View Full Version : Suspension
- narrow sway bars (6 replies)
- Narrow rack and pinion (5 replies)
- Whats a decent air ride kit run? (3 replies)
- SC&C UCAs for A-body--how harsh? (6 replies)
- Who Makes Custom Tubular A-Arms? (7 replies)
- Why doesn't this thing steer better? (32 replies)
- 70 nova (4 replies)
- G-body Front U&LCA's installed - Align Specs? (11 replies)
- Smooth bottom cars, Belly pan?? (15 replies)
- Installed Lee 670 Steering Box (8 replies)
- ? about Poly A arm bushings (3 replies)
- Just picked up a 2nd Gen TA, need suggestions (5 replies)
- Rear UCA, A-body. Curretrac or Edelbrock? Johnny joint = Spherical ball? (10 replies)
- 87 IROC rear width? (7 replies)
- Schwartz Chassis question (6 replies)
- F Body Front suspension Upgrade path Thoughts Appreciated (4 replies)
- hotchkis rear shocks (5 replies)
- Center link and tie rod travel (6 replies)
- Camaro / Firebird the same...NOT! (9 replies)
- Type II steering noisy? (2 replies)
- Need First Gen F Body Help (rear suspension) (10 replies)
- Improving my tri-five suspension (10 replies)
- steering box question (1 replies)
- would this work? (5 replies)
- I need suggestions (3 replies)
- Spindle ID (0 replies)
- Installed Rear Swaybar (6 replies)
- Chevelle alignmnet (0 replies)
- Front subframe (12 replies)
- tired of manual steering (6 replies)
- cheap nova (10 replies)
- cheap nova (0 replies)
- Alston Vari Shock Help (28 replies)
- boxing front lower control arms (8 replies)
- Clean Slate! Design me a rear suspension!! (6 replies)
- Bump steer problems - Camaro 1967 (8 replies)
- Front Shocks 68 Camaro - need recommendations (3 replies)
- Tightening spindle nut (6 replies)
- Front A-arm question (0 replies)
- anyone know how to make p/s firmer (17 replies)
- Idler Arm question (13 replies)
- Where can I get a discount price on Global West Bushings etc.? (1 replies)
- pro-touring a 79 firebird (5 replies)
- How to handle without ATS spindles. (15 replies)
- Anybody running dse arms/afx spindle (11 replies)
- short trip to states needs to find air ride - help! (6 replies)
- G-Bar/Air Ride is in the car!!!!!!!!! (12 replies)
- 81 f-body rear leafs (0 replies)
- Spindle Dimensions (5 replies)
- Whos drop spindle on a '70 Nova? (2 replies)
- Cutting floor with G-Bar/Air Ride suspension??? (20 replies)
- G-Body Bumpsteer ....again (5 replies)
- Galvanize a-body frame? (1 replies)
- Pictures of 3 or 4 Links Installed 2nd Gen Camaro (0 replies)
- difficulty of mini-tubbing Camaro - 1st timer (5 replies)
- AM subframe, where to buy (4 replies)
- Heavy duty sway bars from junk yard? (3 replies)
- Steering Issue (5 replies)
- How do I figure out spring rates for my car? (7 replies)
- New QA1 low friction ball joints (4 replies)
- Apex Pro C6 subframe from Jake's Rod Shop (12 replies)
- lakewood bolt on ladder bars? (3 replies)
- g-body bump stops (8 replies)
- Grand Cherokee steering box - sticks (1 replies)
- gotta figure out some freakin' BUMP STOPS! please help! (19 replies)
- Guldstrand Leaf Spring Rubber Bushing Substitution (2 replies)
- 2nd gen circle track trans am (11 replies)
- Calvert traction bars- drag only? (6 replies)
- Suspension Analyzer (4 replies)
- Rear leaf springs for 68 Firebird - LS1 swap (i have two sets which should i use?) (1 replies)
- Chassis Shop? (21 replies)
- Need stock spindle measurements (3 replies)
- G Bar or DSE Quad Questions (25 replies)
- Calculating rear tire loading (1 replies)
- Alignment Work (0 replies)
- cutting front coils (6 replies)
- How to properly lower E Body... (5 replies)
- Eibach 64-67 A-body spring rate part# 3855.140 (2 replies)
- Power steering woes!!!!! (5 replies)
- 67 firebird with dropped spindles/alignment specs? (0 replies)
- watts link bellcrank bearing loads (4 replies)
- Q for 3rd gen novas w/Hotchkis front springs (21 replies)
