    Page 16 of 27 FirstFirst ... 6 11 12 13 14 15 16 17 18 19 20 21 26 ... LastLast
    Results 301 to 320 of 536
    Thread: Project 70 RS
    1. #301
      Feb 2009
      N.J.
      Spent a couple of hours yesterday looking on the web for the shaft. No luck. Seems nobody sells them.
      Went to my local trans shop and his response was "Oh yeah, I have a drawer full of them." Problem solved.
    2. #302
      May 2001
      Mesa, Az.
      Quote Originally Posted by aps63 View Post
      Thanks Hot rod camaro,
      The 18' spare is from a 1st gen Cadillac CTS-V 2004 - 2007.
      The part #'s are as follows.
      Wheel only 18" x 4" = #9596625
      Tire Kit 18" x 4" = #19179359
      The tire kit is what I bought.
      It includes the tire, wheel, valve stem, jack and accesories, plus the holder for the tire, jack & acc.
      Just so no one is confused the spare is from a standard cts of this generation. The cts-v had 6 lug hubs.
      Nice car! I really like that cast colored paint!
      Phillip
    3. #303
      Feb 2009
      N.J.
      Thanks for the clarification Philip. Not really sure why I added the V. I think I got it mixed up with the 2010 & 2011 CTS-V's which were 5 lugs.
      I got my info from this page.
      http://www.discountedwheelwarehouse...._Reference.cfm
      Thanks again for your input.
    4. #304
      Feb 2009
      N.J.
      Got the last pieces of the exhaust today. Was just waiting for 2 elbows, they came today. Hope to get some of the exhaust mocked up tomorrow.
      First going to run up to NY to pickup a new fender for the Camaro.
    5. #305
      Feb 2009
      N.J.
      Just got back from NY. I guy had a brand new Goodmark fender for sale for $80.
      Couldn't pass it up. The shipping alone would have cost me $150.
    6. #306
      Sep 2011
      Ontario, Canada
      Awesome build! I love the garage makeover too!
      What power steering pump did you buy? Is that a factory unit off a late model GM? I'm looking to upgrade mine this year.
      1970 Buick GSX Restoration/Pro Touring Build
      1987 Buick Regal Turbo T
    7. #307
      Feb 2009
      N.J.
      Quote Originally Posted by BBSkylark View Post
      Thanks, I'm really loving every moment in the garage now.
      The light, work space, and room makes all the difference in the world. I wish I had done this years ago.
      Yes, it is a late model GM unit. I bought it from Jegs.
    8. #308
      Feb 2009
      N.J.
      Had some time slotted for cleaning up the leaves today. Started to rain so out to the garage I went.
      Haven't had much time lately so I took advantage of the rain delay.
      Bleed the brakes with my new Phoenix reverse bleeder. Got it a while back and this is the first time I've used it.
      Pretty easy to use but I guess the real test will be when I drive it.
    9. #309
      Feb 2009
      N.J.
      I want to start on the exhaust but am realizing that the fuel pump is in the way of the new muffler. The new system has a transverse muffler and will be tucked up in front of the fuel tank(original position, as everybody knows).
      So, Pulled out the fuel pump and I'm looking for a new location. Plus I'm thinking of replumbing all the lines. I have been looking at Jiffy-tite quick connect fittings. A little pricey but makes swapping out parts spill free.
      http://motorsports.jiffy-tite.com/
    10. #310
      Feb 2009
      N.J.
      Started to mock up the exhaust today after I removed the fuel pump. Not really liking the thrush hangers. They want me to drill holes in the body to bolt in these hangers.
      Not thrilled with that. I still have the stock hanger pads in place, so I figured why not just order stock hangers. Should be a cleaner look and no extra holes drilled in the floors.
    11. #311
      The Netherlands
      Country Flag: Netherlands
      here's what I did (have the transverse muffler too)
      also reduces the noise considerably.
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
    12. #312
      Feb 2009
      N.J.
      Nice job Martin. I want to get the exhaust in first and then see where I have room.
    13. #313
      Feb 2009
      N.J.
      I got the stock hanger brackets in and they are meant for a 2" exhaust.
      Tried to bend them into place, but then they are not long enough to get the holes to line up. So, time to make my own extended brackets. Not enough time today. Should get to it this week though.
    14. #314
      Feb 2009
      N.J.
      Finally got the new brackets made for the stock exhaust hangers. New one for the 2.5 exhaust is on top.
    15. #315
      Feb 2009
      N.J.
      The new brackets I fabbed and the stock exhaust hangers fit together great.
      Did some cutting and welding on the exhaust today too.
      Started with some exhaust extensions and some flanges and got them cut and tack welded.
      Not a ton of progress but these days even a little is a step forward.
    16. #316
      Feb 2009
      N.J.
      Got the rest of the exhaust mocked up today. Hopefully I can do the finish welding this week. Got it tucked up right where I want it.
    17. #317
      Feb 2009
      N.J.
      I have been spending a bunch of time trying to find a new spot for my electric fuel pump. The transverse muffler takes up just about every inch of room. So, I have decided to go back to a mechanical fuel pump. Should be plenty for the motor that I have. I forgot to order the adapter plate though, so I ordered it today.
    18. #318
      Feb 2009
      N.J.
      Now that I have the stock exhaust hangers set up, I want to put one more hanger in for the tail pipes.
      I was going to use this type. It doesn't really match the stock hangers that I have though.
      I have seen this type used before and I really like them.
      So I ordered 2 of these from Summitt Racing(for $5 each) and I will fab up the other part.
    19. #319
      Feb 2009
      N.J.
      For a while now I have been pondering the problem of my new power steering pump pulley not having enough contact area with the belt.
      I have tried several times to relocate the power steering pump (using differant brackets) to no avail. Finally I decided to use an idler pulley.
      Not having much room, the only possible location for it was on the a/c bracket. I basically spent the half the day on it.
      Fabbing and then refabbing each small part of this puzzle until it goes together perfectly.
      In the first picture you can see how the belt would not contact the power steering pump pulley enough. Now I just have to get a longer belt.
    20. #320
      Feb 2009
      N.J.
      Went to roll down the pass side window and the front of the glass dropped about a inch. Took the door apart to see what was wrong and found one of the rollers had broken. Just spent the day pulling both doors completly apart.
      I have wanted to install electric windows for a while now and I guess this was my sign that it was time.
      I have been looking at the Nu Relic's kit. The kit seems pretty complete. Includes the regulators, motors, wiring harness w/switches, and the wire conduit for between the door and body.
