View Full Version : 69 Camaro - 07 Corvette 18" x 9.5" Front Rim Issues
Gryzlo
02-07-2008, 09:08 PM
OK ...call me crazy. Im trying to fit my 18" x 9.5" Corvette rims on my 69 Camaro. I have the Global west A-Arms and QA1 Coilovers on the Subframe. To complicate things...I have the 2007 Corvette 6 piston Calipers and 14" rotors.
This is where the problem starts. The Back Spacing on the Front Rims is 7".
I realize that there is no weight on the suspension yet but the rimms are really hitting the A-Arms. I MEAN A LOT. I am in need of someone whe knows the geometry.
Should I get a 2" spacer kit to get the backspacing to @ 5"?
Drop Spindles?
HELP
Vegas69
02-07-2008, 10:14 PM
6.25 is what I come up with based off my backspacing of 5.25 on an 8.5 rim. I don't think you can run a 9.5 wide up front with aftermarket control arms??
Apogee
02-08-2008, 08:12 AM
Do you have any pictures? I want to see this.
I'm running the C6 18x8.5 5-spoke wheels on a 73/74 Nova and they clear the C6 Z06 brakes fine with a 45mm adapter. They're pretty much against the fender lip on the outside and the subframe at full lock and you've go another inch of wheel width on me...I'm thinking it's going to rub hard. You may want to do yourself a favor and pull the springs if you haven't already so that you can cycle the suspension and steering effectively through it's range of motion, otherwise you're just going to be guessing. Also keep in mind that aligment will effect your tire position as well, so make sure you at least have it ball-parked.
Tobin
CarlC
02-08-2008, 08:45 AM
That much backspace on a stock frame + aftermarket arms is going to be tough to fit. I've done 17 x 9.5 x 5.5bs on the front. The suspension droop must be reduced to allow for wheel clearance.
See my website for details.
Gryzlo
02-09-2008, 02:18 PM
I am not sure about this. I have the frame off currently so spacing in the fender is not yet addressable. I will post some pics soon.
If this works it will look SICK!!!
streetk14
02-09-2008, 04:53 PM
Take Carl's advice, he's successfully put 9.5" wheels on the front of a stock subframed 1st gen. I'd shoot for a 5.5" backspace, which I guess would mean a 1.5" spacer. Even then it's going to be really tight.
You might be better off buying some replica wheels that aren't quite as wide. I have 9.5" wheels on the front of my car but it has an aftermarket sub that helps them fit. Good luck with the install.
Andy
Project69
02-09-2008, 06:20 PM
2" spacer here on a 17x9.5 +56mm offset Z06 rim up front. Stock control arms, hothckis springs, and 255 tire.
Gryzlo
02-11-2008, 01:01 PM
OK, so I ordered 2" spacers. They are on the front end. It clears the Global west a-arms just fine....almost too good.
Since I have the front end off the car....and every other part for that matter, does anyone know what is the correct dimention from inside the front wheel well to the other side inside wheel well?
The only measurement I can get at this time is outside wheel to wheel.
I would like to know if this is going to work, but need a little(LOT) of help.
PS how do I add pics?
CarlC
02-12-2008, 07:57 PM
The front sheet metal needs to be on the car. With a tire/rim that size there's not a lot of room. With a "normal" alignment buttonhead screws are needed along the outer wheelhouse. With a "performance" alignment (-1, +6) the tire starts hitting the aft lower wheelwell during turns.
streetk14
02-12-2008, 10:09 PM
You really need the sheetmetal on the car to get a realistic idea of how the wheels are going to fit. I'd be worried about rubbing the fender with a 9.5" wheel with 5" backspacing, especially on a '69.
Andy
Rick Dorion
02-13-2008, 03:55 AM
SC&C now has lowers that move the wheel forward to compensate for performance alignments. At least that was how Mark explained it! Might help or at least be worth a discussion with Mark.
matdean
02-13-2008, 09:48 AM
I am not sure how you host pictures to this site, but I use photobucket or a similar site to upload and host them for me. It just works easier and then I can keep them in a central location for different boards. (And they arent lost if a board crashes and looses data/info.
I look fwd to seeing pics, I would guess it would be really tight as well. From the little I have read SC&C makes awesome stuff.
Cruiser
02-13-2008, 09:52 AM
Still looking for one these wheels? Pm me, I saw one on e-bay being sold by a person somewhat local to me......as local as it gets in South Arkansas.....LOL
Joe
eville
02-13-2008, 10:02 AM
I tried to put a 6.25" bs 18x9.5" wheel on the front of mine. I had steering arm issues and wheel to upper a-arm interference when turning..
I opted for a 8.5" wheel and a 245 tire.
Gryzlo
02-19-2008, 08:23 PM
Here are some pics of the tires on the front. 2" spacer.
http://s272.photobucket.com/albums/jj194/ZO69Camaro/?action=view¤t=DSC00624.jpg
I need to put a 1.5" spacer on and see how that works.
Yes I know, nothing works till it works on the car with the fenders on....
chicane67
02-19-2008, 10:43 PM
Camaro X.
IIRC, 6.25" works on a 9.0"... but that might be pushing it on a 9.5" wheel. 9.5" is gonna take some finesse and a shorter tire.
Gryzlo
02-24-2008, 04:09 PM
So Does anyone have the dimensions from the outsides of the front wheels on a 69 camaro? From wheel well to wheel well.....
