View Full Version : DSE Leaf spring Mount w/mini tub
skeeters65
02-20-2008, 12:50 PM
I need to know what you use to mount the front of the leaf springs on a 69 Camaro with DSE Mini tubs??
Do you need the factory mount or do they supply a mount to move it??
The reason I need to know is I am missing one and need to know if I need to order one..
67bird
02-20-2008, 01:26 PM
Factory mounts are used on the front.
skeeters65
02-20-2008, 02:40 PM
Factory mounts in the front and offset shackles in the rear..
Doesnt that make the leaf spring angled??
TitoJones
02-20-2008, 03:29 PM
It actually straightens them out. They are angled from the factory, but after doing a mini tub with an offset rear shackle, they become almost parallel.
Tyler
dolf
06-27-2008, 10:36 AM
Is that bad? Can you run hyperco composite leafs and bilsteins with tubs no problem? What would need to be done and does it effect the way the car handles?
