View Full Version : Nitrous fuel line routing
brickyard69
04-24-2007, 06:30 PM
I am having difficulty coming up with a clean looking fuel line split to my nitrous fuel solinoid.
See my current set up:
http://www.putfile.com/pic.php?img=5304708
I plan on converting to AN lines.
Does anyone have any photoes of a nice set up?
My issue is mainly with slpitting the fuel line.
I though about mounting a carburated regulator on the inner fender, but then you have to run 2-3 ft of line and it might look sloppy.
I am also having vapor lock issues with this set up. You can see I am trying to issolate the problem with heat wrap.
shmoov69
04-24-2007, 07:57 PM
How bout like these!??!:drool:
kmcanally
04-25-2007, 03:38 AM
Heres mine...I added a fuel pressure gauge and a low pressure switch that opens the ground circuit to prevent activation when the pressure drops below 6 psi. You can also see the full throttle switch on the side of the carb in the second pic.
https://static1.pt-content.com/images/pt/2007/04/0701phr_06_z1968_ford_mustang-1.jpg
https://static1.pt-content.com/images/pt/2007/04/0701phr_10_z1968_ford_mustang-1.jpg
brickyard69
04-25-2007, 05:30 AM
SHMOOV69 that's pretty over the top.
Should I run a regulator instead of the fuel line splitter?
I am running a mechanical pump.
DeltaT
04-25-2007, 12:07 PM
You mean there's another way?? :smoke:
Jim
brickyard69
04-25-2007, 01:52 PM
Is it better to use a 2 port regulator instead of the type of splitter I have?
I need some picks of some simple power shot systems like mine.
fishtail8
04-25-2007, 03:55 PM
This one's pretty simple...
shmoov69
04-25-2007, 07:29 PM
I would rather run a regulator instead of just the splitter. Also, I would be carefull that the filter does not get clogged and starve the system of fuel, that would be bad! Also, be carefull if the pump is a stocker, sometimes they are not the most dependable in supplying adequate fuel.
But it should all be ok with a powershot and not too much timing! Oh, and good gas.
If you want to make sure it is ok, another way is to get a cheapie electric pump and a lawnmower gas tank (make sure it has at least a 3/8 outlet). Then mount them up front somewhere (in front of the core support works well) with a wire running to your button or microswitch. Then you have a seperate system and prolly won't ever starve the engine of fuel. You can also run good gas (110 octane+) and keep the timing at a normal level since you are adding good fuel and it shouldn't ever rattle!
Good luck!
brickyard69
04-26-2007, 04:51 AM
Fishtail8, thanks that is what I needed to see.
SHMOOV69 thanks for the info and the laugh with those pics.