- Control Arms (2 replies)
- Engine being set back.... (9 replies)
- Does anyone make a C4 drop spindle (2 replies)
- panhard mounts (2 replies)
- Leaf Spring Lower Plate/Perch (4 replies)
- 4 Link Setup Questions... (1 replies)
- What Chassis to use (7 replies)
- how much do i cut? (8 replies)
- how to tell if spindles are bent? (2 replies)
- g-body rear bushings (6 replies)
- Power Steering pump angle? (1 replies)
- Narrowing 85 C4 Batwing for a 36 Chevrolet (5 replies)
- Who has installed dse controll arms (1 replies)
- What are the advantages of tubular control arms (8 replies)
- Eibach Spring Diameter (3 replies)
- triangulated 4 bar or a three link (11 replies)
- Should I ditch the subframe? (33 replies)
- vt customs air ride kit? (0 replies)
- 67 Camaro Rear Shocks? QA1,Varishock, Be Cool? (6 replies)
- Another G-Body Question (34 replies)
- Best bang for the buck under $2500 (2 replies)
- Subframe for 1st gen f body (3 replies)
- 92 mustang steering wheel removal (2 replies)
- My first time! (4 replies)
- Spring Tech Lowering Springs (19 replies)
- drop leaf springs (0 replies)
- How do I lower a 2002 Tahoe?? (23 replies)
- extreme newb! Should I choose my wheels before suspension setup? (4 replies)
- leaf springs, reversed eye (2 replies)
- A-Body Spindle Brake Combo Info (3 replies)
- What type of custom steering shaft (6 replies)
- pitman arm removal-2nd gen camaro (10 replies)
- Lowered G-body's height (6 replies)
- Need pics of DSE lower shock mounts installed (2 replies)
- Panhard bar brackets help.. (15 replies)
- reinforcing lower tubular A arms (8 replies)
- Best deal on DSE Quadralink (8 replies)
- Spindle Axis Inclination-how much (4 replies)
- sway bars on 3rd gen nova (3 replies)
- DES Quadralink [worth it}? (6 replies)
- power steering pulley (2 replies)
- 9" rear vs 12 bolt (12 replies)
- I wanted it low, but this is ridiculous. (40 replies)
- suspension travel (1 replies)
- pull/pushrod suspension (24 replies)
- *HELP* BRP Rack and Pinion Steering sub frame Templete (0 replies)
- Cutting Eibachs? (1 replies)
- Firebird Rear Springs (2 replies)
- A-body frame reinforcement (4 replies)
- Old Topic I'm sure (2 replies)
- will new rear coils settle?? (3 replies)
- how to find coilovers (13 replies)
- WTF!!! DSE 3" Drop Springs = NO DROP!!! (9 replies)
- Heidt's Narrowed control arms? (1 replies)
- Gbar and exhaust compatibility (13 replies)
- Suspension Kit's (6 replies)
- Stick w/3rd Gen Steering or upgrade to 670? (1 replies)
- Stock A-body mods (2 replies)
- Buick Regal stock cars??? (2 replies)
- A-Body panhard bar install question (11 replies)
- How much clearance?? (7 replies)
- S10 tall ball joint questions (3 replies)
- C5 rear suspension specifications "mounting points" (5 replies)
- Rear Drag Shock Question for Nova (3 replies)
- recco's for conv frame stiffening GM a-body? (11 replies)
- Johnny Joints (30 replies)
- third gen camaro coilover q's (1 replies)
- Want to lower my 72 cutlass... (5 replies)
- The Monte becomes a 'Control Freak' (13 replies)
- 66 A-body When to replace original steering parts? What brand to get? (3 replies)
- Brand new question: Delrin bushing clearance (11 replies)
- 3rd Gen Nova Shock Question (4 replies)
- Subframe - fix or replace? (7 replies)
- Why AFX spindle/ Tube LCA (13 replies)
- Power steering line pictures (2 replies)
- Full Tube Chassis? (5 replies)
- looking for lowering springs (5 replies)
- alignment tools (14 replies)
- ATS Billet Arm problem? (3 replies)
- rear sway bar possibilities (1 replies)
- Do coil overs "settle" like regular springs? (5 replies)
- 2nd Gen Camaro Front Coilover Suspension (10 replies)
- g-bar rear suspension (4 replies)
- Opinion on modding DSE LCA (3 replies)
- Air-ride Shockwave alternative (5 replies)
- Sway Bar Help??? (9 replies)
- Front Control Arm Setup (8 replies)
