5" below the tube.
A related question - should I still use a rubber pad between the leaf spring and the bracket? Not too worried about a smooth ride, but wondering if it's necessary. Flex Form installed thin hard plastic pads (1/16"?) in the bracket area and apparently that's all some folks use.
Scott
https://static1.pt-content.com/images/pt/2011/11/100_2157-1.jpg
https://static1.pt-content.com/images/pt/2011/11/100_2180-1.jpg
https://static1.pt-content.com/images/pt/2011/11/100_2192-1.jpg
https://static1.pt-content.com/images/pt/2011/11/100_2193-1.jpg
https://static1.pt-content.com/images/pt/2011/11/100_2181-1.jpg
Bryce
11-13-2011, 01:54 PM
Option 3: I would not do this.
Option 2: This would be easy and you would make it exactly the way you wanted it.
Option 1: Source some mustang leaf pads, but these might not have the correct shock setup for you. They have a hole for the shock mount, so the shocks need to have studs not eyelets.
Bulletpruf
11-13-2011, 02:04 PM
Bryce -
My fab skills are limited; can you elaborate?
Scott
Bryce
11-13-2011, 02:16 PM
Basically a flat plate with the correct hole pattern for the wider space u-bolts and the center pin. Also I would either bend the edges of the plate to add stiffness or weld on a strip on the sides. Also I would weld on a off the shelf clevis to mount the shocks, this will make the lower shock mount a double shear set up instead of the single shear pin that is currently there.
I can draw something up real quick if that would help.
Bulletpruf
11-13-2011, 02:21 PM
Ok, you're talking about fabbing up a completely new bracket. That makes sense. A drawing would be most helpful.
Thanks!
Scott
Bryce
11-13-2011, 02:29 PM
Thanks!
Scott
Here is a quick model I just, just for reference.
exwestracer
11-13-2011, 05:54 PM
Thanks!
Scott
You could also cut the shock mounts off the old plates and weld them back on the new ones with a gusset. That way all you'd have to fab is the flat lower plate and the gusset. Not as good as Bryce's idea, but maybe a little simpler. Either way, it you're not sure about your welding skills, take it to someone who is...
LeighP
11-14-2011, 02:29 AM
What do you think of....split the existing bracket and weld in a section to lengthen it to the right size...redrill the centre bolt hole.
I'd just use the thin plastic supplied in place of the factory pad...the factory was more worried about NVH than performance.
Bulletpruf
11-14-2011, 04:56 AM
Bryce -
Very nice! Now I see what you're saying about the shear.
Thanks for taking the time to create the schematic.
Scott
Bulletpruf
11-14-2011, 04:57 AM
Another good idea. I can weld, but not sure I could get adequate penetration on something this thick.
Scott
Bulletpruf
11-14-2011, 04:59 AM
Yet another good idea. Not sure why I didn't think of that.
Scott
Bulletpruf
11-14-2011, 12:55 PM
Looks like I have some aftermarket options:
Mancini Racing - http://chucker54.stores.yahoo.net/lespshpl.html
Allstar - http://www.summitracing.com/parts/AAF-ALL60036/
Scott
Bulletpruf
11-16-2011, 03:32 PM
I bought a pair of the Mancini's and a pair of the Allstars. The Allstars I bought have a provision for mounting the shock on either side of the axle, which will allow me to run the factory staggered shock setup.
My findings -
The Mancini stuff is well made, weigh 2.558# each, constructed out of .25" steel (gusset is .185"), and have a .71" shock mounting pin. Fit is fine when mocked up.
The Allstar parts are also well made, but a bit heavier at 3.502# (weighed without shock pin), constructed out of .25" steel (.122" gussets), and did not come with a shock pin. Fit is fine when mocked up.
The stockers are surprisingly a bit thicker at .32", weigh 2.334#, and have a .625" pin.
I also ordered some u-bolts from Mancini. Also nice looking stuff. The u bolts are too long by a few inches, but that won't take long to fix.
I intend to use the Mancini parts, but will hang on to the Allstar brackets in case I want to try a staggered shock setup.
Pics follow.
Scott
Mancini and Allstar bits side by side. Mancini brackets are black.
https://static1.pt-content.com/images/pt/2011/11/100_2218-1.jpg
Flipped over. Sorry for the lousy pic.
https://static1.pt-content.com/images/pt/2011/11/100_2220-1.jpg
Mancini mounted.
https://static1.pt-content.com/images/pt/2011/11/100_2222-1.jpg
Pic 2 of Mancini mounted.
https://static1.pt-content.com/images/pt/2011/11/100_2226-1.jpg
Allstar mounted.
https://static1.pt-content.com/images/pt/2011/11/100_2228-1.jpg
Pic 2 of Allstar mounted.
https://static1.pt-content.com/images/pt/2011/11/100_2232-1.jpg
LeighP
11-17-2011, 05:19 AM
They look like a good win.....better than modding the original.
Bryce
11-17-2011, 08:05 AM
Nice find!
