    Page 1 of 29 1 2 3 4 5 6 11 ... LastLast
    Results 1 to 20 of 578
    Thread: 69 GTO Build
      Jun 2012
      N. Shore, Ma
      69 GTO Build
      Its been a few months since I posted on the forum. Have been busy on the weekends chopping away the bad metal on the GTO and slowly getting new parts welded on. Would normally be more productive, but a broken back from a motocross crash this time last year has slowed me down. I hope to build the GTO to be competitive in Autocross and replace the thrills of Motocross, should be a bit safer with a full cage welded (or bolted) any tips would be appreciated since all the rule books are confusing with a full frame car. Will be using solid body mounts. Oh and it has a fully boxed convertible frame so it should be fairly stiff but adding the cage will help.
      So far I have replaced the upper cowl, fit the left quarter and split the new wheel house in half. Going with a 3" mini tub and coilovers with Fab 9 rear end. Again any tips there?
      https://www.cachassisworks.com/c-291...ody-68-72.aspx
      Near future, 2005 LQ9 that I plan to go through and then I need to order a T56 Magnum.
      Who has the best LS conversion mounts? I guess I need to position the engine first to figure out how far back I can get it.
      Eric
      Eric
      Building 1969 GTO - Roadster Shop chassis, LQ9 w LS3 heads and rebuild parts from TSP, Bowler prepped Magnum T56 6 spd, 3 Link Strange 9" w Speedway Floater Hubs, Wilwood 14" F - 13" R brakes, 275.18 - 345.19
      https://www.pro-touring.com/threads/94970-69-GTO-Build
      Waterloo, Ia
      Love to see fellow GTO guys. Ill be tuning in.
      Are you doing the ABC frame/minitub kit?
      -Nick
      -1967 GTO I drive and race
      -Build threads:
      California
      Good deal bud, Im gonna keep an eye on this one. It sucks cause I wanna work on mine soo bad. As far as the engine mounts I would have given you a set of the ones I made and wound up not using. You can see them on my build page just look up VOODOO CHILD. If you are still looking when I get back ill dig em out and send em to you. Otherwise look into BRP, they have good stuff but its kinda pricey.
      Feb 2006
      Idaho Falls, Id
      Subscribing. These are one of my favorites. Sold my 69 tempest last year when I was broke then got a job that would've allowed me to keep it :(
      Sshep71, I'm in Kandahar, where are you?
      Traven
      Jun 2012
      N. Shore, Ma
      Novaguy73, yeah I hope to combine the ABC mini tub kit and mandrel bent 2X3 rear frame rails from these guys.
      http://autoweldchassis.com/spec.ivnu
      Thanks for the support.
      T Raven, I wish I still had my 69 Custom S (wana be GTO) I had as a first car in High School, it was ugly black primer but today it would be called rat rod black.
      I bought this GTO i am finally getting around to right out of High School around 26 years ago, time flies!
      SShep71, Looks like we are thinking alike on a bunch of things suspension wise with Watts link etc. Good work on those mounts and boxing the frame, love the rendering. Its too bad about the problems with the hobby shop facilities closing. My Dad used to work on his cars in the Air Force base garages in the 50's (B-47 pilot with lots of fun stories). If they kick you out I will clear out a spot for ya! It sucks not having a spot to work, I finally am able to enjoy my garage that took me 20 years to get. Used to work outside but its not fun in New England. Thanks for the info on the mounts I will check them out, I need to save time where ever I can since I dont get much build time per week. I still put my kids first and my 11 yr old daughter doesnt help me out there in the garage much.
      Although tonight she helped me get the LQ9 out of the truck! Its a start right?
      You guys be careful over there, us GTO guys have to stick together!
      God bless, and thank you for your service!
      Eric
      Jun 2012
      N. Shore, Ma
      Got the firewall panel fit and ready to weld.
      Cleaned up the LQ9, right side header bolts not so good, snapped one but it was ready to fall off and the front and back ones were gone when I got it.
      After a day of fitting yesterday the drivers side quarter was ready to weld on. Used the SEM panel adhesive on the lower half, that 90 minute work time goes by fast when you work alone!
      Sorry for the large pics.
      Attachment 68527
      Attachment 68528
      Attachment 68529
      Attachment 68530
      Eric
      Feb 2012
      Ohio
      since when did abc start making a mini tub kit for the 68-72 a bodies?
      Or does their 64-67 fit?
      Jun 2012
      N. Shore, Ma
      Quote Originally Posted by mikes2nd View Post
      Yeah they just started to make one for the 68-72. The website doesnt show it but if you look on their Facebook page they have mentioned it, he says they are in stock and ready to ship.
      Eric
      Jun 2012
      N. Shore, Ma
      Figure I better get an update in before the end of the world today.