- Anyone run a Griggs watts link? (2 replies)
- 2nd Gen. F-body rear sway bar problem (6 replies)
- De-arching Leaf Springs To Lower? (13 replies)
- Three Link parts: Is this a good shopping list? (19 replies)
- Rebound travel/upper CA bumstop questions (5 replies)
- PLease talk me down before I do something stupid... (7 replies)
- motion ratio on leaf springs (3 replies)
- Issues With SPC Lower Control Arms (38 replies)
- Fatman fabrication suspension (1 replies)
- Chassis mounted rear sway bar Vs Axle mounted ?? (3 replies)
- panhard bar? (16 replies)
- Converting '69 Firebird to Camaro steering?? (1 replies)
- Templates ? (3 replies)
- In Stock-3pc splined rear sway bar for DSE Quadralink (5 replies)
- Narrowing a 10bolt rear (11 replies)
- How tall is your Chevelle? (23 replies)
- DSE Leaf spring Mount w/mini tub (4 replies)
- "Button Head " bolts for fender (17 replies)
- how long do performance suspensions last? (2 replies)
- Every day 4 link??? (3 replies)
- Hotchkis Rear Springs (2 replies)
- Truckarm suspension (11 replies)
- Del-A-Lum bushings (44 replies)
- unisteer power rack (4 replies)
- Measuring subframe for straightness. (2 replies)
- Koni part number (4 replies)
- G-Body Front Setup Solutions - Arms/Coilovers? (6 replies)
- opinion, opinion, opinion? (11 replies)
- Heidt's 1st gen Camaro Subframe (35 replies)
- Greasing Currectracs... (0 replies)
- G-mod and Global West arms? (4 replies)
- Need Help Assembling ATS Spindles & Steering Arms (6 replies)
- Nova Subframe Connector Questions? (5 replies)
- will my suspension settle enough?? (8 replies)
- Air Ride Sway Bar Endlinks!! (5 replies)
- To much play in the steering wheel (20 replies)
- Airride + 4 Link = Traction? (2 replies)
- g-body rear bushings (5 replies)
- rear suspension bushings (7 replies)
- For The Dragracer (2 replies)
- Rearend Gasket Covers Which One? (2 replies)
- Which lowered leaf spring to use? (4 replies)
- Body Mount Bushing Kits - Question? (5 replies)
- 69 Camaro - 07 Corvette 18" x 9.5" Front Rim Issues (16 replies)
- need help finding these A-body diff bearings/bushings (1 replies)
- Need help plumbing a 79 Mustang II R&P (1 replies)
- Airspring application on AME chassis (1 replies)
- big problem varishocks (10 replies)
- 68 Camaro Steering box options for poor guy? (6 replies)
- Remote reservoir pump made from pump w/reservoir? (11 replies)
- FR Powersteering Box - (HERE YE HERE YE - In lies EXCITING post #1) (4 replies)
- Affordable Ford Power steering? (2 replies)
- ame tri 4 bar vs ame 3 link (1 replies)
- Torque specs (3 replies)
- SC & C alignment tool - is this worth the investment? (15 replies)
- Question about installing sub frame connectors (6 replies)
- help on what to copy buy or plans (2 replies)
- Frame Rail Thickness (7 replies)
- 50" Width Suspension (3 replies)
- A-body front suspension - SC&C or ATS? (13 replies)
- G-body front end (10 replies)
- How to install body mounts? (7 replies)
- ATS AFX spindles (4 replies)
- Leaf springs with ladder bar set up (4 replies)
- ididit with an iroc box (no pun intended) (3 replies)
- Rod ends on a daily driver? (20 replies)
- HOWE tall upper and lower ball joints (13 replies)
- Lincoln Mark VIII rear suspension widht? (4 replies)
- 3rd Gen Nova 4 link (1 replies)
- Guys running shorter body mounts.. A problem to look at. After market rack guys too (19 replies)
- 2nd Gen F body rear sway bar help (11 replies)
- Bending Leafs for Ride Height (5 replies)
- Front view geometry input please (4 replies)
- UCA's & LCA's (4 replies)
- Anybody running the HRParts&Stuff rear sway bar? (0 replies)
- 71 chevelle upper control arm ? (7 replies)
- S10 LCAs vs G-Body LCAs (16 replies)
- Front sway bar mounting questions (4 replies)
- Rear sway bar + mini tub!!! (8 replies)
- 63 impala tubular control arms? (8 replies)
- bump stop (0 replies)
