View Full Version : v1 G-bar 19" vs 18" wheel
Turbo67camaro
12-04-2011, 11:52 AM
Has anyone out there been able to maximize tire width using an 18" wheel with a v1 G-Bar setup like this one on Todd's Payback? I have the same setup, and using a Percy's Wheelrite, it looks like I likely need a 19" wheel in order to suck the shock mount inside the wheel lip a bit, although its hard to tell with the Wheelrite exactly where the lip will fall. Todd's using a 19" wheel and I suspect that may be the reason why.
52052
Ron.in.SoCal
12-04-2011, 02:10 PM
Hey Mike - I believe Todd is running 18 rears now. He did initially start w a Boze 19 rear if I'm not mistaken. I'm sure he'll chime in soon!
Turbo67camaro
12-04-2011, 03:02 PM
I tried PM'ing him last night, but his inbox was full.
Vegas69
12-04-2011, 05:36 PM
Mike, you need to move the shock mount in to keep the shock housing from rubbing the wheel lip. I designed some mounting plates made out of 1/4" steel and had them water jetted. You could puruade me to share. ha ha My inbox is cleaned out.
