    Page 11 of 27 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 21 ... LastLast
    Results 201 to 220 of 536
    Thread: Project 70 RS
    1. #201
      Feb 2009
      N.J.
      The suspension & brake upgrade has offically begun!
      Got the rear suspension & the old brake lines out and the new Hotchkis leafs in.
      Talk about beefy hardware, I call this picture "Stock U-bolts & BIG ASS U-BOLTS"
      The original suspension comes with only 1 u-bolt per side. And of course they put the brake line clips right inline with where the 2nd set of u-bolts go. A quick run with the grinder and no more clips.
      A coat of por-15 plus a coat of bed liner keeps the rear right inline with the rest of the car.
      I even sprayed the leafs and all the brackets after a coat of POR.
      Now to pull out the axles and have the flanges turned down to fit the Kore-3 brakes.
      Hopefully more to come tomorrow.
    2. #202
      Feb 2009
      N.J.
      Well, I got the 18" Cadillac spare tire kit in.
      The wheel is awesome!!!!!
      Although, I do like that the GTO jack kit comes with 2 tire chocks.
      I am going to try and incorporate them into the Cadillac spare kit.
      I just need to mount the tire and order the adapter and I will have an awesome 18" spare.
    3. #203
      Feb 2009
      N.J.
      Had to do something about the Bilstein shock color.
      Just didn't go with the rest of the car.
      Now if I could just find some black Bilstein decals, it would complete it.
      Before -
      After -
    4. #204
      Feb 2009
      N.J.
      Pulled the axles out to start mocking up the Kore-3 brakes today. The stock axles flanges have to machined down to fit the rotors.
      The axles looked a little worn so a quick call to Moser and they are making axles to fit my application including the screw in ARP 1/2 studs.
      Also ordered a new set of bearings while I'm at it. They said I will have it by friday, so hopefully the back will be done this weekend.
    5. #205
      Feb 2009
      N.J.
      I had read the Kore 3 directions twice and just read them a third time and just realized that I forgot to order one little but very important part.
      The parking brake clevis to attach the Lokar parking brake cable to the Kore-3 actuator. Quick call and the part is on the way.
    6. #206
      Chicago
      Project 70 RS
      Looks awesome. I am happy you ordered new axles it makes the swap much easier and the the wheel studs will match the front.
      marty-mj
    7. #207
      Feb 2009
      N.J.
      Thanks Marty, I took your advice on the axles. After the cost of having the stock ones turned down, plus the fact that they were a little worn.
      For a little bit more I could just order new ones. Thanks again.
    8. #208
      Feb 2009
      N.J.
      Getting ready to install my Moser axles and Kore-3 brakes this weekend.
      Laying everything out to help me get started. I'm waiting for the axles which should come friday.
      Then I can get started.
      I really like Kore-3's flex brake lines. They are steel braided but have a plastic shield over them to keep them clean and protected.
      Nice touch.
    9. #209
      May 2011
      Country Flag: France
      Nice and clean work ahead of you, I got to say the same comment about Kore3 Lines, the are top notch!
      1972 Nova " Hotwhilz Special"
      https://www.pro-touring.com/showthre...t&goto=newpost Under the knife!
    10. #210
      Birmingham, AL
      Between this thread and Marty's build thread, I have learned so much. My car should go together so easily. Great documentation guys!
      Stephen
    11. #211
      Feb 2009
      N.J.
      I just wish my garage was as nice as Marty's. Hopefully that will be the next project.
    12. #212
      Feb 2009
      N.J.
      Axles didn't come so I kept myself busy with the brake pedal and mocking up the booster & master cylinder.
      I didn't like all the extra play in the brake pedal(side to side) plus I had to adapt the clevis to the pedal. I drilled out the hole and put a sleeve in so the pin would fit perfect. Plus I installed new bushings.
      Got the the m/c, booster, & Wilwood proportioning valve mocked up.
      Got a nice stainless steel bracket from Tobin over at Kore-3 to keep the prop valve nice and compact.
    13. #213
      Oct 2011
      Florida
      Looks great!!! Keep up the great work.
    14. #214
      Feb 2009
      N.J.
      Well, out with the old and in with the new. Axles that is.
      Moser really set up the axles for my specific application. Flange being machined to Kore-3's specs and the bolts holes being set up for 1/2-20 screw in ARP studs.
      Got them in and I'm ready to go.
    15. #215
      Feb 2010
      Central NJ
      Looking Good Paul! Awesome parts!
      -Sean
    16. #216
      Feb 2009
      N.J.
      Thanks Sean,
      I got out to the garage for a little while today.
      New bearings & seals.
      The Moser axles & dif cover went it. Really nice pieces.
      Plus the Kore-3 parking brakes. Love their directions, very detailed.
    17. #217
      Feb 2009
      N.J.
      Got the back brakes almost done. Just have to shorten the new brake lines to mate up with the Kore-3 Flex lines and hook up the lokar parking brake cables.
      New wheels & tires to go around the brakes.
    18. #218
      May 2011
      Digging the wheels!
    19. #219
      Feb 2009
      N.J.
      Thanks Hotwilz,
      Drilled holes in the frame for the sway bar brackets and got everything installed.
    20. #220
      Feb 2009
      N.J.
      Spent some time today cutting and trying to reflare the rear brake lines to connect up to the Kore-3 braided lines.
      I have a flaring tool, you know, the hand cranking kind. First time I tried to do stainless steel lines. WOW!!!! they came out bad.
      Took a drive down the road to Lou's automotive. He has a hydraulic flaring tool. SOOOOO much better and faster. Can't see spending $500 on one though.
      Lou has a 67, 68, 69 camaro, 68 Camaro race car, 65 chevelle racecar and a 68 442 that he bought new when he worked at the Olds dealership back in 68.
      Nice guy to have right down the road from my house.
