View Full Version : Power Adders
Pages : 1 2 [3] 4
  1. Procharger quality issues? (9 replies)
  2. I'm so stupid! (6 replies)
  3. supercharger questions?? (3 replies)
  4. See any problems with Nozzles for Water Injection Here? Pics Inside ... (3 replies)
  5. Which Carb Vacuum port to Blower Accessories (Vacuum Log) ... Pic inside ... (3 replies)
  6. Where did you install your Water Injection Kit? (8 replies)
  7. Should I cnc port my intake (3 replies)
  8. Smaller pulley but no more boost????? (12 replies)
  9. V8 project... (2 replies)
  10. Procharged ZZ383? (3 replies)
  11. twin turbo big block mopar. (5 replies)
  12. Ignition setup - Digital-7 part #7535 (13 replies)
  13. Fuel system questions (4 replies)
  14. No intercooler, just meth injection (8 replies)
  15. Decided To Add Turbo's (6 replies)
  16. does this sound right (turbo sizing) (6 replies)
  17. Blow through problems (33 replies)
  18. Anyone wanna help me try and build an engine? (4 replies)
  19. Need turbo big block help please. (6 replies)
  20. Any turbo Basics? (12 replies)
  21. a supercharger (6 replies)
  22. turbo small block help (5 replies)
  23. 351 c twin turbo (14 replies)
  24. Got The Intercooler and Bypass valve installed.. PICS!! (9 replies)
  25. Finally coming together-sorta (2 replies)
  26. turbo header madterial? (9 replies)
  27. Stainless Exhaust Bends - Suppliers? - Welding Tips? (15 replies)
  28. GMPP 350ci 250hp crate engine for turbo application? (4 replies)
  29. Just ordered an F2-R (1 replies)
  30. Where to get a Bypass valve besides procharger?? (16 replies)
  31. turbo on a carb'ed v8 (2 replies)
  32. 1971 Chevelle twin turbo (pics) (17 replies)
  33. What fuel pump with 1200 hp and an F2 blower? (15 replies)
  34. Nitrous fuel line routing (8 replies)
  35. best flowing air filter? (7 replies)
  36. NOS fuel solenoid for purge? (3 replies)
  37. twin turbo camaro run-in ---update--- (4 replies)
  38. Building a small block for my camaro...need input (10 replies)
  39. Clocking blower side of a procharger (3 replies)
  40. Procharger Polish (0 replies)
  41. Questions about ProCharger P1SC....(many) (6 replies)
  42. Can this combo take boost (4 replies)
  43. Dual intercoolers vs. single (5 replies)
  44. Enough venting for intercooler? (3 replies)
  45. nitrous (not noss!) with hyperujunktics (12 replies)
  46. Helpful Spreadsheet with compressor maps (3 replies)
  47. Intake tubing sizing (0 replies)
  48. When do you need a BOV??? (9 replies)
  49. turbo kit? (6 replies)
  50. Whipple, twin screw, magna charger for Big Block Chevy's? (4 replies)
  51. Fuel pump ques. (19 replies)
  52. Found This On Ebay (4 replies)
  53. Someone give me a quick lesson on boost & pressure connections ... See inside ... (6 replies)
  54. Who sells the cheapest aluminum tubing bends? (13 replies)
  55. F1 Procharger Head Unit Price? (4 replies)
  56. lock out distributor on a Procharged car? (17 replies)
  57. BBC heads and 6-71 blowers (9 replies)
  58. 383 procharger (10 replies)
  59. What are the best blow thru carbs? (20 replies)
  60. Procharger problems or not? (3 replies)
  61. Need intercooler sizing help. (4 replies)
  62. pre '86 305 TPI super charger? (18 replies)
  63. Looking for pics of front mount intercooler on 3rd gen camaro! (1 replies)
  64. twin turbo camaro run-in (19 replies)
  65. Possible to turbo my big block camaro??? (8 replies)
  66. Has anyone used these turbo manifolds? (4 replies)
  67. Anyone using Extreme velocity carb hat? (11 replies)
  68. Alcohol injections placement? (3 replies)
  69. Does anyone have a contact at Banks? (8 replies)
  70. What Heads to Use on a T/T 350??? (3 replies)
  71. 69' Camaro twin turbo, turbo locations? (31 replies)
  72. blow through carb??? (4 replies)
  73. turbo with blow through carb (8 replies)
  74. twin turbo sizing for SBC 350 (2 replies)
  75. Nova intercooler? (8 replies)
  76. E85 with a procharger??? (4 replies)
  77. New Kenne Bell Guy-Need Help (10 replies)
  78. T/T 350 Fuel Injector Sizing (3 replies)
  79. Fancy new wastegates! ! ! (9 replies)
  80. Can nitrous be detected? (17 replies)
