    Page 15 of 23 FirstFirst ... 5 10 11 12 13 14 15 16 17 18 19 20 ... LastLast
    Results 281 to 300 of 454
    1. #281
      Aug 2011
      Bay Area
      im so subscribed to this build! great work man, really diggin it. Can't wait to see more.
      — Will
      65 mustang coupe in the works
    2. #282
      Jan 2010
      SLC. UT
      Thanks 65_stang and bishir
      Here's an update:
      First off, THANK YOU to the member that mentioned the upper coilover mounts on the R&C kit were prone to bend.
      We beefed them up. basically plated the outside and welded off the perimeter.
      Mounted up the brakes for fun:
      Jeff -- 96 Mustang - 2V Stroked Modular Turbo // 13 RAPTOR // 67 Mustang Fastback build - Coyote 5.0
    3. #283
      Jan 2010
      SLC. UT
      Here's how far we got on the DS hedder:
    4. #284
      Enfield, CT
      How does the knuckle not hit the sway bar link when turned?
      '67 GTO - LS3, 4L60E, SC&C AFX Package, KORE3 C6 Z06, Boyds PT-09s
      https://www.pro-touring.com/showthre...7-GTO-LS3-Swap
    5. #285
      Dec 2007
      Ravena, NY
      Been watching for a bit, looking good Jeff
    6. #286
      Oct 2010
      SLC
      Quote Originally Posted by Dalamar View Post
      I found that the weakpont on mine was the tab that the coil over bracket mounted to. If you can find room to gusset the top that should also help.
      Zach
    7. #287
      Jan 2010
      SLC. UT
      thanks for that Zach, it's 2x as thick now
      getting closer on this hedder
    8. #288
      SF Bay Area
      Man, that Cleveland looks awesome in there, but onto your headers... Nice job with all the slicing to get them to fit. Since you had to cut them up, would it have helped anything to make them Tri-Y's? Looks like you'll need to pull the steering shaft once they're all welded up. How is the ground clearance? From the pic it looks fine, but you know how pics can be...
      chunger
      '68 Ranchero 500
      '70 Cougar XR-7 Convertible
      '98 Mustang GT Convertible
    9. #289
      Feb 2007
      looks close to the rails
    10. #290
      Jan 2010
      SLC. UT
      Thanks for the interest and Inquires guys.
      The ground clearance isn't bad, the pan is lower, thinking I might wanna build a skid plate for it?? The hedders are about paralell with the Sub frames.
      It's been sitting for about 2 months, crazy busy on my end with work and family stuff.
      got the DS hedder pieced together and clears everything fine. Yes we'll have to pull the steering shaft to remove it, no biggie.
      here's a few update pics.
      My dad went crazy and finished it by himself while I was out of town. It needs some more fill welding and clean up, then off to HTP coatings.
      And we got these pieces!
    11. #291
      Jan 2010
      SLC. UT
      Quote Originally Posted by CFster View Post
      I can see what your looking at, i'll have to turn it and snap a pic.
      Quote Originally Posted by 69clark View Post
      thanks man,
      Is your pace car build on here? love it BTW. really happy with the pictures of it in the SN95 calendar.
    12. #292
      Jun 2011
      St. George, Utah
      Coming along great Jeff! Glad to see you doing the complicated stuff yourself, keep it rollin'!
      SRD on Facebook
      79 Cutlass wagon build
    13. #293
      Feb 2010
      Plainfield, IN
      I have always loved this project! Good stuff, keep plugging away at it. Every little bit counts.
      One question. When you leveled up the IRS, what did you measure? I saw an angle gauge on the "bottom" of the pumpkin. Was that your reference point?
      1969 1/2 Maverick
      4.6 DOHC, Mustang II front, T56, & Cobra IRS
      Custom Interior in the works.
      http://www.cardomain.com/ride/2200206
    14. #294
      Jan 2010
      SLC. UT
      Quote Originally Posted by ATOMonkey View Post
      Thanks man. That gauge was to set the pinion angle. did you mess with the pinion when you put the IRS in your build?
    15. #295
      Feb 2010
      Plainfield, IN
      I don't even have a pinion! lol... I'm going to hit the pick a part this spring and see if I can hunt up a Mark VIII pumpkin. That will give me a better reference point.
      I'm tyring to figure out what part of the IRS cradle or control arms are "level" so I know where to put the brackets. So far, I'm thinking the pinion mount brackets are probably my best bet. They look to be perpendicular to the pinion flange.
      1969 1/2 Maverick
    16. #296
      SF Bay Area
      Not to hijack this thread, but you should look up a build on here called "Twin Torino" by SVTforme, he put a Cobra IRS under a Torino and could probably point you in the right direction.
      chunger
      '68 Ranchero 500
    17. #297
      Jan 2010
      SLC. UT
      His thread is sweet.
    18. #298
      Jan 2010
      SLC. UT
      After being gone for about a month, I got to work on the car for about 1 hour!!
      spent all day working on my wifes car...
      There were some pits on the hedder welds, so we gas welded all the joints, test fit, and started grinding it down.
      Going to re plumb this thing:
      I like the open bay look
    19. #299
      SCHWEET!! good work Jeff!!
      Jan 2010
      SLC. UT
      Thanks Kev.
      Ordered some parts last few weeks.
      here's a peek at the first few to arrive:
