Chadman
02-05-2008, 08:04 PM
Hello everyone! I'm a long time observer of PT Forum, as the collection of knowledge and class of members here is second to none! :hail: ...Until now, I've never really felt the urge or needed to post anything, but after recently hitting a snag... I FEEL THE TIME HAS FINALLY COME!!!
That being said...
I recently did a refresh on all the steering components of my 81 Trans Am (2nd gen, for those not familiar). This included centerlink, tierods, pitman arm, idler arm, steering pump, hoses, and my favorite part (or so I thought) a Flaming River 12:1 steering box.
This box is Part # FR1560 as seen on:
http://http://www.flamingriver.com/index.cfm/page/ptype=product/product_id=330/category_id=191/home_id=80/mode=prod/prd330.htm
So... all steering components go in, box goes in/hooks up perfect. I do the recommended lock-to-lock steering wheel turns to lubricate the box. I drive to a local shop and get the alignment. As I'm driving around, and even well after the alignment/mileage put on car, the box still seems stiff (or resistive) to turning... as though though it were a manual steering.
Does anyone know what the issue could be?
I figure it could be 1 of X things:
1) The box is defective.
Therefore I call FR, sent the box back... There it was tested and said to be in all working order, although the tech guy COULD NOT identify for me if the box was actually load tested. :box2: So who knows.
2) The powersteering belt is not tight and can't cause enough fluid to pump sufficiently.
The belt is fine.
3) I have been told that there is a particular bypass valve in the back of the powersteering pump. It appears (though I no longer have... core refund) that the old pump did not have this. The new pump does? It was also brought to my attention that the FR steering box may not have an internal bypass, that the GM box did possess. (I am not familiar with this and therefore am unaware of the bypass type for either box) Can anyone verify, suggest this? The FR guys claim direct replacement of OEM box, so therefore I deemed this a non-issue in the beginning, and has only now become of concern.
4) Possibly a 12:1 ratio box is too much for the pump/car to handle. And I should use the 14:1 ratio.
I do not feel this should be of issue, as many people run the 12:1 box. I would like to keep this quick ratio for Auto-X.
Now, a few things that I have noticed about the FR box...
- These are actually Delphi steering box with a Billet "Flaming River" cap. A Delphi tech verified this on their very helpful techline.
- The box is EXTREMELY hot to the touch after minor driving. The tech at Delphi said operating temps for their boxes are normally @ 135 C (302 F) and Intermitten @ 150 C (302 F). (Does this seem a bit extreme to anyone???) I suppose I could cook pasta or ramen noodles in my power steering pump if I am ever stranded and starving...:barf: )
Knowing this I have 2 further questions:
1) Is this a normal operating temp. for OEM boxes?
2) If I continued use of the "hot" FR box, would this effect a future install of a hydratech brake system as the PS fluid must pass through this as well. (Could increased temp ruin/effect system performance?)
WELL, not bad for my first post... sorry its long winded, but I really need some answers and I figured this would be the best place to get them!
Until post 2 :woot: ,
Chad
That being said...
The belt is fine.
Chad