  81. Smoking!!!! (10 replies)
  82. Best WG location (6 replies)
  83. wideband A/F, which one? (31 replies)
  84. Dyno today! (13 replies)
  85. twin turbo a pontiac 400? (4 replies)
  86. Weiand 144 (6 replies)
  87. A little turbo porn (3 replies)
  88. Paging Prostreet RT... (7 replies)
  89. Boosting a Mopar 318? (1 replies)
  90. Vortech superchargers (9 replies)
  91. TIAL BOV on with a Procharger system? (3 replies)
  92. Who wants SBC turbo manifolds? (10 replies)
  93. Who knows ball bearing turbo's??? (1 replies)
  94. 70 camaro d-1sc (13 replies)
  95. Nitrous Switches (1 replies)
  96. which blow through carb (3 replies)
  97. supercharger for a pontiac 400? (1 replies)
  98. 350 SBC 4 Bolt Main 800 to 1000 HP (19 replies)
  99. I need an aluminum 3.5" to 4" adapter (4 replies)
  100. GM Steel Crank (11 replies)
  101. New a company to purchase a supercharger (3 replies)
  102. NOS or Zex (3 replies)
  103. Cam choice for procharged 468 (2 replies)
  104. Silicone hose (3 replies)
  105. Turbo manifolds (1 replies)
  106. Blow through carburated LS1 in early camaro.... (8 replies)
  107. How hard would you push the block on a SBC? (13 replies)
  108. Procharger pulley (6 replies)
  109. Got a new toy last night...... (5 replies)
  110. Turbo project update (20 replies)
  111. Procharged 383 - Header Time ... Question about Primaries ... (3 replies)
  112. Help with big power procharged small block (7 replies)
  113. Turbo Engineering Corp Has Reopened (0 replies)
  114. Procharger vs Vortex (8 replies)
  115. Possible to route a blow-off valve to the exhaust ? (6 replies)
  116. Mounting A/C and Alt with Procharger? (17 replies)
  117. junkyard TT setup????? (11 replies)
  118. ok some questions and maybe a desktop dyno? (5 replies)
  119. gear ratio in turbo car? (4 replies)
  120. Blow through boost and 5 speed manual (0 replies)
  121. Particle size required to damage a turbo (16 replies)
  122. vortec V6 (4 replies)
  123. Turbo piping question (3 replies)
  124. question about sts rear mount turbos? (3 replies)
  125. quick question on my setup? (3 replies)
  126. general question (4 replies)
  127. Twin Turbo Help (26 replies)
  128. turbo motor (1 replies)
  129. Blow off valve...Procharger. (4 replies)
  130. Can I turbo 10.5:1 on alch (3 replies)
  131. 2 Bolt main with BDS blower? (5 replies)
  132. Who to go to on turbos (38 replies)
  133. Intercooler sizing and placement (6 replies)
  134. 406 Single Turbo (4 replies)
  135. T/T Headers for SBC (6 replies)
  136. Blower bracket for Olds (3 replies)
  137. compression on lsx blower motors (8 replies)
  138. blow through turbos questions (9 replies)
  139. intercooler cores (8 replies)
  140. Wastegate Dump (12 replies)
  141. Re: Alternative affordable fuel option (4 replies)
  142. nos jetting (2 replies)
  143. wieand 6-71 clearence? (3 replies)
  144. Strap Wrench & Air Impact Wrench to Remove Blower Pulley??? (5 replies)
  145. Procharger to carb hat pix (9 replies)
  146. Kenne Bell LSX blower in 1st Gen (12 replies)
  147. looking for some info on the easiest power adder (9 replies)
  148. 250 Blower Under 1st Gen Hood? (1 replies)
  149. DISC installation Problems...Do I have the correct Bracket? (17 replies)
  150. Too much fuel pressure - with no boost yet (14 replies)
  151. Lets talk turbo voodoo (14 replies)
  152. Procharger with stock 69 camaro hood (1 replies)
  153. Nitrous for Newbie (2 replies)
  154. Nitrous install on an 01 Vette (3 replies)
  155. Help me build an engine (6 replies)
  156. Just bought my F1R!!! (41 replies)
  157. Crank Mount Cent Supercharger (11 replies)
  158. turob id help needed (0 replies)
  159. Twin Turbo kit for S.B.C. (10 replies)
  160. Turboing a 461ci Pontiac (10 replies)
  161. Procharger Race Bypass Valve Installation Pics, Ideas, etc... (8 replies)
  162. Could someone give me a recomendation for turbos (4 replies)
  163. Superchargers and aluminum heads? (15 replies)
  164. Test Fit On Passanger Side..... (0 replies)
  165. turbo question (4 replies)
  166. Y-TRY back on the dyno.. (6 replies)
  167. 454 ho w/ vortech or procharger? (30 replies)
  168. Twin Turbo SBC Questions (5 replies)
  169. turbos or procharger (1 replies)
  170. 69 camaro ls1 twin turbos (9 replies)
  171. Turbo identification (2 replies)
  172. air to water intercooler (2 replies)
  173. Which supercharger????Procharger or Vortech (33 replies)
  174. Rotrex Supercharger (2 replies)
  175. Need a cheat sheet for the Aeromotive 13202 (32 replies)
  176. Dyno #'s with vid (19 replies)
  177. Power adder for a ram jet 350? (1 replies)
  178. Blow-through set up using Edelbrock carb(s)? (4 replies)
  179. turbo newb (1 replies)
  180. sbc twin turbos (12 replies)
  181. Turbo's (2 replies)
  182. Wastegate Help? (9 replies)
  183. Wilson Manifold nitrous (10 replies)
  184. tt cold side update (8 replies)
  185. Turbo ?'s (6 replies)
  186. Different Style Twin Turbos (8 replies)
  187. turbo on an ls1 first gen ? (16 replies)
  188. Turbo blow through carb set up? (12 replies)
  189. How much boost will this 454 combo handle? (8 replies)
  190. Good book to learn about turbos - Recommendations (9 replies)
  191. Pro Charger questionS...thats plural, theres alot of them (2 replies)
  192. Ls1 Procharged....questions (0 replies)
  193. Compound Charging (20 replies)
  194. Finally ready to take the plunge!! (12 replies)
  195. ATI Procharger/LS1 motor/second gen Camaro (1 replies)
  196. Blow-Through D-1SC Procharger Boost/Pulley Questions... (11 replies)
  197. Air-Water folks inside please (5 replies)
  198. Massive single or dual intercoolers? (6 replies)
  199. Intercooler for 1st Gen Camaro ('68) ... Questions... (16 replies)
  200. turbo sizing (15 replies)
  201. Cam selection for TT setup (11 replies)
  202. weiand blower (8 replies)
  203. Turbo - will it fit under the hood? (12 replies)
  204. Everybody with turbo projects stop in and say hi (202 replies)
  205. Ihi Turbo Info (3 replies)
  206. NOS Top Shot Nitrous System (1 replies)
  207. Head Gasket thickness (2 replies)
  208. Turbo headers for nova (16 replies)
  209. intercooler design ?'s (2 replies)
  210. S/C for Poncho Engine (7 replies)
  211. Project JUST-N-SANE hits the TRACK!! (31 replies)
  212. HAHA the turbo project is back in full swing! (8 replies)
  213. Procharger modifications ? (6 replies)
  214. Magnacharger Opinions (21 replies)
  215. Procharger or Vortech ? (26 replies)
  216. Nova intercooler mocked up (8 replies)
  217. Need Experienced Turbo Users Help (20 replies)
  218. Supercharger for the track (6 replies)
  219. Blow off valve placement (2 replies)
  220. Turbo pics (9 replies)
  221. Procharger Question (3 replies)
  222. Weiand 177 blower on 1st gen Camaro (8 replies)
  223. Finally made some passes! (9 replies)
  224. reverse rotation supercharger? (2 replies)
  225. Just bought 502, now which supercharger? (13 replies)
  226. Help me get just the right parts. (16 replies)
  227. Turbo headers: mild steel or stainless (27 replies)
  228. Vortech Supercharging system (3 replies)
  229. BBC Procharger (3 replies)
  230. D1sc Procharger..69 Maro...ls1 (7 replies)
  231. Blow through supercharging (7 replies)
  232. turbo size (2 replies)
  233. Project JUST-N-SANE is back up and running! (21 replies)
  234. biggest front mount intercooler in 68-72 nova? (1 replies)
  235. Thinking about blower for 55 , where do I start ? (3 replies)
  236. Boost Controler controlled by vehicle speed? (9 replies)
  237. Water injection (29 replies)
  238. Max HP from an intercooled blow-thru P-1SC? (11 replies)
  239. LS6 & LS2 Cranks? (2 replies)
  240. Sputtering when stomping on it...??? Help.. (3 replies)
  241. OLD Martins Turbo set up.... (10 replies)
  242. Weiand 144 set-up..... (5 replies)
  243. super charger and front runner system (0 replies)
  244. here is a setup for somebody building ! (0 replies)
  245. 4 cylinder + turbo = anyone here tried it? (60 replies)
  246. who has the best price on intercoolers??? (16 replies)
  247. anybody try nitrous and a supercharger???? (3 replies)
  248. The Big Kaboom!!! (13 replies)
  249. Supercharger (Lean Condition) (3 replies)
  250. Mounting of intercooler (5 replies)
