    Page 41 of 48 FirstFirst ... 31 36 37 38 39 40 41 42 43 44 45 46 ... LastLast
    Results 801 to 820 of 954
    1. #801
      Jul 2012
      Iowa
      With those cross-members the only real change in them is the mounting height for the trans mounting bushing correct? I have the 200r4 version and was just going to weld on a tab for the t56 when I got to that point.
      Miles Boyer
      The car hobby is dangerous,if the speed doesn't kill you, the cost of parts will.
      91 V8 S10
      88 Cutlass Pro-Tour
      97 Chevy lifted Z-71
      96 Corvette
    2. #802
      Dec 2011
      Any new updates?
    3. #803
      Woodbine, MD
      Quote Originally Posted by silvermonte View Post
      That is what Lance did with his cross member. Lance want to chime in here??
      Douglas Lutes
      1988 Monte Carlo SS
    4. #804
      Woodbine, MD
      Quote Originally Posted by Number1 View Post
      Any new updates?
      No real updates.....life has been getting in the way now. I might have a hernia so that will put me out of commission for a while I think....time will tell.
      My next step is to install my Canton oil pan...so I can then install my flywheel and Centerforce Dual Friction clutch. After that the pedal assembly and hydraulics will go in and the trans can be bolted in for the last time.
      Then its on to the new rear end....measure for a new drive shaft...install suspension....etc etc etc.
      Douglas Lutes
      1988 Monte Carlo SS
    5. #805
      Aug 2012
      Peoria, AZ
      Here's what we did to modify my existing G-Force to work with the T56. I was the designer while my friend John was the lead engineer and machinist. Thanks John...
      The T56 transmission mount needed to be about 1 1/4" lower and and inch or so towards the front than the 200R4 mount was, so we cut a C-notch out of the front of the g-Force cross member.
      Then tack welded plates to box the C-notch in and tacked a new mounting plate at the right height inside the notched part.
      Then took it to the car and test fit to make sure everything was correct before final welding.
      We got the height perfect. I removed the rubber bumper on the top of the T56 and the tail shaft height is now in just about the exact same height as the 200R4 was and I can fit a straight blade screw driver between the rear two cover bolt heads and the floor pan.
      200R4
      T56 on new mount
      John finished welding it up and I painted it up and it'll be ready to go back in tonight.
      Lance
    6. #806
      Woodbine, MD
      Lance thank you for the post!!!!
      Tonight I am pulling out the measuring tape to see how the rear of my trans matches your pictures. Pics to follow....
      Douglas Lutes
      1988 Monte Carlo SS
    7. #807
      Jul 2012
      Iowa
      Thank you for the pictures Lance. Seems like a pretty easy thing to do to save a few coins since I have that cross-member already.
      Miles Boyer
      91 V8 S10
      88 Cutlass Pro-Tour
      96 Corvette
    8. #808
      Woodbine, MD
      I thought I would buy the T56 one to save some time......but we all can see that I'm taking my sweet time with these upgrades as it is.
      Douglas Lutes
      1988 Monte Carlo SS
    9. #809
      Jul 2012
      Iowa
      Quote Originally Posted by SicMonte View Post
      Thats no biggie, its called life and its nice to enjoy it sometimes. Ill go weeks without even looking at my projects sometimes.
      Miles Boyer
      91 V8 S10
      88 Cutlass Pro-Tour
      96 Corvette
    10. #810
      Woodbine, MD
      Looks like the motor will be pulled out to freshen it up bc I have to pull the motor out anyways to install this new oil pan so why not!!
      Douglas Lutes
      1988 Monte Carlo SS
    11. #811
      Nice fix! it looks good.
    12. #812
      Woodbine, MD
      Did some work on the car today...well set up for the final push to complete it. I'll have pics and info up here soon enough!
      Douglas Lutes
      1988 Monte Carlo SS
    13. #813
      Woodbine, MD
      So I am having the 8.5" GM 10 bolt build finally and I thought I would share with you all what is going into it.
      Here she sits in her current state of grime and rust.....
      Here are the 30 spline forged Moser Axles.
      Douglas Lutes
      1988 Monte Carlo SS
    14. #814
      Woodbine, MD
      Here's the Inland Empire 1350 Yoke.
      Douglas Lutes
      1988 Monte Carlo SS
    15. #815
      Woodbine, MD
      Yukon rear end assembly kit.
      Yukon 3.73 Ring Gear...still in the packaging lol.
      Douglas Lutes
      1988 Monte Carlo SS
    16. #816
      Woodbine, MD
      LPW Aluminum Diff Cover.
      Douglas Lutes
      1988 Monte Carlo SS
    17. #817
      Woodbine, MD
      Eaton TruTrac.....I can't tell you how long I have wanted one of these!!!!!
      Douglas Lutes
      1988 Monte Carlo SS
    18. #818
      Woodbine, MD
      Soooo while the rear is out getting built I have started the suspension parts swap.
      First step was to assemble my new ridetech TQ series coilovers.
      Here are the springs. Fronts are now 800# (used to be 900# on the single adjustable coilovers) and the rear springs are 275# (up from 250# on my singles).
      Douglas Lutes
      1988 Monte Carlo SS
    19. #819
      Woodbine, MD
      Here is all the hardware for the front coilovers.
      and here's what's included with the rear coilovers.
      Douglas Lutes
      1988 Monte Carlo SS
    20. #820
      Woodbine, MD
      And here we have a ridetech TQ Coilover for the front of a G Body...when using the ridetech lower control arms.
      The first step in assembling these coilovers is to put on the lower spring mount/adjuster. This is usually done from the bottom of the shock but this is not possible on the TQ series due to the reservoir hose...so the lower spring mount needs to go on from the top. This is a seriously tight fit so the guys at Ridetech gave me a lil trick of the trade.......put a thick washer in the open space on the spring mount to widen the inner diameter and the mount will slide right over the shock body to the threads. BINGO!!!!!!!!!
      Douglas Lutes
      1988 Monte Carlo SS
