Results 141 to 160 of 454
Thread: 67 Fastback - Project Dalamar
03-13-2010 #141
Removing the firewall wasn't as hard as we thought it would be.
We worked on it for about 6 hrs today.
Here's some pictures.
Jeff -- 96 Mustang - 2V Stroked Modular Turbo // 13 RAPTOR // 67 Mustang Fastback build - Coyote 5.0
03-13-2010 #142
03-13-2010 #143makes me want to start a build..lol.. good looking work from a fellow hellion guy!
03-15-2010 #144Damn... talking about cutting 2 cars apart to make one... looks awesome!!
2014 Chevy SS LS3 / 4 Door
03-15-2010 #145awesome progress!
the burning seam sealer is a familiar sight... ;)
03-15-2010 #146Wimbledon White, with a black turn signal hood that I had traded some parts for and since the paint was good, was too lazy to repaint to match the car. Color wise, it actually worked pretty good.
Thanks, I'll have to go take another look at the Lincolns, sounds like they'll work just fine. But, I'll have to stick with the 110v models.My welder is the Lincoln SP-170 T
Runs on 220V. and I use an Argon/Co2 mix with it for the shield.
I've had it for about 5 years, and it works great.
Recently replaced the lead because the coil inside it was getting old cand causing drag on the wire. Otherwise I've had no problems.
I wouldn't recommend going over a 15' lead.
I welded my Roticery together with it.
Much past 1/4 you'd want more heat. Using this for 3/16 and 1/4 I'd recommend you have a slight gap to help with penetration.
Car is really coming together. Nice job on the firewall - are you going to fab in some cowl vents like the stock firewall has? Dunno about you, but I find myself using them quite a bit to get air flowing in the car.chunger
'68 Ranchero 500
'70 Cougar XR-7 Convertible
'98 Mustang GT Convertible
03-15-2010 #147black hood on white is a nice combo. I'm considering doing something on my 96, which is white.
If there is any way you can get 220V out where your welder is, I'd highly recommend it.
In my experience you get a better weld, and you can turn up the heat when needed.
If you need to go with a buzz box (120 V uint ;) , I'd do some more checking on which model is best. a 120V unit would be fine if you're just doing sheet metal.
havn't thought about putting those vents back on, but that's a good suggestion. I'll check it out, thanks.
03-15-2010 #148
