    Page 43 of 48 FirstFirst ... 33 38 39 40 41 42 43 44 45 46 47 48 LastLast
    Results 841 to 860 of 954
    1. #841
      Dec 2014
      nashua new hampshire
      what axle company did you use? strange? im building a 8.5 for mine now, i was going to go with a disc brake set up off a 90's 2wd blazer.. any thoughts
      still have the tubular front suspesion setup anymore?
    2. #842
      Woodbine, MD
      Quote Originally Posted by slow87monte View Post
      I'm using Moser 30 spline axles in my 8.5.
      Not sure about the rear discs off an s10...no experiance with those. I know a lot of people use the rear ls1 brakes though.
      I am planning on using the ridetech front Tru-Turn set up and also hope to use the new UMI G Body front suspension set up at some point. I will test both to see what best fits my driving style.
      Douglas Lutes
      1988 Monte Carlo SS
    3. #843
      Apr 2011
      Hey doug, hang in there. It will all come together. Besides, if it was easy, everyone would be doing it. I attached a pic of my monte that has been a labor of pain for the last 18 years of my life. But i wouldnt trade any of it. All the suspension work has been done, with a lot learned form your thread(thank you, seriously), but i have one nagging problem that you seem to have fixed. Your inner fender liners...early on you had cut them, but now it looks like you hAve some stock replacements. You claim they dont rub even with the 275s up front. I have 245s and im hitting on the passenger side where it pinches in for the ac box(thats all gone now) and the battery tray. Whats your secret? Ones for a regal, or cutlass work better?
    4. #844
      Dec 2011
      Sicmonte, what size and backspacing are your rims? Also what size tire are you running? Thanks in advance.
    5. #845
      Jan 2015
      Charlotte, NC
      this thread makes me want one now
    6. #846
      Dec 2011
      Found the wheel & tire information. Are you still running a spacer, as I see you were before you upgraded to the baer brakes? Also any updates on the car?
    7. #847
      Woodbine, MD
      Quote Originally Posted by Number1 View Post
      No spacer on the fronts anymore but I am still running one on the rear...but not for long!!!!
      Douglas Lutes
      1988 Monte Carlo SS
    8. #848
      Woodbine, MD
      Quote Originally Posted by Dochaze View Post
      I am using the stock inner fenders but I cut them across the middle so they flex more. Thats about all I did....no rubbing at all on full lock.
      Douglas Lutes
      1988 Monte Carlo SS
    9. #849
      Woodbine, MD
      Update time!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
      Douglas Lutes
      1988 Monte Carlo SS
    10. #850
      Woodbine, MD
      I got the rear end back...all I have to do now is paint it and determine what I will be using for my LCA relocation brackets. I hear UMI is coming out with some trick stuff soon............
      The rear is a GM 8.5" 10 bolt with 30 spline Moser Axles, Tru Trac Diff, 3.73 Yukon Gears, Inland Empire 1350 forged yoke, a LPW Ultimate 10 Diff Cover and the UMI Performance Roto Joints. This is a bad mofo.
      Douglas Lutes
      1988 Monte Carlo SS
    11. #851
      Woodbine, MD
      I decided to pull the motor in order to swap out oil pans...and this quickly turned into me taking the motor to a machine shop to rebuild since I only had 4 psi of oil pressure at idle.....sooooooooo
      Douglas Lutes
      1988 Monte Carlo SS
    12. #852
      Woodbine, MD
      Douglas Lutes
      1988 Monte Carlo SS
    13. #853
      Woodbine, MD
      While it is at the machine shop......
      Douglas Lutes
      1988 Monte Carlo SS
    14. #854
      Woodbine, MD
      Here's the car as she sits......
      So I decided to put up my partner banners and film some stuff for my YouTube page!!!
      https://www.youtube.com/channel/UC-F...Oc4Xf8m6O8mFnQ
      Douglas Lutes
      1988 Monte Carlo SS
    15. #855
      Woodbine, MD
      Pics of my Canton Road Race Oil Pan and FelPro one piece gasket.
      Douglas Lutes
      1988 Monte Carlo SS
    16. #856
      Woodbine, MD
      So I went to the machine shop tonight to talk about the motor. Remember I had 4psi of oil pressure at idle and this is why.....everyone of my main bearings was destroyed and the crank main journals were so worn that they looked like a mountain ridge. Nasty!!!!
      Douglas Lutes
      1988 Monte Carlo SS
    17. #857
      Woodbine, MD
      We will clean up and reuse the rods and pistons.
      Douglas Lutes
      1988 Monte Carlo SS
    18. #858
      Nov 2002
      state of confusion
      Have you radius'ed the entries to the oil drainback holes at least in the cylinder heads and at the back of the block?
      Norm
      Gone but not forgotten dep't:
    19. #859
      Woodbine, MD
      Quote Originally Posted by Norm Peterson View Post
      Norm
      That will probably happen depending on the cost.
      Douglas Lutes
      1988 Monte Carlo SS
    20. #860
      Mar 2010
      Okinawa, Japan
      Looks like we have matching rears except I know we are running different disk brakes. You'll love the tru-trac its smooth as butter! I don't think they like sythetic fluids though, might want to check on that before you fill it.
