radicalc6
07-31-2007, 05:39 PM
have a few supercharger ????s
first, pros/cons of vortech, procharger
whos really better?
i have a 4 bolt main 383 stroker w/ Eagle rotating assembly w/ h beam rods. i am going to run holley systemax II heads :
Combustion Chamber Volume (cc):68CNC Machined Combustion Chamber:NoIntake Runner Volume (cc):184ccExhaust Runner Volume (cc):68ccCNC Machined Intake Runner:NoCNC Machined Exhaust Runner:NoIntake Port Location:StandardExhaust Port Shape:SquareExhaust Port Location:StandardSpark Plug Style:StraightIntake Valves Included:YesIntake Valve Diameter (in):2.020 in.Exhaust Valves Included:YesExhaust Valve Diameter (in):1.600 in.Intake Valve Angle:20Valve Springs Included:YesOutside Diameter of Outer Spring (in):1.250 in.Damper Spring Included:NoNumber of Springs Per Valve:SingleRetainers Included:YesRetainer Material:SteelLocks Included:YesLock Style:7 degreeValve Stem Seals Included:YesValve Stem Seal Style:UmbrellaRocker Arms Included:NoRocker Arm Studs Included:YesRocker Arm Nuts Included:NoRocker Arm Nut Thread Size:3/8-24 in.Guideplates Included:YesGuideplate Pushrod Size:5/16 in
a Lunati cam with 235°/240° duration at .050, .490/.490 in. lift, and 112° lobe separation.
is this a good combo for a supercharger ?
motor was being built for 10.0 :1 can change to 9.0
do i need a different cam?
i would like to run an intercooler
what kind of power can i expect?
this is for a street car only
thanks for the space and anyones time who reads this
whos really better?
