    Page 6 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
    Results 101 to 120 of 262
    1. #101
      Jun 2017
      Utah
      Did a little rust repair on the B pillar
    2. #102
      Jun 2017
      Utah
      I’m trying out the lower stance and testing tire clearance issues. I don’t have those nice tools for this purpose so plywood and Ram board will have to suffice for the initial tests.
      How low is too low? The lowest point is the bottom of the driveline hoop at 3.5”. The rockers are at about 5”. Name:  IMG_1623.jpg
    3. #103
      Jun 2017
      Utah
      Got her up on the rotisserie to finish the welding underneath. And also to get it outside so I could work on my daily driver. Name:  IMG_1634.jpg
    4. #104
      Jun 2017
      Utah
      Trying to build something like the original louver/ vent on the sail panel. I want it to be very similar but maybe some additional style.
    5. #105
      You're killing it!
    6. #106
      Jun 2017
      Utah
      You're killing it!
      Thanks for the encouragement. Just to be clear, the red one is the real thing I want to copy. At this point, mine is only cardboard but I’m making progress.
    7. #107
      Jun 2017
      Utah
      Finishing up all the welding on the bottom. I’m waiting on the trunk filler panel to finish up the body.
    8. #108
      Jun 2017
      Utah
      I built a wooden window buck. My plan is to bend some metal around this and then add the louvers inside. We’ll see how it goes.
    9. #109
      Jun 2017
      Utah
      Ok, I got one of the vents mostly done. I built a wooden window buck, cut 2” wide 18 gage sheetmetal strips, bent that around the buck, then built a backplate, then some louvers. It’s close to what I was hoping for.
Size:  413.1 KBName:  812EB5C1-3DA7-4F83-87C4-4CB778FE6C65.jpg
Size:  394.8 KBName:  92C5CBEE-0D3A-4A7C-A2AD-0E6B9ECB7C60.jpg
Size:  450.6 KBName:  063BC640-549D-46BB-AEB5-57C0802F2E0A.jpg
      - - - Updated - - -
Size:  513.5 KBName:  395616BD-24CC-4283-BA36-133BA561FD22.jpg
Size:  316.7 KBName:  CFDE899D-271A-413D-ACB0-BEBC80B72503.jpg
Size:  321.3 KBName:  8FC78A44-2433-48CB-B6BA-313E656CC02A.jpg
    10. #110
      Jun 2017
      Utah
Size:  210.8 KBName:  CBEFACB8-0323-4F53-BD4B-0DDE1D221B9F.jpg
Size:  367.6 KBName:  2DA92FD1-DD0C-4D9E-A45B-D960DBCBDA97.jpg
Size:  415.2 KBName:  13D2DF50-E4FA-4F8E-958C-DB8A674AD314.jpg
Size:  479.6 KBName:  B302E96C-35FC-42FD-811C-0425937BF8F5.jpg
Size:  348.2 KBName:  2477360D-4A99-4C51-8674-E6CC6A2D4207.jpg
    11. #111
      Nov 2009
      the dirty mitten
      66 Mustang Restomod Project
      Wild build and you’re doing great! What size wheels and tires are you thinking? You asked what is too low. I have a car that is less that four inches high, only issue I’ve had is getting it on a trailer. Other than that just might have to plan ahead a bit of possibly depending on your area, look into a lift system for coil overs.
      After years of building my car and just sort of building the body while making it up then starting over I finally had rendering done. Cost wasn’t bad at all and we got to discuss a lot of details while it was getting done. Then you get to see what you have been working for all this time. Really helped with my build and saved me tons of time and wasted money/materials. If you think you’d want to get one for your build, hit up Ben at SRD art.
      Keep posting up the progress, it’s coming along quick!
      Steve
    12. #112
      May 2012
      Kansas City, Missouri
      Those vents turned out amazing. Looks great and very nice work. Bet u could sell those
    13. #113
      Jun 2017
      Utah
      Thanks for the kind words. I am planning n running a 13” wide by 28” tall in the rear. I want to go as wide as possible on the front- I think I can run a 295 up front, 26” tall. I don’t have the front suspension yet but on paper that should work. I mocked up a 14” wide, 30” diameter rear and it fits but absolutely no room for error. I have a lot of adjustment on ride height so I’ll experiment a bit once it’s a roller.
      I like the idea of a rendering. I’m not sure the color I want yet but I am painting it myself so I will experiment a little more.
    14. #114
      Jun 2017
      Utah
      A few shots recently.
    15. #115
      Jun 2017
      Utah
      We’ll, I haven’t been able to find a Dynacorn rear deck panel so I bought a cheap one. I have used the cheaper panels in the past with mixed results. Unfortunately, this one isn’t going to work. The trunk seal lip is supposed to be a rounded bend but this one is pinched flat. It won’t line up at all with the other panels. I could probably live with that but the window interface is bent at 45 degrees but needs to be 90.
      I had to send it back and this is going to set me back a bit because I can’t start welding until I have all the sheetmetal in place. Oh well, I’ll find plenty of other projects to keep me busy.
    16. #116
      Jun 2017
      Utah
      I closed up the coupe quarter window notch. Don’t need that in a fastback.
Size:  388.9 KBName:  32668C15-2AFD-47BF-AA4D-C2DC83CEBC92.jpg
      that gave me a spot to attach a B pillar support. I am experimenting with a roof support. Not sure if I’ll stick with this version.
Size:  351.5 KBName:  B4CD1814-0FC5-4E98-AD54-D1649E58309E.jpg
    17. #117
      Jun 2017
      Utah
      I figured out how to attach the louvers without them showing too much and I finished the drivers’ side. Now I have to figure out how to cover the gaps between the louvers and the quarter panel. I’m looking at various plastic/rubber moldings or even trying to add metal and weld them into the panel. I love the idea of a rounded smooth transition but I’m not sure I’m capable of that.
Size:  478.2 KBName:  5F3403EF-A6BA-4803-BFAF-41802EE3820A.jpg
Size:  390.1 KBName:  465EF34D-79D6-405A-9D20-B0D07B1789AF.jpg
Size:  244.8 KBName:  F4DC79D9-91ED-4109-8782-47267C1F0BF7.jpg
    18. #118
      Mar 2016
      For the rubber molding around the louvers here is a thought:
      AMAZONdotCOM/D-Lumian-Fender-Flare-Edge-Rubber/dp/B087BZ2TKW
      Sorry cant post links so check Amazon.
      It's supposed to be used for fender flares (instead of caulking).
    19. #119
      Jun 2017
      Utah
      Quote Originally Posted by Lockdown View Post
      This might be a great option, thank you.
    20. #120
      Jun 2017
      Utah
      Made some progress today. First, I tried out a 355/30R19 tire for size. It fits but it is tight.
Size:  417.2 KBName:  A63DE632-BAB7-4BF9-80D9-A8C3FC1700AF.jpg
Size:  361.7 KBName:  89E35899-8A25-4B21-A6C3-0ACAE9E1A70E.jpg
Size:  350.3 KBName:  756ABA73-3AF9-45D1-BC07-7B770ACD108C.jpg