      Placed an order for the roll cage and bent 2x3 frame rails, got the DOM 1 3/4 tubing.
      http://autoweldchassis.com/rbc.ivnu
      Thinking about setting the engine back more, cutting the firewall (adding lots more work)
      Trying to get all the quarter work done first, got the passenger side off.
      Need to research flush glass how to's, new window / trunk pan is next, planning on sliding it up to get rid of factory molding.
      Oh and if the world doesnt end today MERRY CHRISTMAS!
Size:  77.0 KBName:  DSC04699.jpg
      Eric
      Jun 2012
      N. Shore, Ma
      Bought fairly good fenders and a hood from a guy in CT over the weekend, gotta love Craigslist. Will be felling better with the front sheet metal on and lined up so I can match up the gaps before I finish welding the right quarter.
      Been fixing rusted tail panel, package tray and radiator support with good metal from parts cars out back.
      Sorry for all the boring sheet metal updates! I cant wait to be finished with the body so I can move on to more exciting parts of the build.
      Roll bar and rear frame rails showed up from Autoweld. That will be next to play with.
Size:  74.2 KBName:  DSC04921.jpg
Size:  89.0 KBName:  DSC04944.jpg
Size:  64.9 KBName:  DSC04948.jpg
Size:  63.5 KBName:  DSC04954.jpg
      Happy New Year!
      Eric
      Apr 2004
      Cedar Rapids, IA
      Quote Originally Posted by ekmxryda View Post
      Happy New Year!
      Nothing boaring about sheetmetal updates. Happens to be my favorite part.
      Nice project. Anymore pics of the purple sweatpants?
      Jun 2012
      N. Shore, Ma
      Quote Originally Posted by rohrt View Post
      Haha no she is not that interested yet, I tell her maybe someday she will be driving it though. She says when I get to the interior work she will help more.
      Eric
      Jun 2012
      N. Shore, Ma
      Tail Panel
      Some more work that will never be seen once the car is done.
      Salvaged a bent but solid one off my parts car. Lots more welding to do, but feeling better that this is coming together.
Size:  68.0 KBName:  DSC04070.jpg
Size:  58.7 KBName:  DSC04895.jpg
Size:  92.4 KBName:  DSC04539.jpg
Size:  105.5 KBName:  DSC04764.jpg
Size:  77.5 KBName:  DSC04933.jpg
Size:  60.9 KBName:  DSC05005.jpg
Size:  47.3 KBName:  DSC05066.jpg
      Eric
      Jan 2013
      Beaverton, Oregon
      This is my wife's favorite car. I will have to follow this one for sure! Good decision replacing the whole back 1/4s... yuck!
      Air/Hydraulic tube benders, Drill Press Reduction Kits, Die Sets, Tubing Notchers! All made in the USA
      st. paul mn.
      I do not envy you one bit rust repair just plain sucks it is alot better after sandblasting but it still sucks. looks like you are going to put a cage in it? where did you get the cage and how does it fit? let us know when you get to it.was the firewall piece a bought piece or self fabricated?
      Jun 2012
      N. Shore, Ma
      Quote Originally Posted by RogueFab View Post
      I will be done with the sheetmetal work soon I keep telling myself! But mini tubs and floors are next.
      Eric
      Jun 2012
      N. Shore, Ma
      Quote Originally Posted by E.rodz View Post
      Yeah I wish there was an easy way to do rust repair, it does suck.
      Autoweld in PA made the cage, looks like I need to modify the bends on the a pillar to get a tighter fit.
      Link to site up on post #9.
      ABC Performance in Michigan made the firewall panel.
      http://abcperformance.net/firewall%2...%20panels.html
      Eric
      California
      Are those dynacorn quarters? how did they fit?
      Jun 2012
      N. Shore, Ma
      Quote Originally Posted by SShep71 View Post
      Hey SShep are you back home yet?
      Overall I was happy with the fit of the quarters, I only had to cut the top of the sail panel a little bit to help the curve at the top of the back window. They are Dynacorn with the weld through primer.
      Wondering if it is best to strip the primer on the outside so I have the same SPI Epoxy primer base on everything?
      Eric
      Nov 2011
      Fort Worth, TX
      Hey Eric, from the pictures it looks like you installed the quarter panel before the inner fender wells. Is that correct?
      I mini tubbed my 70 GTO by stretching the factory inner wells but I'm not to pleased with the outcome, so I am considering ordering the ABC mini tub kit. The reason I am asking about the quater panel process is because I have both left and right replacements and was wondering if I should install the quarters before the mini tub kit?
      Cameron
      Cameron Miller
      Link to 1970 GTO Build Thread...
      https://www.pro-touring.com/showthre...Pro-Tour-Build
    Tags for this Thread
